Determining factory trim package from VIN or other serial numbers?
Hello,
First post. I'm close to owning my first Z and I've been scouring various forums and FAQ's trying to figure out if one can determine the trim package of a 350Z based on the VIN or other info on the door sticker.
I've found a used 350Z I may purchase, but some of the options do not appear to correspond with the stated trim package.
I called the VIN into Nissan USA's 800 number and got the in-service date, but they said they can't determine trim package based on VIN.
I also located a website that is helpful at deconstructing the Nissan VIN, but also does not get down to the level of trim package.
http://www.etraxx.com/350z_vin.php
I know on some other vehicles there are codes on the door sticker which indicate trim packages. But I don't know what to look for on a Nissan. Any assistance would be appreciated.
Thanks for the correction on my terms. Too bad it isn't easier to determine model info.
Digging around in the archives, I found a very helpful thread:
How to tell if a Z has LSD from it's options?
It's easy to spot Brembo rotors but not so easy to spot LSD. If the cruise control => LSD rule is correct, that should be almost as good as knowing the model.
There is a metal plate attached to the left side of the firewall (in front of the battery compartment) that contains some of the information you seek. Unfortunately, I've never seen any documentation on how to decode it. Even the FSM doesn't include a key. Apparently, it's only intended for production use, not for dealers, etc.
What was an option in one year may be standard in another year (i.e. TPMS) so sometimes it's hard to say that a particular car is one trim or another just by looking a feature differences without knowing the year.
I thought I had found a steal on an '06 Touring package with 9K at a Toyota dealer for $25K. The dealer had it listed as a Base model but showed it as having leather seats and cruise so I figured it was probably actually a Touring not a Base.
The PO had even installed Bose speaker covers so it looked like a Touring. However, I noticed the leather seats were not heated and there was no cruise control. So I said no thanks.
Non-Nissan dealers seem to have a hard time figuring out exactly what they are selling. If you don't know better and they don't either - you can get screwed or get a great deal. I recall somebody here buying a Track that was listed as a Base model and he paid significantly less than what a track should have gone for.
I've found a new candidate. The (non-Nissan) Dealer has it listed as a 2003 Track model. It's a few hundred miles away so I can't just pop over and look at it.
There is only one photo on the dealer website and it isn't very good. However, those do appear to be stock Brembo calipers peeking out from the front wheels. It is however listed as having tan leather seats which makes me wonder if it is truly a Track model.
Here's the only photo I have (click to enlarge):
Would any of the Z experts here care to speculate as to the model based on the photo?
I've called both Nissan USA and a Nissan dealer and they said they don't have access to any info other than in-service date and paint code.
The easy way to tell what model it is is to find the cars weight
3,188 lb (1,446 kg) (Base)
3,197 lb (1,450 kg) (Enth)
3,217 lb (1,459 kg) (Perf)
3,247 lb (1,473 kg) (Tour)
3,225 lb (1,463 kg) (Track)
You should be able to find this somewhere on the car.
I doubt he can tell you, that was posted back in 2006!
