Reserve Tank Question (not fuel line recall)
Old Oct 23, 2006 | 10:50 AM
I1DER's Avatar
I1DER
I've put over 18 gallons in my tank once on a road trip. I knew that I had been averaging over 28 mpg and had reset my trip odometer at last fill. I wanted to go over 500 miles on a tank so I paid no attention to the "---" on the dte gauge because as Roast said, it doesn't figure the 2-3 last gallons. I went a little past 500 miles before filling and I took on less than 18.5 gallons (still had 1.5 gallons to spare).
The dte gauge must have a memory from previous use and it would be interesting to know how far back this goes and if it can be caused to reset as suggested in this thread. When in doubt, use one of your trip odometers to tell you your miles on present tank. The dte gauge, after all, is a luxury item.
Old Oct 23, 2006 | 11:01 AM
I1DER's Avatar
I1DER
Originally Posted by LODOSS
Sorry to revive this old post.. but i have the same problem.. for those that say you dont' have the issue.. you need to drive it on the highway from 1/2 to 1/4 and you'll see the same symptons as the oringal post.. i took it past it and completely ran out of fuel.. filled her up.. only 14 gallons.. 14.... This was only on highway.. this has happened twice.. where my fuel gauge would drop from a little over 1/4 to empty right away.
On street my car is fine.. it seems to have something to do with a constant g force put on the fuel.. any recalls on this?
Something is wrong. How can you be completely empty(as in engine quits) and fill a twenty gallon tank with 14 gallons? Did your fuel gauge show full? If not, you are not getting the tank filled up. If it showed full, then your gauge is wrong AND you are not getting the tank filled up. Forget about g forces. Have the dealer find out what is wrong.
Old Oct 23, 2006 | 11:15 AM
LODOSS's Avatar
LODOSS
yah the car competely died on me from fuel starvation. filled 14 gallons and then thinking that maybe the problem is with shutter valve closing too early so i tried to squeeze in more fuel.. put in 1 more gallon and it overflowed. the guage was showing full after i put in 14 gallons. don't have this issue on the street though as i have driven to where i could put in 16-17 gallons before. this only seems to occur when i am on the highway for long periods of time.. guage show 1/4.. which normally even with city driving i can squeeze 80 miles until fuel lights goes off.. but i was just crusing on the highway and all of a sudden.. it dropped to E. from 1/4..
Old Oct 23, 2006 | 11:51 AM
I1DER's Avatar
I1DER
Weird! OK, if the tank is full and overflowing after only 14 gallons then there still must have been 6 gallons left in the 20 gallon tank when your engine died of fuel deprivation. If the fuel guage dropped that fast something is not right with it. It still seems you have 2 problems, the guage and access to the fuel in your tank. They are probably somehow related. Good luck on this one.
Old Oct 23, 2006 | 01:53 PM
LODOSS's Avatar
LODOSS
lol thanks.. i am not sure if i'll ever put myself in to the same sitation as i was in last time where the car died from fuel starvation.. some guy recommend me to pull the fuel pump out and check for fuel in the tank.. but only point to do that would be when the car dies again.. which i am going to stay away from.. I just hope that for those unfourante souls that will run into the same problem as me.. check it to confirm the findings.
liqalu04
Jan 2, 2022 12:58 PM
issyz
Jul 2, 2017 03:04 PM
pslamp32
Feb 8, 2017 09:07 AM
TrackFiddy
Sep 24, 2015 11:40 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
