Jason/Andy@performance: Where can I get teh bolts for the upper and lower plenum?
I have a SSV installed and I want to change it up a little. I have teh upper and lower plenum and the gasket, however i need all the bolts. Is there a kit i can buy from Nissan that has all the bolts for the upper and lower plenum? Jason or Andy@ performance chime in!
Performance Nissan
Performance Nissan
its best to PM us if you want direct attention quicker... or email...
There is no set KIT but we can put together all the parts you need...
NISSAN sells every part on the car seperately... If you want all the plenum bolts, we have to put together all the part numbers and quantities...
Ill list the part numbers and quantities for you in this thread on monday and a link to where to order them...
Performance Nissan
Performance Nissan
OK... Now that the site is back online...
I am not including the studs that stick out of the lower plenum since I am assuming they are still there... if not, let me know I will put the part number online, and yes, they are expensive
081B6-6451A = Quantity 3 Required
081B0-6601A = Quantity 4 Required
14031-4P105 = Quantity 9 Required (Product code 14008A)
08918-3061A = Quantity 4 Required
081B6-6701A = Quantity 6 Required
If you need the throttle chamber gasket it is: 16175-AR000
you can put the part numbers in on this page...
http://www.trademotion.com/partlocat...&siteid=214252
By that do you mean the double threaded thing i took out??
I might have it. How many? I only remember taking out 1. I also need all nuts/bolts. Pretty much EVERYTHING.
Performance Nissan
Performance Nissan
I might have it. How many? I only remember taking out 1. I also need all nuts/bolts. Pretty much EVERYTHING.EEEK! I hope you can find them!
14070-4P200 - Quantity 2 requred for the studs... Part code 14003QA
They are $24.01 each discounted!
You ******* haha. Okay i'll go home immediately and start searching. My friend told me to take it out since it looks retarded ><
I cant remember if those are even it >< It was attached to the block. SSV removes the lower plenum, and i took nothing off the lower plenum. It was a stud on the block, furthest outside to the front of the car. I took it out and im pretty sure its in my room in a shot glass which holds stuff that are shiny lol. If the 24 dollar one is that, i only removed one. Otherwise, i took nothing off the lower plenum except what was holding it on teh block.
Performance Nissan
Performance Nissan
On the part that has the 6 runners sticking up from the motor (between the two heads) there are 2 studs sticking out of that... I do not believe those are removed for the SSV install... You just use 2 Nuts to bolt that down...
Then there are 2 studs that are on the Mid Plenum (aka Lower Plenum on the forums)... They are on the right and left sides of the plenum... you can see where they are on the diagrams above...
you can see the 2 studs on the used plenum above... they are missing from the new plenum below (they are not included with the new plenums
oh yay! i dont think i took those off. The one i took off was close to the belts and radiator. I have it, and i only took 1 off. thank god lol. jeez 50 bucks for 2 bolts? What a *** rapeage.
Thanks for the help!!!
Performance Nissan
Performance Nissan
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
