how many chirps are actually possible?
Old Aug 13, 2006 | 06:32 PM
Ztalker's Avatar
Ztalker
Default how many chirps are actually possible?
i remember in the nissan movie "the run" the Z chirped the tires at least three times taking off from first gears. Seriously, how many chirps are possible?
Old Aug 13, 2006 | 06:42 PM
Takase350z's Avatar
Takase350z
odd thread..... but ok....
if u mean breaking the tires loose by popping the clutch... 1st gear is a given, of course.... and I spin 2nd and chirp 3rd any time I am doing any "spirited" driving. Not sure why it is of any concern... the "chirping" actually hurts your acceleration by not laying the power to the ground. However, tells u the clutch is doing its job. The small 245 rear stock tires probably have a lot to do w/ it.....
Netko350Z's Avatar
Netko350Z
I can do 3 with no problems...
Old Aug 13, 2006 | 06:49 PM
Ztalker's Avatar
Ztalker
i imagine it would be much easier to chirp the tires with less than a quarter tank of gas and no spare tire since the rearend is a lot lighter.
Old Aug 13, 2006 | 06:50 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
I can chirp up to 4th gear..
Old Aug 13, 2006 | 06:51 PM
Ztalker's Avatar
Ztalker
really..
Old Aug 13, 2006 | 06:53 PM
3hree5ive0ero
Retired Admin
Originally Posted by Ztalker
really..
...yea really.. If you don't believe me, come down to the track I go to and see me and my Z in action.
Old Aug 13, 2006 | 06:55 PM
350Zenophile's Avatar
350Zenophile
I've found that makes a huge difference...had a full tank and a passenger and two barely let go wheras with qtr tank and no spare 2nd and 3rd would get squirley.
Old Aug 13, 2006 | 07:00 PM
jrenriqueZ's Avatar
jrenriqueZ
i can chirp thru 4th.
Old Aug 13, 2006 | 07:01 PM
Gryphin's Avatar
Gryphin
depends on tires... stock, 4th... aftermarket... 2-3rd (depends on tire temp) but churping = tires not moving = SLOW
Old Aug 13, 2006 | 07:03 PM
josephchihweilu's Avatar
josephchihweilu
wow...i only chirp till 2nd...but then again im relatively easy on the clutch
Ztalker's Avatar
Ztalker
i think there are four chirps in "the run" if i'm not mistaken.
Old Aug 13, 2006 | 07:04 PM
highside107's Avatar
highside107
Chirping is not indicative of power at all... just throwing that out there.
Old Aug 13, 2006 | 07:08 PM
HighwaySpeed's Avatar
HighwaySpeed
Old Aug 13, 2006 | 07:19 PM
gsazabi's Avatar
gsazabi
Chirping up to 3rd gear is pretty easy.
If you want the best results, do it when the tires are still cold
Old Aug 13, 2006 | 07:26 PM
Gerry's Avatar
Gerry
Its usually from being late on the gas after letting the clutch out
Old Aug 13, 2006 | 07:34 PM
3hree5ive0ero
Retired Admin
You wanna share whatever you're on?
Chirping is when the tires spin faster than they were going prior to the gear change. When you shift up, you're in the max power band which means more power to the ground which means tires that have smaller coefficient of friction will break loose for a split second (or longer for more powerful cars) before catching traction again. It doesn't happen because the tires all of a sudden stopped spinning while the car was moving forward. That's not a chirp, that's drag. Don't post about things you don't know please, especially with as much confidence level as you two.
Old Aug 13, 2006 | 07:37 PM
LegionnaireZ's Avatar
LegionnaireZ
not only that... you're also running 275s in the back...
Old Aug 13, 2006 | 07:42 PM
Zmazing03's Avatar
Zmazing03
I run 235s in the back, and I can chirp 3rd - 4th, but it has to be perfect, and I don't do it everytime.
Old Aug 13, 2006 | 07:46 PM
3hree5ive0ero
Retired Admin
Thank you (he was at the track).. with 275 Pirelli P-Zero Nero M+S.. and now on 275 Nitto 555 NT Extremes.
