burning oil?
Old Dec 11, 2006 | 09:45 AM
dmroberson's Avatar
dmroberson
oh... I was under the impression that to break in a new engine, you couldn't floor it yet, or drive it harshly in any way, until the break in period was over. Guess I was wrong. I'll try to remember that next time. Sorry for being such a noob.
Old Dec 11, 2006 | 10:11 AM
Chochi's Avatar
Chochi
Originally Posted by CaliTouring
mine is an 06 and at 3200 miles i went for an oil change and i was missing a quart and a half of oil.
I was missing a quart and a half before my 3500 mile service, then this last week, I had it missing again, not 1 week before my 7000 mile service was scheduled to be performed.
The dealer KEEPS stating that there are no know issues with this, and they have never heard any complaints. Finding it hard to believe. 90% of my driving is on the HWY.
MAKE SURE YOU CHANGE YOUR OIL RIGHT AT THE SCHEDULED CHANGE... I went 20 miles over the 7000, and it started sounding like tin cans again. I now carry a quart in the trunk of the car at all times.
Old Dec 11, 2006 | 10:35 AM
Sean_350z's Avatar
Sean_350z
Not a "noob" way of thinking at all. The vast majority of people think this is the proper break-in and the owner's manual/dealer will likely tell you same thing.
Old Dec 11, 2006 | 10:51 AM
marathonhunter's Avatar
marathonhunter
Default 2006.5 350z
Anyone notice the new 2006.5 350z at the dealer? I talked to a sale rep. and he said the only thing they changed in the .5 was the airbag seatbelt sensor. Something about the airbag sensor turning off when no one is sitting in the passenger side.
Now why would they make a .5 just for that change? sounds fishy to me.
fyi, my nov05 2006 350z is going through a oil consumption test.
I don't mind adding a quart of oil every 1k...thats actually normal for a high performance car. However, when I hear other 2006 owners who do not have to add oil...I get redlights flashing. Maybe I'm jealous.
Old Dec 11, 2006 | 10:56 AM
CaliTouring's Avatar
CaliTouring
Damn you dealer sucks *****. I told the service manager about it and he said that there is no way to fix this problem so he said just keep bringing it in for a consumption test everytime its missing oil and after the third test if its still burning oil this is his quote, "I'll just drop a new engine in there for you. I mean its bad for Nissan but its more work for me."
Old Dec 11, 2006 | 11:20 AM
dbasal's Avatar
dbasal
But that was not caused by your going over the mark. It was an accumulation of oil loss over the time since your last oil change. These things suck it down like they have stock in the stuff!
Old Dec 11, 2006 | 11:24 AM
dbasal's Avatar
dbasal
I had not heard of that although there was a post about the 2006.5 user manual at one point. It is very odd to make a change just for that.
I would disagree with having to add oil just because it is a high performance vehicle. Unless you have some major mods, you should not be burning any oil at all. I am babying the car through these tests and still losing 1/2 qt in 500 miles and around 2/3 qt for 1000 miles. I find that very excessive considering I am stock with synthetic oil. I think I will revert to conventional for the next tests to see what happens.
Old Dec 11, 2006 | 12:13 PM
MyZFiona's Avatar
MyZFiona
I spoke with a buddy of mine whos' a service manager at nissan.. and he said that a hand full of the 06rev-ups "including mine" tends to burn oil, and the best way to figure out if you are burning oil is to do the dealer recommended "oil consumption test" which i am going through right now... just change your oil with the factory breakin oil or let the dealer do it, and just check your oil level da 1st 500 miles after changing your oil, and then the next 250 miles, and if your car has no reading on the dpstk between those 750 miles.. then you have a problem and the dealer buys u a new motor... i've been riding my car pretty good for being brand new and so far with the consumption test, the oil level is still looking good after da 1st 500miles.. the car will burn oil to correctly lube the seals.. but if all fails after the consumption test, then u need a new motor...
Old Dec 11, 2006 | 12:36 PM
Sean_350z's Avatar
Sean_350z
Actually that's not entirely true although it shouldn't burn at the rate I've read here. A "loose" ring package on a engine will let some oil by in the search for lower frictional losses. For years the 5.0 roller cammed Mustangs were known for eating a qt. every oil change from day one. You can tear one down at 120k+ miles and still find crosshatch in the bores though too.
There's obviously another issue at hand here however as the consumption I'm reading about here is ridiculous.
Old Dec 11, 2006 | 02:36 PM
dbasal's Avatar
dbasal
Are you saying that you do not believe the rev-up engines burn oil?
Old Dec 11, 2006 | 04:31 PM
Sean_350z's Avatar
Sean_350z
No, I'm saying that it's not entirely true that a performance vehicle won't burn ANY oil. A looser ring pack will allow some oil past in the process of trying to reduce frictional losses. The post above stated there should be no burning at all.
Old Dec 11, 2006 | 05:47 PM
dbasal's Avatar
dbasal
OK.Thanks. I think my head is all screwed up now with all this discussion and my frustration over the issue.
Old Dec 12, 2006 | 04:48 AM
Jonathan Allyn's Avatar
Jonathan Allyn
I had a new longblock put in my 03' back in January with no questions asked after my OC test. If your not getting what you want, check out another dealership.
Sean_350z's Avatar
Sean_350z
I don't blame you for being frustrated. A qt over an entire oil change period would be one thing but this is definitely excessive.
Old Dec 12, 2006 | 03:48 PM
wckdclw's Avatar
wckdclw
i just got my oil change done last week and put regular oil in it...not synthetic, isnt that what the manual says...."dino oil" or even a thread on here said the same thing....synthetic burns worse than conventional?
Old Dec 12, 2006 | 04:06 PM
Reality350's Avatar
Reality350
I remember reading somewhere that you should not be using synthetic oils to early on in your engines life, something about the rings not seating properly? (someone chime in here if I am wrong)
I am also a firm believer in checking your oil every 2nd fill up.
But I digress,
Your oil consumption problem is unacceptable and I hope you find a resolution to your Z's issue.
R350z
Old Dec 12, 2006 | 04:13 PM
Swiffer's Avatar
Swiffer
Originally Posted by rockinbboy
He's getting rid of whatever metal shavings in the engine from break-in. Its an okay thing to do.
Well, how do you know you are burning oil? Do you smell it? Do you see it "L" on your dipstick? Did you check your dipstick level when you got your car back from its oil change initially? Are you following the break-in procedures?
I have an 06 Rev-up and not encountered any oil issues. Had the car since Feb 06. Over 8k miles now.
Same here. Had the car since March, 9000+ miles, no oil consumption.
Old Dec 12, 2006 | 07:48 PM
  #38
dbasal's Avatar
dbasal
But I digress,
R350z
I've heard the same thing, but have found nothing further on if that is fact or fiction. I changed mine at 7000 when I noticed that the oil level did not read on the dipstick. My first oil change (done at around 4000 using conventional) was done using synthetic after seeing what it did with conventional.
I've gotten in the habit now of checking the oil every couple hundred miles.
I take it back in tomorrow morning. I have gone 1000 miles since my last visit. I'm sure they will be thrilled to see me since I have been driving Nissan Cusumer Affairs crazy with my phone calls and they in turn call the dealer. Eventually, maybe I will wear them down.
Old Dec 12, 2006 | 08:21 PM
  #39
Ztalker's Avatar
Ztalker
i switched back to dino oil 5/30 last oil change. i've noticed my 03 engine uses about 1/2 qt. of synthetic between oil changes. i don't need to check my oil level until the next oil change with dino oil.
Old Dec 13, 2006 | 06:17 AM
  #40
merlin3's Avatar
merlin3
switching to dino oil may temporarily hide a problem but after an engine has 2k plus miles I would run synthetic as it keeps all the seals in gaskets in better condition. And I agree with sean with the breakin. I just got done rebuilding my vg30dett in my 300zx and I put about 2500 miles on it in just a couple weeks, drove it fairly hard to get the rings to seat and it runs perfect. Actually took it on a 2000 mile roadtrip with only a few hundred miles on the engine. Getting ready to pick up a 350z now.
