Burnout in manual transmission
Old Apr 15, 2003 | 06:16 PM
Ricky's Avatar
Ricky
Default Burnout in manual transmission
Anyone sucessifully do one yet? I can't figure out how to with a manual.. someone told me hold clutch all the way, press gas, release clutch, then brake fast, and continue to gas. I'd like to get a few more opinions before I try anything. Any help?
Old Apr 15, 2003 | 07:05 PM
deviousZ's Avatar
deviousZ
I don't think you can do a burn out in the Z unless you disconnect something but I am not sure what it is... It's more than just tracktion controll. Why do you want to do a burn out??? Unless you are going to the track and using slicks???
elektrik_juggernaut's Avatar
elektrik_juggernaut
VDC off......don't even touch the brake pedal......hold the clutch in.....put it in 1st gear.....gas until RPM's reach 6000......release clutch.......that should do it
Old Apr 15, 2003 | 07:07 PM
Importlife.com's Avatar
Importlife.com
Have you tried this yourself? Only reason I ask is because I did try on my stock tires once and i had a lot of wheel hop.
Old Apr 15, 2003 | 07:26 PM
ares's Avatar
ares
Veteran
yeah it would seem on certain surfaces you can get a clean burn.not many tho
but as I saidto you before ricky, I think you need a line lock to do a full stopped burn out. fwd cars have the edge, as they can just apply the parking brake which stops the back tires. in RWD you have to stop the front tires somehow, only way I know is a line lock.
Old Apr 15, 2003 | 08:02 PM
FLY BY Z's Avatar
FLY BY Z
Nah you can use the brakes and work the clutch and gas at the same time. Here is me in my 01 Z28 before I put some mods on it. This is just with a Flowmaster muffler and some ET Streets. Sorry the quality is not so good.. By the way, this was a VERY humid summer night and the car was slow.
Potato Drags
By the way, do your business in second gear and not first.
Old Apr 15, 2003 | 08:10 PM
ares's Avatar
ares
Veteran
but to do that, your spinning the tires with brakes applied, Id only reccomend this if you dont like your brakes in addition to your tread.
Old Apr 15, 2003 | 08:22 PM
FLY BY Z's Avatar
FLY BY Z
It isn't like I was jamming the brakes down. Just a light hold on them to get the tires spinning and then you almost don't even have to use them. The tires will spin until they get hot enough to hook and that is all you need. We don't make enough power to do long nasty burnouts. And it isn't needed with any street tire. There are no adverse effects on the rear brakes by doing this once a month. Of course don't do this every stoplight or every day. Your tires will go way before brakes. Besides, your fronts will wear faster on the street anyways.
While your at it, never autocross because it wears parts out faster. Namely, brakes and tires.
Old Apr 15, 2003 | 08:38 PM
ares's Avatar
ares
Veteran
but theres useful wear and tear, and useless. useless would be a burnout on street tread.
Old Apr 15, 2003 | 10:06 PM
deviousZ's Avatar
deviousZ
was that first run a 13.01??? @108 that's nice time!! What happened on the second run???
Old Apr 16, 2003 | 12:36 AM
elektrik_juggernaut
Yes, i have done this.....a little too frequently.......i stand still for a few seconds with 'em spinnin......not good for launches, but a nice special effect
Old Apr 16, 2003 | 02:48 AM
j's350z's Avatar
j's350z
This has been posted a hundred times... To do a standing burnout, which means holding the brakes at the same time and staying in 1 place, you must pull the fuse which disables the brake lights.. The Z cuts power to the motor due to the drive by wire setup whenever the brakes and gas are hit at the same time.. And yes, I have done this. Also, the Z has plenty of power to do rolling or standing burnouts all the way through 2nd gear...
Old Apr 16, 2003 | 06:23 AM
ThreeFiftyZoom's Avatar
ThreeFiftyZoom
I dont see the point in doing a standing burnout unless you are trying to heat up some drag radials or slicks. Powerbraking just doesnt have the same "cool factor" as just dumping the clutch and heading down the street sideways. In a safe manner that is.
Old Apr 16, 2003 | 08:16 AM
Ricky's Avatar
Ricky
Which fuse is it exactly? Which row, ect ect.
Old Apr 16, 2003 | 08:49 AM
bnd350Z's Avatar
bnd350Z
who ran a 13.01? what mods? that's quite impressive.
Old Apr 16, 2003 | 09:04 AM
Heo2boy's Avatar
Heo2boy
Default 13.01
not to be rude, but read the thread. it was a camaro ss
Old Apr 16, 2003 | 09:33 AM
Ricky's Avatar
Ricky
yeah, hah.. if a Z ran a 13.01.. ***** in pants*
Old Apr 16, 2003 | 10:43 AM
Sudou's Avatar
Sudou
why couldn't it? MaxHax's automatic Z ran 13.41
Old Apr 16, 2003 | 08:21 PM
FLY BY Z's Avatar
FLY BY Z
MaxHax on nitrous.
the second run was faster. I don't understand what you mean. the car went a 12.76 the second go round and the fastest I went was a 12.69 @110 (in that car). by the way that was NOT an SS.
Old Apr 17, 2003 | 07:46 AM
Ricky's Avatar
Ricky
Yeah, MaxHax was spraying on that run, the fastest I seen without spraying, and minor mods was a 13.8.. must of been one hella good driver.
