AC Freaking Out?!?!
Old Dec 19, 2006 | 11:03 AM
RiotWithin's Avatar
RiotWithin
Default AC Freaking Out?!?!
It's wierd I've got an 05', to save on gas I don't use the AC. Every now and then the AC turns on, full blast most of the time. I have to turn it on then back off to turn it off. Is this an issue or normal?
Old Dec 19, 2006 | 11:06 AM
bailey bill's Avatar
bailey bill
Don't use the "auto" setting.
bill
Old Dec 19, 2006 | 11:15 AM
RiotWithin's Avatar
RiotWithin
bill
Like I said I don't use my AC, it is always on the off position...
Old Dec 19, 2006 | 11:32 AM
roast's Avatar
roast
That's strange. Sounds like an issue to me. It should be covered under warranty.
I find it annoying how the ac kicks on every time you want the fan on, but that's a normal "problem".
Old Dec 19, 2006 | 11:40 AM
Sean's Avatar
Sean
it's the defroster part kicking the AC on
Old Dec 19, 2006 | 03:38 PM
zedated's Avatar
zedated
I think the AC mode **** is defective. I have seen this problem also, when the **** is turned to the OFF position. I found that the AC starts randomly, causing the fan to run full blast. If I turn the **** gently counterclockwise (i.e. more OFF), the system turns off. Note: while the **** does *not* appear to move, the system does turn off. I think either the electronics are overly sensitive or there is a mechanical defect in **** itself.
Old Dec 20, 2006 | 01:44 PM
Azeotrope's Avatar
Azeotrope
My car does exactly the same thing as zdated's. Once in a while the fan turns on full-blast. I very rarely use the AC.
Old Dec 20, 2006 | 03:01 PM
Nforce1's Avatar
Nforce1
This has happend to me once... I had no idea what caused it.
Old Dec 20, 2006 | 05:31 PM
Aeleven's Avatar
Aeleven
Me Three.
Old Dec 21, 2006 | 07:12 AM
Ztalker's Avatar
Ztalker
mine only turns on when its on auto every time i crank the engine. If i hit the a/c off button, the a/c stays off. i cycle the a/c once in a while even in the winter time to keep the seals lubricated.
Old Dec 21, 2006 | 10:52 AM
Kurru's Avatar
Kurru
if u pull apart the part where the ***** are, try and seeing it that white cable thats connected is damaged or not pluged in all the way. cause when that is unplugged ur a\c goes on full blast
Old Dec 21, 2006 | 02:16 PM
jc0019's Avatar
jc0019
I have the same problem 2 months ago. The AC will just turn on full blast by itself when it is at the off position. I didn't care about it too much until last month when all my gauges, radio and AC went dead. The light on the gauges are on, but they are not functional. I took it to the dealership right away and they told me there were a short in the wirings and this might be related to the AC problem too. It took them a week to order and install the new wiring harness, but I don't have the AC problem anymore.
I will suggest you to bring your car back to the dealership and hopefully it is still under warranty.
Old Dec 22, 2006 | 08:15 AM
Kurru's Avatar
Kurru
yea it's that white wire then... well it maybe. pull ur lower dash apart and just check it out real fast.
AfroCreame
Cleaning & Detailing
Jun 15, 2006 03:40 PM
digerydingo
May 14, 2003 06:27 AM
polar
May 12, 2003 04:34 PM
350ondubZ
May 12, 2003 09:16 AM
SoCalKid86
Nov 8, 2002 03:42 AM
