What are the differences between the 350z and g35x engine
Old May 13, 2007 | 07:24 AM
One Quick Z's Avatar
One Quick Z
Default What are the differences between the 350z and g35x engine
Hi guys,
I recently lost some compression in cylinder 6 on my motor and have found a 04 g35x engine to do a direct swap.
Will I need a different wiring harness to plug into my ECU?
Are there any differences at all that would get in the way when doing a longblock swap?
I tried to search for differences and didn't come up with anything, so I assume they're the same, but I just wanted to make sure before I spend the money.
Old May 13, 2007 | 07:40 AM
Z04's Avatar
Z04
first off, if it is a G35X then it is a AWD engine, you may have some issues with that, mainly with the rear driveshaft and what to do with the front system. not really sure this engine would even work in a 350Z, even with a ECU since the system is used to control the AWD in the first place. might be better off finding another VQ35 Z engine for this. for an idea of what will be involved to do somethign like this, check out this:
https://my350z.com/forum/showthread....highlight=G35X
Old May 13, 2007 | 07:49 AM
rookie's Avatar
rookie
Oil filter position is different on the AWD VQs, from the upper oil pan up it is the same motor.
Old May 13, 2007 | 07:58 AM
One Quick Z
Thanks, so I can just pull my oil filter housing from my old motor.
What about the wiring harness?
Old May 13, 2007 | 08:02 AM
StylesCD's Avatar
StylesCD
i would suggest doing a rebuild on ur current one, replace cylinder heads ETC
would be cheap and easier
Old May 13, 2007 | 08:04 AM
rookie's Avatar
rookie
Swap oil pans and sensors from your motor to the other and it will be fine.
Old May 13, 2007 | 10:01 AM
One Quick Z
Doesn't seem like it would be worth it since some of the sensors are located within the block ie. knock sensors..
Mattg350z
Oct 2, 2015 06:51 AM
_koubie_
Sep 20, 2015 06:34 PM
