weigh of vq35de?
http://www.supraforums.com/forum/sho...d.php?t=413208
s2k can get that motor in there ,why not 350z?
Originally Posted by rAiN
just wanted to know weigh diffrences in vq35de and 2jz
i dont have numbers, but the 2jz is WAY heavier than the vq.
my buddy is putting a vq35de in his 240sx and the motor is almost the same as the sr20det was. that's very light for a 6cyl.
aluminum and 2000+ engineering ftw
Originally Posted by 350z_drifter
that not a 350z motor,that a maxima or altima,and it was told that that only weight the long block without accessory
My 03 maxima motor has the same cams, rods, pistons, heads and compression.as your 350z.
krismax if you read what i posted it said nothing about the cams, rods, pistons, heads and compression all it said is the motor they weight is not a 350z motor,if you look at the weight from a front wheel drive sr 20det motor swap and a rear drive sr 20det motor swap the weight is different about 50 lbs you should read thread before you try to prove something
I found this page:
http://forums.nicoclub.com/zerothread?id=146631&page=1
Scroll almost all the way down. Says about 313 lbs.
again that is the same picture from this thread that where this info.came from its not a 350z motor but it is a vq35de
i would say the 350z motor is +10- 20lbs more than the fwd 3.5 but otherwise they are almost identical
