Another Noob shifting question
Old May 27, 2007 | 08:25 PM
OneI350's Avatar
OneI350
Default Another Noob shifting question
was wondering if it was proper form to push the clutch completely down (all the way to the floor) in order to switch gears. Or,exactly how far down is enough, without hurting clutch or tran. Still trying to get used to the Z clutch and power. Did not get much out of the search engine for this question.
Thanks in advance
Old May 27, 2007 | 08:32 PM
Casanova's Avatar
Casanova
I dont think there is a problem unless you hear a crunch man... Just drive.. put in clutch - i dont think i go all the way down.. but just shift normally - should be fine -- no one likes a clutch rider
Old May 27, 2007 | 08:33 PM
Spike100's Avatar
Spike100
All the way down... to the floor... everytime you shift.
--Spike
Old May 27, 2007 | 08:37 PM
Bottled Water's Avatar
Bottled Water
and wen yur wide open, dont let off the gas. keep it pinned!
Old May 27, 2007 | 08:43 PM
On the street? Yes. Plush the clutch to the floor. Why wouldn't you.
Old May 30, 2007 | 03:16 PM
OneI350's Avatar
OneI350
Thanks folks, just wanted to be sure.
Old May 30, 2007 | 03:36 PM
GameBlouseS's Avatar
GameBlouseS
yes it's proper form to push it all the way to the floor
Old May 30, 2007 | 03:46 PM
Marino Z's Avatar
Marino Z
Know it all
like everyone else said, all the way down
Old May 30, 2007 | 04:01 PM
danduvz's Avatar
danduvz
Our clutches engage high, so it doesn't matter (except for some peoples peace of mind) if your pedal actually touches the floor. The farther you push the pedal down, the bigger gap you are putting in between the pressure plate/clutch/flywheel assembly, but as long as the are not transmitting friction between each other it is safe to change gears.
I find it to be quite a bit easier to rev match when I don't have 4 inches of pedal travel after a gear engagement.
Old May 30, 2007 | 04:14 PM
Kevins350z's Avatar
Kevins350z
push the clutch all the way down when ever you shift
Old May 30, 2007 | 04:22 PM
6SPD Z33's Avatar
6SPD Z33
wtf is a clutch? you use that thing? speed shift ftmfw!!!!!
Old May 30, 2007 | 04:51 PM
fr0ng's Avatar
fr0ng
lol @ people giving answers without even knowing how a clutch works.
you dont need to push it all the way...just enough to disengage it while you shift to the next gear.
Old May 30, 2007 | 05:45 PM
OneI350's Avatar
OneI350
I was out running around today and I noticed that there wasnt much difference when pushing the clutch all the way down or just 75 percent down.
Seems like there is mixed asnwers for this. But your comment does make sense. I think ill just stick to pushing it down completely...for now
Old May 30, 2007 | 05:48 PM
jrforrester's Avatar
jrforrester
What you need to ask yourself is if it's really that much more of a pain to push it the entire way compared to the possible risk of not pushing it far enough. I would say with normal driving there is no reason why u shouldn't just play it safe and push it the extra couple inches.
Old May 30, 2007 | 06:44 PM
deluzrider's Avatar
deluzrider
it does not matter as long as it is fully disengaged. to the floor or 3'4ths the way down. dosent matter as long as it doesnt grind
OneI350's Avatar
OneI350
yup, like i said, ill stick to pushing it down completely
Old May 30, 2007 | 08:00 PM
Spike100's Avatar
Spike100
So... how far is that, 2 inches, 4 inches, or maybe until you mystically feel that it is the right distance?
Old May 30, 2007 | 08:42 PM
fr0ng's Avatar
fr0ng
when it doesnt grind, its far enough.
Old May 30, 2007 | 08:54 PM
danduvz's Avatar
danduvz
Why is this even a debate? For everyone saying "Push it to the floor", can I have a reason? Forums have bad names because people JUST SAY STUFF. If you don't know, don't comment. A little explanation goes a long way around here.
Seriously, one more thing. How do you know if your clutch is disengaged? Easy. If you are at 3,000rpm and you push the clutch pedal down, once the rpms fall, you are disengaged. Pretty simple.
Spike100's Avatar
Spike100
Do you do some "test grinding" to determine that point?
