Best RPMs to shift during normal driving?
Old Apr 11, 2007 | 12:35 PM
gsazabi's Avatar
gsazabi
I shift at 3,000-3,500RPM and try to stay above 2,500RPM all the time(cuz of JWT flywheel chatter..)
Old Apr 11, 2007 | 12:41 PM
alan86's Avatar
alan86
shift at whatever your heart tells you to shift at haha
Old Apr 11, 2007 | 12:45 PM
gothchick's Avatar
gothchick
I guess everyone's definition of "normal" driving is probably going to be a little different. That's why some people might burn through a clutch in a few months and have no idea why...
Attached Thumbnails Best RPMs to shift during normal driving?-407643-can_of_worms-1-.jpg
Old Apr 11, 2007 | 12:50 PM
JAB_06-350Z's Avatar
JAB_06-350Z
.........and as for the can of worms.....
Old Apr 11, 2007 | 12:58 PM
Scrivner's Avatar
Scrivner
Originally Posted by Z~Licious
Do you mind if I ask how much that was?
$28K + $600 destination & handling.
Invoice is listed at about $30K.
MSRP is listed at about $34K.
Old Apr 11, 2007 | 01:58 PM
Hey. Everyone shifts at different RPMs. Can you believe it!
Old Apr 11, 2007 | 01:59 PM
terrasmak's Avatar
I stay under 4 usually , but try to shift at no more than 3k
Old Apr 11, 2007 | 02:01 PM
Originally Posted by xNeo
I'm new to driving manual, I've been doing it for a week now! I shift around 3k, but I'm a fcking noob what do I know?
I have a stupid question, my father told me not to shift back into first unless I'm not moving at all, 100% complete stop... he said to keep her in second even at like 5pmh. I feel like it's going to die and I'm putting to much stress on it, but today I tried to put it back in first around 5pm and it wouldn't let me like it was locked.
Am I just retarded?
There are techniques that will allow you to shift into first gear while the car is moving. But for now, bring the car to a stop.
Old Apr 11, 2007 | 02:02 PM
Hashiriya's Avatar
Hashiriya
Starting out, maybe up to 3500rpm, and after maybe touch 3000rpm.
Old Apr 11, 2007 | 02:28 PM
RJ_KC's Avatar
RJ_KC
3k'ish when its cold, around 4k when im just crusing and whatever feels good when the car's warmed up and i have open road in front of me
Old Apr 11, 2007 | 02:42 PM
jonnylaw's Avatar
jonnylaw
3-4k
Old Apr 11, 2007 | 07:34 PM
Manjot's Avatar
Manjot
3.5-4k
Old Apr 11, 2007 | 09:56 PM
Playboy's Z's Avatar
Playboy's Z
7500 rpm ftw
Old Apr 11, 2007 | 09:58 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
3k-4k
Old Apr 12, 2007 | 01:27 AM
lilquazyvietboi's Avatar
lilquazyvietboi
Am I just retarded?
it isnt locked... u just have to push harder... and u dont want to use first gear. first gear is meant to be used to start a car from 0mph.. or when u are on a hill sliding backwards... 1st gear has alot of power that if u clutch out properly, can pull you out of a really steep hill w/o stalling.
one of the main reason why i DONT go into first gear is because it is harder to rev-match. and being in first gear is very sensitive... how much gas u are putting into the engine reflects greatly how fast you are going. trying cruising around in the parking lot with 1st gear... and then try 2nd gear. jerky in 1st gear huh?
almost always... stay in 2nd gear... even at 2mph... stay at 2nd gear. i know alot of people might disagree on me on this, but when i come to a stop sign, let go off brakes... if i am still moving forward (1mph-2mph), then i go off in 2nd gear also.
and to answer the question about best gear to shift... shifting early around 2k isnt going to help you save gas. here's an example, but u shouldnt be doing this. if you go into 5th gear.. and try to go off from a stop... then u slam on the gas. u'll be acceleration REALLY slow, yet ur MPG meter will say 6-8mpg. u are pouring in alot of gas just to get the engine enough power to move a big *** gear.
it is like comparing to cruising on a slight downhill and an slight uphill with same speed. you are using more gas trying to go uphill because of the gas you are giving to the engine and the stress that's build in the engine.
i found out the best way to save gas city is to use 1st gear and rev close to 4k rpm... shift to 2nd gear... rev to 3k,... shift to 3rd gear... and shift at 2.5 or less every so forth. this method yields me 18-20mpg. dont slam on the gas either to get up to 4krpm... that isnt gonna help ur gas mileage. go up moderately. of course, this depend on circumstances also... that's just a method close to what i use in the city 35mph speed limit. u gotta feel it though.
so the idea is... when u are accelerating... use low gear... and when u are cruising.... use high gear.
you dont want to accelerate in 6th gear while going 40-50mph...
and you dont want to be cruising in 1st gear going 25mph either....
hope this helps
Old Apr 12, 2007 | 01:48 AM
chriskabobbers's Avatar
chriskabobbers
lol ok better twist to this question. what rpm do you guys shift at when you're next to a cop? lol if you shift normally your exhaust will be too loud. =P
Old Apr 12, 2007 | 04:51 AM
Tac-M's Avatar
Tac-M
7600 Ftmfw !
Old Apr 12, 2007 | 06:54 AM
  #38
2005fair's Avatar
2005fair
Am I just retarded?
God help me if i'm wrong but its my understanding that 1st gear is not synchronized. All other gears have mini-clutches called syncros that match the input and output shafts of the MT(internaly) when your selecting a new gear. That is what gives you the slight resistance and click as you select a new gear. Since 1st has no syncro it can't match the other gears unless your stopped. If you insist of getting into first while in motion you'll need to double clutch(shift out of whatever gear your in, put her in N and let the clutch out, then clutch in revmatch and select 1st). But as said before, never shift to first while moving. I've never stalled or felt like the car was lugging in second.
www.howstuffworks.com has a great description of how MT really work.
and as to the original post=), shift at 2500 and accel slowly while car is cold, 3-3.5k normal driving, 4k when im late for work, 6.6k for on-ramps/outrunning Nuclear explosions.
Old Apr 12, 2007 | 07:00 AM
  #39
chochoky86's Avatar
chochoky86
I shift at around 3.5k-4.3k
Old Apr 12, 2007 | 08:43 AM
  #40
bailey bill's Avatar
bailey bill
Originally Posted by 2005fair
God help me if i'm wrong but its my understanding that 1st gear is not synchronized. .
Yeah, you're wrong. All 6 gears are fully syncronized on our cars.
bill
