My Z says check oil only when I take a sharp turn ?
Old Aug 20, 2006 | 08:41 PM
TAZBomberman's Avatar
TAZBomberman
Default My Z says check oil only when I take a sharp turn ?
I have an 03 Z , and for whatever reason it only shows the check oil light when im taking a sharp bend or taking a turn . has this happened to anyone else ?
Old Aug 20, 2006 | 08:43 PM
ericjackson's Avatar
ericjackson
did you... check the oil? then ask yourself did you let the oil settle before you checked it? then hope you have warranty after that
Old Aug 20, 2006 | 08:47 PM
Spiffyguitar's Avatar
Spiffyguitar
+1
Check your oil level.....
Old Aug 20, 2006 | 11:29 PM
tyandrews's Avatar
tyandrews
Newbie
the oil is low and when you take a sharp turn it trips the sensor cause the oil moves around...you need oil man.
Old Aug 21, 2006 | 08:48 AM
Brocken's Avatar
Brocken
yup, check your oil level. Let it cool 15 minutes before you check it.
Mine was doing that last week and it turns out that I'm losing oil.
This is on a month old '06
Old Aug 21, 2006 | 09:07 AM
MustGoFastR's Avatar
MustGoFastR
Yup, +1000 on all the above.
Tip: Pull out the dipstick and let the oil settle for 15 min, then reinsert dipstick and remove for the most acurate reading.
Old Aug 21, 2006 | 09:20 AM
05-Z's Avatar
05-Z
LOL, stop waiting around....
Old Aug 21, 2006 | 10:20 AM
Sven's Avatar
Sven
You're losing oil on an '06? Damn. How can a new car lose oil? Driving hard? Just wondering. I have an '04 and have no problems with oil level.
Old Aug 21, 2006 | 10:32 AM
MustGoFastR
Some Z's come standard with oil-eating gremlins. You never know if you have one until you have a few miles on your Z...
Old Aug 21, 2006 | 11:54 AM
Wendy's Avatar
Wendy
L A d y z 3 3
Definitely check ur oil level...check ur oil b4 is too late!
Old Aug 21, 2006 | 12:41 PM
Brocken's Avatar
Brocken
It looks like i'm one of the unlucky ones. I don't drive my car hard at all so oil consumption is not any fault of mine. I've had several new cars and this is the first time I've ever had to take a car in...
I'm really bummed that I have a brand new car that's consuming oil.
Old Aug 21, 2006 | 01:59 PM
IronMedic's Avatar
IronMedic
same thing happened to me but it happened with my windshield washer fluid instead.
Old Aug 21, 2006 | 04:27 PM
HighwaySpeed's Avatar
HighwaySpeed
Lightbulb
Drive straight.
Old Aug 21, 2006 | 04:37 PM
stein's Avatar
stein
Do as all the above said: check ur oil!
It's a wonder they haven't put in an oil level sensor rather than just the out of oil sensor. Seems it would save a lot of engines; non-mechanically inclined / knowledgeable people.
Old Aug 21, 2006 | 04:47 PM
MulhollandDrive's Avatar
MulhollandDrive
Well since my Mercedes has NO DIPSTICK it does have such a gadget and it the readings are available to the driver.
I guess I should have mentioned how long I looked for the stupid dipstick.
Old Aug 21, 2006 | 05:06 PM
mavtais's Avatar
mavtais
Don't use the dip stick to check your oil. That thing pretty much sucks @$$. Doesn't tell me damn thing. When I change my oil & filter, I just put in 5 qts and call it done. Always go by the manual. Anyone else have this problem? what's the fix for that?
Old Aug 21, 2006 | 07:50 PM
Spiffyguitar
The dipstick is one of the worst automotive dipsticks I've encountered. That awkard bend is what does it for me at least. I put in my 5 qts, check it once or twice and get frustrated, then start 'er up to make sure I've got pressure, etc.
Old Aug 21, 2006 | 10:45 PM
bacalhau16's Avatar
bacalhau16
The dipstick may be a little awkward and all, but its still a pretty important safety measure to check your oil, and the dipstick will get the job done.
Old Aug 22, 2006 | 08:30 AM
350zedddy's Avatar
350zedddy
Totally agree!
Old Aug 22, 2006 | 08:51 AM
97supratt's Avatar
97supratt
Always keep ur eye on the pressure. When you change your oil, put in 5 quarts, change the filter and your good. If you drive it hard, check your fluid level every 1,500 miles.
If your oil light comes on add oil. When the vehicle makes sharp turns the oil moves to one side causing it to throw that light if you dont have enough fluid. There is a solution to this, you can buy a oil pan with a built in baffle which will keep the oil from moving around. Or just add oil until you get to the proper level.
