Almost lose my car (FIRE)
Old May 13, 2007 | 01:44 AM
  #61
TayTaythatsme04's Avatar
TayTaythatsme04
Originally Posted by nzpv03
thanks for some good advice!
Hey T car parts can be replaced...glad youre ok
THanks
T
Old May 13, 2007 | 02:21 AM
  #62
jmasi's Avatar
jmasi
Originally Posted by TayTaythatsme04
THanks
T
I always see you driving around Temecula...That sucks what happened...but as long as your okay it's all good..Poor Z..
Old May 13, 2007 | 04:46 AM
  #63
StylesCD's Avatar
StylesCD
do you have any idea what happen? did the engine pop a cap or sumthin?
Old May 13, 2007 | 08:15 AM
  #64
TayTaythatsme04
not yet
Old May 14, 2007 | 12:27 PM
  #65
upperguy's Avatar
upperguy
Originally Posted by dc567
looks like a gti or jetta
It was my 20th ann ed GTI.
Old May 17, 2007 | 03:46 PM
  #66
TayTaythatsme04
well heard from the shop today and they told me that it was a bad PS line. Which was leaking on to the hot side piping which caught on fire.
T
Old May 17, 2007 | 09:04 PM
  #67
The Brickyard Rat's Avatar
The Brickyard Rat
What is a PS line?
Old May 17, 2007 | 10:01 PM
  #68
TayTaythatsme04
power steering line, next to the steering rack
Old May 17, 2007 | 10:06 PM
  #69
carfi179's Avatar
carfi179
I drop my car at GT motorsports yesterday and I think I saw your car there?
Old May 17, 2007 | 10:25 PM
  #70
r0mey's Avatar
r0mey
im sorry 2 hear man good luck with ur ride
Old May 18, 2007 | 05:47 AM
  #71
THE TECH's Avatar
THE TECH
At least you found out what is was. Now I guess it's up to your insurance to cover it.
Old May 18, 2007 | 06:05 AM
  #72
sq40's Avatar
sq40
Originally Posted by vo7848
The only possible thing I could think of that would cause a fire would be overloading some wiring with more current than it was designed for. Typical car stereo power cable meltdowns are caused by too large a guage wiring, while forcing more current through it than it can handle. End result is the cabling melting down, igniting some flammable material.
Glad you're ok.
VO,
Im glad you brought this up, its a Good Safety Reminder;
1) ALWAYS Fuse every power lead you install as close to the power source as possible.
2) If you split a power lead in to two or more smaller leads, fuse each new lead at the split.
3) Use power wire that is appropriate for the wattage you will be drawing. Larger wire is always safer, as it does not heat up under load. (Chart Below)
4) Use the proper size fuse for your wire and do not add a larger amp fuse than you need.
5) If you keep blowing fuses, do not simply add a larger amperage fuse, blowing fuses is an indication of a ground or current fault, fix the problem.
Old May 18, 2007 | 07:57 AM
  #73
TayTaythatsme04
Originally Posted by sq40
VO,
I dont think it was bad wiring, just a faulty PS line. And when you have hot side piping all over that area your asking for trouble.
T
  #74
TayTaythatsme04
Im going to look into that but I dont think there going to
T
Old May 18, 2007 | 07:58 AM
  #75
TayTaythatsme04
probably it waiting on the OEM part from Nissan to fix this problem
T
Old May 18, 2007 | 08:01 AM
  #76
sq40's Avatar
sq40
T
Ofcourse, I just wanted to post up a little wiring reminder since we were on the topic of Safety.
I am really sorry to hear about the fire, glad your OK man.
Old May 18, 2007 | 08:02 AM
  #77
THE TECH's Avatar
THE TECH
T
Ouch. Hopefully they'll take care of you. I assume there's quite a bit of damage?
Old May 18, 2007 | 03:54 PM
  #78
TayTaythatsme04
got to look at it before the new part was in. The hot side piping leading to the turbo was rubbing against the metal PS line right next to the steering rack.
The reason for this could be multiple things. The shifting pipes during driving under heavy conditions(load). The fact that this kit is a for a auto and things were custom fitted to make it work. Also the fact that the heatwrap over all the piping increases the size of the pipe while increasing the change it will rub against something.
In short there were probably a few factors that made this happen. But there was no fire damage to anything,
T
Old Jul 2, 2007 | 12:49 PM
  #79
35ounces's Avatar
35ounces
03 CS Track 6MT
Wow! I didn't see this until now. Sorry to hear about the fire. Glad there was limited damage and no injuries.
FWIW: A while back my car had the same issue. The TN piping was rubbing the PS line and cut a hole through. Lucky for me it finally let go after getting off the highway. No fire but I did realize that could have happened. I've been a little worried that I could go up in flames in this car ever since.
etkms
Jun 19, 2022 06:30 PM
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
Mattg350z
Oct 2, 2015 06:51 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
Daniel_dh
Sep 7, 2015 12:56 PM
