empty gas tank fills to 15 gallons?
Old Jan 21, 2007 | 08:51 AM
Ztalker's Avatar
Ztalker
^yeah, i only fill to half tank considering gasoline weights 7pounds /gallon.
Old Jan 21, 2007 | 09:05 AM
CNOTE's Avatar
CNOTE
Originally Posted by icedout589
haha I drove on the "---" flashing for an entire day once.....probably about 35 miles. Went to fill it up and got 17.3 gallons worth
thats nothing... like I said when my says "---" it still has about 4 gallons left. I've driven to Boston and back which is about 45 miles on way...and then some...
Old Jan 21, 2007 | 09:06 AM
Kevins350z's Avatar
Kevins350z
i think it's normal. i've never filled up to the gallons they say it should on all of my previous cars.
Old Jan 21, 2007 | 09:09 AM
There is a service bullitin for early gas pump shut-off. If you are concerned, have the service completed. Of course you will pay for it.
Or just live with the fact that the fuel gage is inaccurate.
Old Jan 21, 2007 | 09:15 AM
roast's Avatar
roast
350z's are "notorious" for fuel related problems.
faulty sending unit, faulty shutter valve, fuel filler hose recall... etc..
Old Jan 21, 2007 | 09:20 AM
Ztalker's Avatar
Ztalker
^ yeah, nissan replaced the fuel sending unit/sensor in my 05Armada(always reading half tank even after fillups).
Old Jan 21, 2007 | 09:31 AM
Vegas_Speedster's Avatar
Vegas_Speedster
I always try to use Chevron gas, the few times that I had to use Arco I had problems getting gas in the car. One time I couldnt get the pump to work at all; tried two more pumps with the same problem. Drove to the 76 about a mile up the road and filled the tank with no problems. Maybe there is different valve design at the pumps? I dont know. I never have problems at Chevron though.
Old Jan 21, 2007 | 10:40 AM
derekinthez's Avatar
derekinthez
Originally Posted by CNOTE
I have a 2003 and the I still drive long after it's supposedly "empty".. there is still about 4 gallons left in the tank after it says empty...
curious to why some people don't go below a 1/4 of a tank, and always fill up then...
keeps any possible condensation out of tank, does not allow sediments to block tank fuel filter etc. .
Old Jan 21, 2007 | 11:15 AM
drivenCSZ's Avatar
drivenCSZ
i never fill mine up much more than half way for fear ill start crying when i see how much a full tank cost me
Old Jan 21, 2007 | 11:18 AM
Reyes_USN's Avatar
Reyes_USN
mines like that, I cant put in more than 15, usual is 11-13 and the dte is something like 40-ish. Yeah I always wondered about that
Old Jan 21, 2007 | 11:26 AM
Z_rican's Avatar
Z_rican
Originally Posted by chuquison
yeah i get about 13.5 i have never gotten 15 gallons and the funny thing is when I fill up all the way my gauge reads i have a 1/8 left to full anyone have this problem?
I have the same damn problem.
Old Jan 21, 2007 | 12:35 PM
davidz33's Avatar
davidz33
06 base
When my dte flashes, it takes about 17 gal.
Old Jan 21, 2007 | 07:24 PM
Zmazing03's Avatar
Zmazing03
The most I have ever been able to cram in is 18.7 gallons, and that was after driving 25 miles or so AFTER it said 0 DTE.
Old Jan 21, 2007 | 07:47 PM
geomark's Avatar
geomark
there's a low gas light? I never went below a 1/4 tank.
Old Jan 21, 2007 | 08:12 PM
Bevo's Avatar
Bevo
ya me too, I fill it up around 1/4 left.
Old Jan 21, 2007 | 08:22 PM
jdo's Avatar
jdo
I don't think there's really a light. The info automatically goes to your miles range when it gets below a 30 mile range (like when the temp gets to the icy range) and blinks until you flip it off. Personally I've driven when it was blinking "---" just to see how far i could go for a while and then finally filled up only about 17 something gallons. Pretty much the same as a bunch of other posters. Its annoying though because after you fill up the gas gauge drops like mad until about a half tank (which I'm guess really means you have about 15 gallons left) so it makes u think ur getting no gas mileage.
Old Jan 21, 2007 | 09:12 PM
black06z's Avatar
black06z
yep. Ive had this problem before and just last night, my gauge said 1/8 in the tank, and I filled the tank until the pump shuts off, and went to reset the miles per tank stat, and the tank only read 3/4 full.
Old Jan 21, 2007 | 09:22 PM
  #38
_Donovan_'s Avatar
_Donovan_
I have a '03, when I get low it will only fill to half a tank. Also one time I was stuck on the PA turnpike and drove forever with gas light on. Didn't even register on the digital DTE. I didn't mean to. Just happened. somehow I made it to a gas station in some back woods area. Again, only filled to half a tank.
Old Jan 21, 2007 | 09:39 PM
  #39
joe645733's Avatar
joe645733
im pretty sure its cuz the gas level sensor or meter isnt too accurate.
ive hit 16 gallons and ive hit 18. my gas light goes on at 36 miles left to empty.
Old Jan 22, 2007 | 09:04 AM
  #40
ZBigDog's Avatar
ZBigDog
When running to empty keep in mind that fuel pumps are lubricated by the gas they sit in when your tank is not empty. Not that running your car empty will cause the fuel pump to expire, but it may cause excessive wear and tear in hotter weather when it is dry out.
Also for cold weather when the air is wet and dense it is recomended to stay at least above 1/4 tank to keep any condensation out of the tank.
The most I've ever filled in my 03 is 15.2 gallons or so, the least my DTE has ever gotten is in the 20's, not that I don't believe that their is 3-4 more gallons in their, I just don't want to run that risk of running out. How silly does a guy with a Z look on the side of the road. Is good to know now just in case.
