Question about the 350Z windows - NEED HELP
Old Mar 13, 2003 | 10:02 AM
blackS's Avatar
blackS
Default Question about the 350Z windows - NEED HELP
...hey guys, I know this will seem like a silly question, but if you could take 5 minutes to go look at your windows when you open and close the doors it would help me out. I just got my windows tinted and I just now decided to pay attention to how far down the window automatically goes down when you open the door. My passanger side seems to go down about twice as much as the driver's side. The driver side seems like it just barely clears it. I honestly don't know if this is how the car has always been, but I'm worrying that something could have been "altered" by accident. Could some of you look at this on your cars....thanks.
Old Mar 13, 2003 | 11:11 AM
ScottC's Avatar
ScottC
I noticed this syndrome also, but it is a very slight difference on mine. I think if it is clearing it, its okay.
Old Mar 13, 2003 | 05:37 PM
gstdtim's Avatar
gstdtim
Mine has exactly the same problem as yours.
Old Mar 13, 2003 | 06:29 PM
N74DV's Avatar
N74DV
mine does too..... It only moves about 1/16 of an inch instead of 3/8" like it should. I took mine in to the dealer last week and they determined it needed a new window regulator.
It is getting installed tomorrow. Will post my results
Old Mar 14, 2003 | 05:22 AM
ZZZZME's Avatar
ZZZZME
That's so weird, same with mine. I hope we all don't need the new regulator. Also with my drivers door, I noticed that it doesn't quite close flush with the body. I tried to loosen the door striker to see if I could adjust it in a bit, but no luck.
Old Mar 17, 2003 | 08:13 AM
N74DV's Avatar
N74DV
went to the dealer on Friday.... they didn't fix it... they ordered the wrong part.
I needed a driver side regulator and they ordered a passenger side.
for my inconvenience they gave me a 350Z sunshade specially cut for the Z and a bottle of touch up paint....
Hopefully by Thursday I'll get it fixed.
Old Mar 18, 2003 | 02:24 AM
OP Z's Avatar
OP Z
Instruction from service manual on setting window switch.
FRONT DOOR GLASS AND REGULATOR
SETTING AFTER INSTALLATION
Setting of limit switch
If any of the following work has been done, set the limit switch (integrated in the motor).
 Removal and installation of regulator.
 Removal and installation of motor from regulator.
Resetting
After installing each component to vehicle, follow the steps below.
1. Raise glass to the top dead center.
2. While pressing and holding reset switch, lower glass to the bottom
dead center.
3. Release reset switch, and check reset switch returns to the
original position, and then raise the glass to the top dead center.
CAUTION:
Do not operate the glass automatically to raise the glass to
Do not operate the door switch is turning on.
FITTING INSPECTION
 Check that glass is securely fit into glass run groove.
 Lower glass slightly [approx. 10 to 20 mm (0.39 to 0.79 in)] and check that clearance to sash is parallel.
If the clearance between glass and sash is not parallel, loosen regulator mounting bolts, guide rail mounting
bolts, and glass and guide rail mounting bolts to correct the glass position.
PIIA2164EFRONT DOOR GLASS AND REGULATOR
Resetting
dead center.
CAUTION:
FITTING INSPECTION
Resetting
dead center.
CAUTION:
FITTING INSPECTION
Resetting
dead center.
CAUTION:
FITTING INSPECTION
PIIA2164E
Siqcology
Sep 18, 2019 01:45 PM
_koubie_
Sep 20, 2015 06:34 PM
