What is the max PSI of tires?
Old Mar 24, 2003 | 11:35 AM
cluofi's Avatar
cluofi
Default What is the max PSI of tires?
I went autocrossing last weekend. And i just couldnt seem to have enough air in the tires. I had them at 45 psi cold front and rear. They ended up climbing to 49 psi hot. The bridgestones say 51 psi max, is that hot or cold?
Old Mar 24, 2003 | 05:09 PM
ares's Avatar
ares
Veteran
uhhh dude, what the hell are you talkin about????!!!!!
first off, recomended is 35cold, and I think the concencus is that its a bit high, I run 32cold, 35-36 hot.
HOWEVER, why would you EVER pump up your tires? some sort of trick in an autocross that you raise your tire pressure? you know you get more traction with less pressure right??? never heard of anyone increasing pressure for a race....
EDIT, I was running 29 hot when I was drag racing, and I wish I had taken it down to like 24 in the back.
Old Mar 24, 2003 | 06:48 PM
cluofi's Avatar
cluofi
if you run anything below 40 you roll your tires over on their side and chew up the tread very quickly, and it much more responsive in the quick turns.
Old Mar 24, 2003 | 07:02 PM
ares's Avatar
ares
Veteran
hmmm never had that problem with the low profile tires... guess I just havent pushed it hard enough yet.
Old Mar 25, 2003 | 03:26 AM
cluofi's Avatar
cluofi
It didnt help that it was in a parking lot that wasnt smooth at all. On one run they showed wear on half of the side wall at 49 psi, the rear tires were the only ones with problems fronts were fine.
So does anyone know if the max pressure is cold or hot?
350Z_Al
Oct 29, 2020 07:44 PM
