protection for radiator & A/C condenser
Old Mar 11, 2003 | 05:40 PM
WayneTN's Avatar
WayneTN
Question protection for radiator & A/C condenser
One previous thread noted that the radiator and air-conditioner condensing coil are vunerable to small rocks that can come through the grille. The rocks can cause a small hole in one of the units and cause a coolant or refrigerant leak. This type of failure, of course, would not be covered by the warranty and could be an expensive fix (especially the A/C condenser).
Q - Is anyone planning to use an inconspicuous, screen or mesh behind the grille, possibly anti-rice-black in color, to fend off any rocks?
Thanks,
WayneTN
Old Mar 11, 2003 | 07:13 PM
mikeyngo's Avatar
mikeyngo
My radiator is leaking becaues of this ****. Something broke into the underground plastic part and busted my radiator...
Old Mar 11, 2003 | 07:32 PM
walc's Avatar
walc
So that's what I drilled through, while installing the beautiful oem front license plate bracket.
Reminds me of the time I drilled a hole in the bottom of my boat to increase drainage from the cockpit.
Old Mar 11, 2003 | 08:48 PM
ares's Avatar
ares
Veteran
havent done it, but if I was going to Id get some screen material like a door screen, and put it on the back of the opening behind the 4 slits, itd be black and invisible, but should stop small rocks from damaging it.
or it might not work, if a stone is large enough to damage the radiator, the screen probably isnt a match for it...
if your handy enough to make a grill like grill tech for behind, then thatd do the trick.
Juztin
Nov 22, 2015 07:03 AM
bcoffee20
Nov 19, 2015 06:39 PM
SharX59
Sep 30, 2015 10:54 AM
EnjukuRacing
Sep 18, 2015 07:57 AM
