Reintroducing Myself
Old Dec 1, 2006 | 12:56 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Default Robert_K Build Page
Updated: Click Me!!!
Forum Name: Robert_K
Vehicle: 2003 Nissan 350Z Touring 6sp
Engine Code: VQ35DE
ECU: TurboXS UTEC
Updated: 06-Jan-08
Engine:
- JWT 530BB Twin Turbo System (April '08!)
- AutoTechnic CF Shroud
- JWT PopCharger w/ Heatshield
- ARC Oil Catch Can w/ AAM Brace
- InGalls Stiffy Engine Torque Damper
- MotorDyne 5/16" Spacer w/ ISO Gasket (Current)
-- Cosworth Intake Manifold (Waiting on delivery to replace spacer)
- UR Underdrive Crank Pulley
- Gates Belts
- DeatschWerks 600cc Injectors
- NGK Iridium IX 1-Step Colder Spark Plugs
- Braille 15lb. CF Battery
- Braille Battery Mount
- CF Battery & Brake Fluid Covers
- Stillen Custom CF Engine Cover
- Stillen Oil Cooler
- Walbro 255lph Fuel Pump
- APS 2.5" Test Pipes
- Stillen TD Cat-back ZR Single Tips
- TurboXS UTEC
- TurboXS Tuner Wideband w/ Bosch O2 Sensor
- TurboXS DTEC Map Sensor
- Perrin Boost Solenoid
- Nismo Oil Cap
- Project Kics Magnetic Oil Plug
Transmission:
- JWT Clutch
- JWT Flywheel
- AP Stainless Steel Clutch Line
Suspension & Brakes:
- Aerosync CF Strut Tower Brace
- GTSpec Front Fender Reinforcement Braces
- GTSpec 4-Point Mid Chassis Reinforcement Brace
- GTSpec Rear Tie Brace
- GTSpec Rear Lateral Arm
- Hotchkis Stage 1 TVS Kit (Lowering Springs, F&R Adjustable Sway Bars, Bushings, and Brackets)
- StopTech Stage 2 OEM Brake Kit (StopTech Slotted Rotors, Axxis Ulitmates Pads, StopTech Stainless Steel Lines, Motul RBF600 Fluid)
- StopTech 14" 4-pot front, 13" 2-pot rear Big Brake Kit (April '08)
- EBC Yellow Stuff Race Pads (Race Use Only)
Wheels/Tires:
- 19x9.5(F) 19x11(R) Work Meister S1 3-Peice
- Yokohama Advan Sport 255/35-19(F)285/35-19(R)
- Project Kics R40 Racing Lugs w/ Locks
Exterior:
- Intense Power Front Lip
- Stillen Street Scene Grille (Painted Flat Black)
- JDM Nissan Smoked Markers
- Nismo Horns
- 6000k D2R Bulbs
- White Wedge-Type Parking LEDs
- AUT Carbon Fiber Z Emblem Filler
- 15% Tint
- Varis CF B-Pillars
- Perrin Shorty Antenna
- Removed Rear Wiper
- Fairlady Z Third Brake Light
- JDM Fairlady Z Emblem
- White Wedge License Plate LEDs
- White Reverse LEDs
Interior:
- Rearview Radar Detector Mount
- Bel RX65 Laser/ Radar Detector
- Dual Pod A-Pillar
- Defi-Link Control Unit
- Defi 60mm BF Series Gauges (Imperial Units & White)
-- Boost Gauge
-- Fuel Pressure Gauge
- Defi-Link Display
-- Defi Oil Temp Sensor
-- Defi Water Temp Sensor
- Defi-Link Indicator II
- Nismo Ti Shift ****
- TurboXS UTEC Map Switch
- Nissan Z Seatback Organizer
- Nissan Z Trunk Mat
- Nissan Cargo Net
Audio:
- XM Roady Radio
Dynojet 248/224 AWD Dyno: 256.32whp, 240.61wtq* New numbers coming April '08!
1/4 Mile: Unknown since new mods.
More Info: Robert_K's 350Z
Car Domain: Click Me!!!
Pictures: Waiting to get more up-to-date pictures. Here is what I had before I left for Kuwait.
Dyno Video:
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i107.photobucket.com/player.swf?file=http://vid107.photobucket.com/albums/m317/airforcefd/StillenTDExhaustwAPSTP.flv"></embed>
Goals/ Next Mods:
- CF Hood
- Coilovers
- Light weight Track Use Wheels
- R-Compound Tires
Old Dec 1, 2006 | 12:59 PM
DavesZ#3's Avatar
DavesZ#3
Damn, all those mods and you still have the stock wheels...
Old Dec 1, 2006 | 01:07 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Yeap... I don't have $2500-$3500 cash for new wheels and tires. I also refuse to something cheaper. I'm quite happy with the stock 18's. Rather invest in more safe & reliable power than $3k worth of bling.
Old Dec 1, 2006 | 01:26 PM
shezzzhot's Avatar
shezzzhot
Abzolutely Zexy
Nice!! Welcome back!
Old Dec 1, 2006 | 03:25 PM
Kolia's Avatar
Kolia
Damn, all those mods and you still don't have the power of a revup ...
Hehe, just messing with ya! Nice Z !
Old Dec 1, 2006 | 05:04 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Acually Revup Stock Zs are dynoing at 245-250ish whp & 225-230ish wtq. So once I'm in front I'll stay there.
Old Dec 1, 2006 | 05:25 PM
Kolia's Avatar
Kolia
Damn you !!!
Old Dec 1, 2006 | 05:31 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Damn you !!!
Think of the thousands spent for a new revup w/ less tq vs the non-revup w/ more tq and investing $800 to produce equal hp and even more tq.
Old Dec 1, 2006 | 05:38 PM
taurran's Avatar
taurran
Wheres the ****?
Old Dec 1, 2006 | 05:55 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
On your hood???
Old Dec 1, 2006 | 06:13 PM
Tenac1ousZ's Avatar
Tenac1ousZ
Engine Code: VQ35DE
ECU: TurboXS UTEC
Engine:
- JWT PopCharger
- Gates Belts
- TurboXS UTEC
- Royal Purple 10W30 Engine Oil
- Royal Puple MaxGear 80W-90 Diff Oil
- Redline Oil MTL/ ML-90 Mixed Tranny Oil
- StopTech Stage 2 OEM Brake Kit (Slotted Rotors)
Wheels/Tires:
- 225/45F & 245/45R BFG KDW
Exterior:
- Grille-Tech Black Race Grille
- Nismo Horns
- 6000k D2R Bulbs
Interior:
- Custom Mounted TurboXS UTEC Map Switch
ICE:
- XM Roady Radio
HP: 249.93 TQ: 240.25 1/4 Mile: 15.0 @ 94 Bandimere 5800' before UTEC
Welcome to the forum Robert! Be sure to use the "search" function in the future to avoid reposting to the same topic
Old Dec 1, 2006 | 06:16 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Old Dec 1, 2006 | 06:33 PM
insomniaxvi's Avatar
insomniaxvi
Welcome back man! That's a sick ride...
I may consider your philosophy on the stock wheels and just keep my 18's for now.
Anyhow, good to hear from ya!
Old Dec 1, 2006 | 06:42 PM
03performz's Avatar
03performz
$3000 for rims is retarded. It's a Nissan for God's sake . I put my $$$ into performance as well. All rims and no go makes you a ricer. I'm not putting rims on unless I go FI and I'm not dumb enough to do that either. I'm going to move up instead.
FWIW, Motordyne 5/16 w/ISO, JWT pop, KJR pulley, Stillen sways, NISMO exhaust.
Old Dec 1, 2006 | 06:47 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I don't think its "retarded" whether or not its a Nissan. I want wheels I'm just not going to put them on credit. My mods come by cash. So when I have some extra cash I order my mods. I don't have $3k cash so no wheels. Yet! :Thumbup2:
Old Dec 1, 2006 | 07:10 PM
03performz's Avatar
03performz
You still need headers and cams first poser. J/K.
I just don't see how >10% the cost of a vehicle should go into rims alone. Not just Nissan..anything, and I'm also not putting $3000 in rims and an extra $1200 in tires on a car that has permanent tire feathering issues.
Old Dec 1, 2006 | 07:13 PM
Kolia's Avatar
Kolia
Aha !
I might have "just a revup" engine, but my tires last !
Old Dec 1, 2006 | 07:26 PM
bofa's Avatar
bofa
Nice. You still running the stock exhaust?
Old Dec 1, 2006 | 07:34 PM
dbasal's Avatar
dbasal
Well. At least he's not burning through oil.
Old Dec 1, 2006 | 10:20 PM
03performz's Avatar
03performz
Aha !
Bastard!!(I'm sensitive about that) Well I'm sueing Nissan because of that. Seems to be that any auto manufacturer that builds a car w/ a defect that can't be fixed should either buy the car back or pay till the customer is satisfied. I might be unloading my mods and the Z soon.
