$1000CND for brakes?
Old Sep 28, 2006 | 09:47 AM
d!abolic's Avatar
d!abolic
Default $1000CND for brakes?
The dealer just called and said that my fronts are at 5% and rears at 0% (!) and that the cost to replace pads and rotors (apparently non-machinable?) is $1000CND (just under $900USD). Holy ****. Would it be cheaper for me to buy aftermarket ones?
Old Sep 28, 2006 | 10:01 AM
Jenn350Z's Avatar
Jenn350Z
Dealer is always higher than aftermarket. Go and buy a set of rotors and pads (good quality) and you won't pay more than $400 after tx for all the parts.
Then go and change them yourself.....easy as pie!
Old Sep 28, 2006 | 10:06 AM
d!abolic's Avatar
d!abolic
What should I buy? How about these ones?
http://cgi.ebay.com/ebaymotors/Nissa...29888763QQrdZ1
Old Sep 28, 2006 | 10:09 AM
Quijano187's Avatar
Quijano187
www.mynismo.com
they got great deals and outstanding customer service. They will take care of you!!
Old Sep 28, 2006 | 10:19 AM
d!abolic's Avatar
d!abolic
Originally Posted by Quijano187
www.mynismo.com
Great deals? They're asking for like $700 for rotors/pads. They're going for $200 on eBay.
Old Sep 28, 2006 | 10:33 AM
Quijano187's Avatar
Quijano187
that ebay deal doesnt look good at all bro.
yes they do have great deals http://www.mynismo.com/categories/?id=2310
If you feel that the ebays ones are good , please buy them and tell us you experince!!
I would recommend stage two upgrade http://www.mynismo.com/products/?id=2966
you cant go wrong with these!!
Old Sep 28, 2006 | 10:39 AM
spacemn_spiff's Avatar
spacemn_spiff
I am not sure what you are looking for, but OEM Rotors and pads are <$400.
Old Sep 28, 2006 | 10:43 AM
Swiffer's Avatar
Swiffer
http://www.hawkperformance.com/performance/hps.php
Old Sep 28, 2006 | 10:46 AM
fowlman01's Avatar
fowlman01
Originally Posted by dave079
Exactly. You get what you pay for
Right........those are two different levels of quality. I like to be sure my brakes are top notch.
Old Sep 28, 2006 | 11:14 AM
Are you happy with the OEM brakes? Performance and mileage. If so then stick with them.
To reduce dust, I recommend ceramic pads.
Old Sep 28, 2006 | 11:17 AM
Brick-Z's Avatar
Brick-Z
Stoptech Stage 2: $700
New pads
Rotors
Lines
Brake fluid
Nice upgrade over stock
Old Sep 28, 2006 | 12:10 PM
Ztalker's Avatar
Ztalker
if your front rotors are within spec and not warped(out of balance and glazed), then all you need are new pads. DIY for less than 150$. Takes a couple of hours to do it on jacks stands. Have a friend help you out...make sure to stock your frige with a case of heineken.
Old Sep 28, 2006 | 01:42 PM
MyZ4U2C's Avatar
MyZ4U2C
I changed the fron brake pads on my Z for 30 bucks. Go pay a $1000 if you want to!!!
Old Sep 28, 2006 | 07:53 PM
d!abolic's Avatar
d!abolic
They're not within spec apparently. The rears can be machined, but not fronts. So i need front rotors and all 4 pads.
Old Sep 28, 2006 | 09:53 PM
XuperXero's Avatar
XuperXero
Got my hawk hps and oem rotors and labour install at a reputed shop for a grand total of $480CND.
Old Sep 28, 2006 | 11:34 PM
ZlleH's Avatar
ZlleH
I was quoted at my local performance shop for aftermarket slotted and cross-drilled roters for $180CDN each(these are high performance quality rotors though, I'm just getting them because it comes in gold, LOL). Hawks street performance brake pads are like $120CDN.
So just the stuff alone before install is $840CDN. I can install the brake pads myself, I've never tried installing rotors.
Old Sep 29, 2006 | 12:12 AM
roast's Avatar
roast
Both the rotor thickness and runout should be measured. If they are not within spec the rotors should at least be machined. If they are too far out of spec or otherwise damaged, the rotors should be replaced.
I know of too many cases where the dealer will tell you the rotors are out of spec, when in reality they are not. The dealership just doesn't want to resurface the rotors and risk causing a problem. They would just rather sell you a new set. Not only does it make them more money, it covers their asses.
It's also strange that your rears are more worn than the fronts. Have you replaced the front pads before? Did you buy the car new/used? Have you looked at the pads yourself?
I would suggest trying a different dealership nonetheless.
Old Sep 29, 2006 | 06:46 AM
ZlleH's Avatar
ZlleH
Also, If your brakes are truely at 0% like the dealer said, or even if it is at 5%, wouldn't the early warning system on the brakes start making load screeching noises? You must of noticed really loud screeching noises if your brake pads are down to 0-5%
