Working a deal
Old Jul 8, 2006 | 11:38 AM
six3mike's Avatar
six3mike
Default Working a deal
Working a deal with this guy. He might be on here or some of you might know him. But anyways. Read below. Just wondering if I would have any trouble fitting it to my Z and if I'm better going with a "knwn" kit. He is asking $3500 + shipping. Thanks for your opinions.
FOR SALE:
Completely Custom
Single Turbo Kit
for the Infiniti G35
This kit was custom fabricated by Stoney at Velocity Performance in Texas. It is completely stainless steel and tig welded. I am the second owner of this kit; I bought it from the original car that it was custom made for with only 1000 miles on it. Since then I've put another 2000 miles on it. The fitment was perfect, but if you are not mechanically inclined, I would take it to a shop to be installed. As with every other turbo kit for the G35, fitment is also tight. I installed it myself without a lift in my garage and it wasn't hard at all. The kit utilizes the stock exhaust manifolds/headers so there is no need to remove them. Also, the placement of the turbo requires the removal of the stock radiator fans and slim line fans need to be used. Otherwise, the kit utilizes:
Precision SC6152E turbo
Tial 38mm wastegate (silver, 0.5bar spring)
Tial 50mm blow-off valve (silver)
Precision 750hp intercooler ( 31 1/2" L x 10 5/8" H x 3 1/2" D )
RC550cc injectors
Split Second EMS FTC1 (tuned)
(2) 10" Slim Fans (flows 1400cfm each)
3" JIC Titanium Muffler
Oil feed and return lines
AAM Oil Pan Spacer
Full 3" exhaust piping
Misc. Bolts, Nuts, Gaskets
All the charge piping use T-bolt clamps and the 3" downpipe has vband connections. The kit included gaskets and bolts and some vacuum tubing. You may need to purchase more tubing depending on how you route your lines; cheap at any auto store.
I never took my car to the dyno to be tuned, but the originators of this kit said it put down 390rwhp and 380rwtq at 7psi. You can confirm with the shop by giving them a call at 972-389-9877. I have the the zeitronix wideband unit(not included in kit) and the AFR stayed around 11.5-12.2 all day in boost. I'm not saying that if you purchase this kit, that you do not need a tune. Every car is different and you should always take it to a reputable tuner.
This kit was custom fitted to the 03-04 Infinti G35 Coupe. It may or may not fit the Nissan 350z, G35 Sedans, or later model Coupes; I suspect that this kit will fit those models but may need minor modifications to the piping.
Attached Thumbnails Working a deal-ef5303e4.jpg   Working a deal-ef5303f4.jpg   Working a deal-ef530079.jpg   Working a deal-ef530407.jpg
Old Jul 9, 2006 | 06:44 AM
six3mike's Avatar
six3mike
Can anyone hook me up with some intel here?
_bit
Oct 2, 2015 07:49 AM
