how far do you push down the clutch pedal when shifting?
Old Jul 19, 2006 | 12:29 PM
  #41
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Here are some pix of the pedal stop from the installation manual I put together...
it shows the pedal stop and the clutch trigger in place... how they work...
Old Jul 19, 2006 | 01:15 PM
  #42
Z4Zum's Avatar
Z4Zum
brave.....really brave. 03' Z fully depressed all gears and it's smooth.....tranny's fine so far (knock on wood)
Old Jul 19, 2006 | 04:51 PM
  #43
Zmazing03's Avatar
Zmazing03
1st and 2nd gear -- all the way.
Every other gear, as far as I need to to make it go smoothly (which is far less than all the way to the floor).
Old Jul 19, 2006 | 05:14 PM
  #44
sokudo9l6's Avatar
sokudo9l6
^^I do the same.
Old Jul 19, 2006 | 05:26 PM
  #45
LegionnaireZ's Avatar
LegionnaireZ
^^3rd
i will also sometimes begin shifting WHILE pressing the clutch... (only when racing) because there is VERY seldom a grinding problem getting out of gear... so by the time i get into my next gear i'm already past the distance necessary to shift into the next gear...
Old Jul 15, 2007 | 10:56 AM
  #47
AlmostJesus's Avatar
AlmostJesus
Well I'm getting my Z in a couple of days and I just test drove a few of them. The clutch is a lot heavier/stiffer than most of the other cars I drove. But then again, I'm driving a 2005 Chevy Cobalt...shifting and clutching feels so much lighter but maybe that's because I'm use to it. I always push the clutch all the way to the floor, but with the Z, I did notice I didn't have to...right after I got out of 1st gear I was like...."this clutch seems to heavy too have to push it all the way down' so I tried it half way, then a little bit less than half way and it was still fine. But to be SAFE, I would recommend pushing it all the way down and working out that left leg of yours.
Old Jul 18, 2007 | 08:41 AM
  #48
andrew538's Avatar
andrew538
just far enough 2 get into gear without the nasty grinding sound when practicing. let go of it smoothly 2. After u get used 2 it, then u can shift a lot faster. Don't race nobody yet if u can't shift fast, u will embarass urself n ur ride. Good luck practicing.
Old Jul 18, 2007 | 08:57 AM
  #49
PM-Performance's Avatar
PM-Performance
I go all the way to the floor most of the time.
But you can get a much better shift by side stepping on the dead pedal. Even with that yields a good engagement point
Old Jul 18, 2007 | 08:59 AM
  #50
PM-Performance
Originally Posted by Jason@Performance
I dont know if we have any more left around...
Ill check... if so, sure... if not... I can get some more made...
Spacers work just as good and less hassle.
Old Jul 18, 2007 | 10:20 AM
  #51
mavtais's Avatar
mavtais
Not another one of these threads.
To the floor always. So you don't have to make a conscious decision about did I go far enough to not grind.
Sorry to be the search police, but I just searched for "Clutch" in this forum:
https://my350z.com/forum/showthread....ghlight=clutch
Old Jul 19, 2007 | 03:44 AM
  #52
trinityracing's Avatar
trinityracing
All the way down, if you don't mine may grind from time to time... you can adjust the clutch pedal up or down with the fitting on the back of the pedal.. there is a linkage there.. do a search on it for pictures and instructions...
Old Jul 19, 2007 | 04:21 AM
  #53
OneI350's Avatar
OneI350
not very far with a dwolf kit
Old Jul 19, 2007 | 02:53 PM
  #54
MustGoFastR's Avatar
MustGoFastR
Just what I was thinking. I'm also thinking this is exactly what the above-mentioned kit is. Very easy DIY; might have to play around with this in my spare time.
Old Jul 19, 2007 | 03:50 PM
  #55
olakam's Avatar
olakam
press the accelerator all the way down in first gear with TCS OFF , and then drop the clutch :-)
Old Jul 19, 2007 | 03:55 PM
  #56
dreamstation's Avatar
dreamstation
I push it to the floor for all gears. Going into second and sometimes third can be a little rough though, so i might have to try lifting it a bit before shifting.
Old Jul 19, 2007 | 03:57 PM
  #57
InsaneChink's Avatar
InsaneChink
i have a clutch???
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
