Almost lose my car (FIRE)
Old May 10, 2007 | 10:17 AM
  #41
The Brickyard Rat's Avatar
The Brickyard Rat
Please be sure & post when you figure out the cause.
Old May 10, 2007 | 10:39 AM
  #42
ZBigDog's Avatar
ZBigDog
Scary stuff at least she still runs. My friend had a fire in his car once too, wait na he didn't but everyone elses friend has it seems, wanted to fit in
Old May 10, 2007 | 11:07 AM
  #43
nooooorb's Avatar
nooooorb
Damn. Glad you're safe.
Post updates, please. We'd all like to know how this started. It could be a recall issue, it may not.
Old May 10, 2007 | 12:03 PM
  #44
TayTaythatsme04's Avatar
TayTaythatsme04
When I hear what the shop finds I will post it.
T
Old May 10, 2007 | 12:26 PM
  #45
hidehide's Avatar
hidehide
You should just let it burn.
I owned a 330ci before, and it burnt. Insurance pay me back, then I got a Z
Old May 10, 2007 | 12:42 PM
  #46
VO...'s Avatar
VO...
Administrator
The only possible thing I could think of that would cause a fire would be overloading some wiring with more current than it was designed for. Typical car stereo power cable meltdowns are caused by too large a guage wiring, while forcing more current through it than it can handle. End result is the cabling melting down, igniting some flammable material.
Glad you're ok.
Old May 10, 2007 | 06:12 PM
  #47
CivicDelSlow's Avatar
CivicDelSlow
ooops
Old May 10, 2007 | 08:47 PM
  #48
sofa king's Avatar
sofa king
sue nissan for all theyve got1!!!
Old May 10, 2007 | 09:54 PM
  #49
dc567's Avatar
dc567
Originally Posted by upperguy
brings back memories.
looks like a gti or jetta
Old May 10, 2007 | 10:28 PM
  #50
Mickey's Malt's Avatar
Mickey's Malt
Keeping a smaller "dual halon"(wtf that is) fire extinguisher in front of the passenger seat and a much larger ABC co2 extinguisher behind the driver seat brings peace of mind.
No need for the ricer A-pillar mount(aka "my car is this hot") when you know where it is when you need it and it won't roll under the seat.
If this is an electrical fire, it's a good idea to make some sort of on/off/kill/etc switch on the negative battery terminal to cut the power when a wire starts to fry the insulation. An extinguisher may not help with melting copper wants to fuse with your fuel line.
Best of luck in repair and I wish that it doesn't happen again! These things usually are not your fault, unless the battery is grounding on your hood or something obvious like that.
Old May 10, 2007 | 10:35 PM
  #51
doskiez's Avatar
doskiez
Wow that is wierd glad to hear your ok and your car was not damaged tooo much
Old May 10, 2007 | 10:44 PM
  #52
03Platinum350z's Avatar
03Platinum350z
Glad to hear your all right bro! Damn RSX, it was just jelous =P
Old May 11, 2007 | 09:01 AM
  #53
Jonathan Allyn's Avatar
Jonathan Allyn
Glad to know your OK. Keep us posted..
Old May 11, 2007 | 10:38 AM
  #54
TayTaythatsme04
will do
T
Old May 11, 2007 | 10:46 AM
  #55
Sleeper01's Avatar
Sleeper01
glad your okay...crazy ****
Old May 12, 2007 | 01:26 PM
  #56
whitemikecn's Avatar
whitemikecn
Originally Posted by TayTaythatsme04
I opened the hood and almost got my face burned off. Saved the hood though
T
Just an opinion comming from a Firefighter...... Never open your hood if you have a fire in your engine compartment..... When you let a vast amount of O2 into any fire you are feeding it. If you are gonna fight the fire just "pop" the hood(do not open) and stick hose or extinguisher through the crack between the fender and the hood that you created from poping it.
And about the dual halon..... Halon extinguishers are no longer available because the work on the principle of comletly eliminating the O2 form the air....Accidently set off a halon extinguisher in your car and it could be a very quick death if you didnt know what was going on.
Chris
Old May 12, 2007 | 02:04 PM
  #57
StylesCD's Avatar
StylesCD
dude i'd be freaked....now that i knwo this could happen to a 350Z i'm buyin a fire extinguisher
Old May 12, 2007 | 02:07 PM
  #58
hardrock905's Avatar
hardrock905
Wow. That's some crazy sh#t for sure. I would have been flipping out.
Glad you're fine and please let us know WTH caused this when you find out.
Old May 12, 2007 | 07:38 PM
  #59
TayTaythatsme04
Chris
I thought it was just smoke I didnt see flames until I opened the hood. If I didnt see the flames I would of walked away and my car would have been ashes
Thanks for the info though
T
Old May 12, 2007 | 10:33 PM
  #60
nzpv03's Avatar
nzpv03
Chris
thanks for some good advice!
Hey T car parts can be replaced...glad youre ok
