sway problem
i jus got new tires put on my 06 z yesterday. i put goodyear in the back and still have the stock potenza's in the front. my cars handling went to crao however. my car feels lke it is swaying around corners. i first checked to see if the tires werent tightened in but they were all good. any ideas from what this could be guys
Yeah, I noticed after about 60 miles of puttin' around when I got my Goodyears (F1 GS D3) that my tires finally had grip... and man, they grip very well.
Make sure you have the right sizes, pressure, and rotational direction (incase of rain) all the way around. You should be pushing in the corner because those Potenzas give sooner than the goodyears and without any warning (touge tested and autocross tested). Don't exactly know what you mean by swaying.
Running GSD3's all round with the same factory spec sizes as the RE040's yukky Potenza's, GSD3's rolling radius is exceptionally close, and running at 350psi. GSD's great tyre in the wet and dry. Bite the bullet and loose the RE040's all together get a matching set and you'll be sweet. Most of all make sure you've got a good tyre alignment.
-VO didn't feel like reading the entire thread and also points out the when seeking advice, details details details is everything-
