my dipstick - how does yours size up?
Old Dec 16, 2006 | 07:04 AM
cowzrul's Avatar
cowzrul
Default my dipstick - how does yours size up?
With all the Rev-up 6mt oil usage concerns, I have been checking mine twice a week. I now have 1516 miles on the odometer and here is a pic of my dipstick with readings. At 1500 miles I took it into the dealership and they said this reading was only about 2 oz and doesn't even need any oil. My real question is when you are on L is that a quart low? How much is it between the L and the H?
Old Dec 16, 2006 | 07:50 AM
dbasal's Avatar
dbasal
It is probably still too early to determine if you have a problem. During the early stages you will have some consumption as the engine is broken in (or at least that is the consesus). Most people are noticing the problems first between 5000 and 7000 miles. That comes after the first oil change. I only noticed mine at 7000 because I read about it here. My first check came at 3000 miles after my first oil change and there was only a dot on the bottom of the dipstick. Needless to say, I check regularly now.
Old Dec 16, 2006 | 07:53 AM
06r33z's Avatar
06r33z
thats the sam reading i always get as well. i asked the dealer they said thats normal but what do they know
Old Dec 16, 2006 | 08:03 AM
Your oil level is fine. I think you are paranoid.
Old Dec 16, 2006 | 08:13 AM
azula's Avatar
azula
there's a lot of ways the mind can wonder when reading the title of this post.....lol. mines is the biggest!!!
Old Dec 16, 2006 | 08:17 AM
LV350's Avatar
LV350
Good question. Anyone know the proper quart readings on the dip stick markings
Old Dec 16, 2006 | 08:37 AM
cowzrul's Avatar
cowzrul
+1
It looks fine now, but that wasn't the jest of my post.
Old Dec 16, 2006 | 08:46 AM
rockinbboy's Avatar
rockinbboy
I have not had any oil issues. Just stick with the recommended oil grades, oil changes, break-in procedures, and you should be fine. That level looks fine.
Old Dec 16, 2006 | 08:48 AM
350zex's Avatar
350zex
Not to go way off topic. I'm in the process of an oil consumption test right now, and I've come to find out that the dip stick really reminds me of a crazy straw.
Anyone remember these things lol?
Old Dec 16, 2006 | 08:52 AM
roast's Avatar
roast
It reminds me of mickey mouse....
Old Dec 16, 2006 | 09:07 AM
cowzrul's Avatar
cowzrul
I remember the crazy straw.
Off topic in my own thread: I was talking to my dealership about oil they use in Nissans and was very surprised when he said the ONLY thing they use is Castrol GTX 5w30. Everything in the shop gets that unless a customer brings it in themselves.
Old Dec 16, 2006 | 11:18 AM
LV350's Avatar
LV350
^^ I'm sure that changes from dealer to dealer... But I do my own now, I just don't trust them anymore.
Old Dec 16, 2006 | 11:26 AM
dbasal's Avatar
dbasal
+1
If you're at the L, that means you have lost 1 qt. For now, it appears you are ok, but I would closely watch it. If you are at the L at 3000 miles, there would be reason for concern unless you always run it hard.
Old Dec 16, 2006 | 12:47 PM
cowzrul's Avatar
cowzrul
That confirms what the dealer said, thanks.
Is there any other way?
Old Dec 16, 2006 | 03:45 PM
dbasal's Avatar
dbasal
Well, there is some debate on how you break it in. There is a lot of good info on this alternative to the manual method. Some people swear by the Mototune method:
http://www.mototuneusa.com/break_in_secrets.htm
Personally, I just think that the Rev-Up is defective. To me, this is the tire feathering issue for the 06. This is why that even when Nissan replaces the engine, the same problems seems to persist. Hopefully I am wrong, but from everything I have read, I do not believe I am. It would really help if Nissan would come forward and let us know what the problem is.
Old Dec 17, 2006 | 12:31 PM
NVS_350Z's Avatar
NVS_350Z
From H to L it usually means you will need 1 qt of oil. Goes for most cars out there.
Old Dec 17, 2006 | 05:41 PM
Hashiriya's Avatar
Hashiriya
I wouldnt worry about it. Your oil level looks pretty good. Just keep an eye on it. You have a powertrain warrenty, and if you notice it getting worse and worse. Take it in. I'd just enjoy the car!
Old Dec 17, 2006 | 06:22 PM
On Nightfall's Avatar
On Nightfall
Dude why in the hell are you worrying? Your oil mark is closer to the H than the L, the manual states that the normal mark is the center between the H and L.
Old Dec 17, 2006 | 08:37 PM
captj3's Avatar
captj3
I have to agree with everything that is said above. There is nothing wrong with your oil level. To quote the dealer it's normal.
Old Dec 17, 2006 | 09:30 PM
bhendjol's Avatar
bhendjol
achoooooo
Lucky I didn't get Mt.
