Well I'm a huge moron
Old Dec 13, 2006 | 01:49 PM
2005daytonaZ's Avatar
2005daytonaZ
My problem it not being able to find 4 from 6...mother ***** always wants to hit the gate right in the middle and wont go in.
Old Dec 13, 2006 | 02:48 PM
stan's Avatar
stan
Originally Posted by insomniaxvi
I'm a stick noob; how would you rev-match in that situation? Clutch in, rev to 5k rpm, shift to 3rd, clutch out?
yep. 70mph in 6th-->clutch in-->blip to slightly above 5 bucks-->stick to 3rd--->drop clutch just as revs drop down to 5k. if you do it fast enough you should rev almost exactly to 5k and drop right on it. you'll know you rev matched it by the fact that the car doesnt lurch when you drop the clutch.
anyone else feel free to correct me. i'm still learning but this is what works for me. i checked today and 70mph in 3rd gear is pretty much dead on the line 5k rpms
Old Dec 13, 2006 | 03:05 PM
hardrock905's Avatar
hardrock905
Originally Posted by HDPD350Z
Incorrect. It's just as easy to overrev with the AT while downshifting.
Yeah, but you're only going to drop down one gear, no worries about
5th to 2nd.
But....with the AT......when you F up, you can't just push in the clutch either.
Old Dec 13, 2006 | 03:07 PM
charlie_rdstr_Z's Avatar
charlie_rdstr_Z
Originally Posted by jsupetran
Honestly it was a great day at work (work at a nonprofit), felt great, listening to linkin park. Its one of those days where you have to open up the throttle and become reminded that you are driving a sports car. What are the safe shifting points to drop to 3rd gear? Is 70 too much?
That's your problem right there.
Old Dec 13, 2006 | 04:00 PM
HighwaySpeed's Avatar
HighwaySpeed
Question
Explain
Old Dec 13, 2006 | 05:28 PM
Zmazing03's Avatar
Zmazing03
No worries. I was doing about 85 once, and downshifted into 3rd from 6th. I let the clutch out WAY to fast, lousy revmatch, and the rear end locked up for a second. Scary when it happens, but its been fine since.
To the OP, I am surprised that even let you go into 3rd at that speed. You didn't have to force it at all?
Old Dec 13, 2006 | 05:49 PM
DIGItonium's Avatar
DIGItonium
I was busy getting on the freeway when I did a 3rd->2nd mishift at WOT. The needle was bouncing past 8k for a couple of seconds. It's like an earthquake. Thankfully, the motor survived?! O_o
Old Dec 13, 2006 | 06:00 PM
UGOTZ'D's Avatar
UGOTZ'D
Originally Posted by dutchboy350Z
3rd gear tops out around 88 mph on non revup Zs.
I know it all too well!
Old Dec 13, 2006 | 06:31 PM
doskiez's Avatar
doskiez
Originally Posted by roast
The rev-limiter does absolute NOTHING about a mis-shift.
Down shifting to too low of a gear is a good way to rape your motor.
+2 Missed shift in e36 325is racecar floated the valves. None bent no malfunctions, but when i tore into the engine you could see where the contact was made. But new built motor can rev to 7600 so
Old Dec 13, 2006 | 11:22 PM
jsupetran's Avatar
jsupetran
Hey come on, Linkin Park is good band. I gotta support my people (Asian band members are few and far between in the mainstream music scene).
ablaine
Nov 29, 2016 10:13 AM
PureR3d
Sep 10, 2015 06:23 PM
ares
Nov 3, 2002 05:26 PM
droideka
Oct 22, 2002 07:35 AM
