oddest thing during tiptronic shift
Old Jul 2, 2007 | 02:33 PM
Nismo 350z's Avatar
Nismo 350z
Originally Posted by Lawy'dU
no it's tiptronic. It's actually a pretty decent system. It doesn't automatically shift up or down unless you tell it to.
Its triptronic u dumba$$. It doesnt matter if it shifts for u or not. Anything that has a manual mode is a triptronic system. Same thing found in Porshe's,Bimmers(excluding SMG)and so on.
Old Jul 2, 2007 | 05:16 PM
sandthepilot's Avatar
sandthepilot
Originally Posted by aloh
Even if you hit the redline, it wont shift up. Ive tried it to see what would happen. All it does is cut the throttle, but it will not shift up for you. THe only time it changes gears without your input is if youre going too slow for that gear and will downshift to a more appropriate one.
Agreed. It only shifts down for you.
Old Jul 2, 2007 | 09:54 PM
Suvlaki's Avatar
Suvlaki
Originally Posted by fr0ng
hi i drive an automatic sports car
the ignorance on this forum that turns every thread with "A/T" in it into an A/T vs. M/T thread amuses me... it never gets old
Old Jul 2, 2007 | 10:13 PM
tractng's Avatar
tractng
Originally Posted by Suvlaki
when you were "racing" this "malibu," did you keep your hand on the shifter? the shifter is very sensitive as far as shifting it back and forth from D is concerned, and if u accidently move it a little bit to the left, it can go in D.
Maybe you accidently moved it just a tad, realized that it was moving so you tried to move it back, and did it at juuuuust the right speed so that the computer locked up and thought that the tranny was in D instead of manual mode. Coming from a computer proramming and electrical engineering background, I know lock ups like this are actually more frequent than people think.
Try shifting up and down in manual mode, but taking your hand off the shifter between shifts. If you can replicate the problem, take it to the stealership.
..and don't ever lose to a malibu again.
I don't know what I did. Maybe you are right about being sensitve. I am still used to the 6spd car. .
Tony
Old Jul 2, 2007 | 10:26 PM
JJ350's Avatar
JJ350
hi im a tool
fixt!
Old Jul 2, 2007 | 11:09 PM
groove269's Avatar
groove269
Originally Posted by IcW@TeR
is the z really tiptronic? i though it had some wannabe tiptronic auto transmission
You used the same quote on another thread, how sad
Old Jul 3, 2007 | 05:46 AM
350Zenophile's Avatar
350Zenophile
triptronic?
Old Jul 3, 2007 | 05:49 AM
IcW@TeR's Avatar
IcW@TeR
yea it's called a joke
Old Jul 3, 2007 | 05:54 AM
IcW@TeR's Avatar
IcW@TeR
ya might wanna hit google up before ya start calling peoples intelligence into question
Old Jul 3, 2007 | 05:57 AM
wckdclw's Avatar
wckdclw
but either way, its if you driving too hard then the ecu puts it into safe mode, it wont let you go above 2nd gear manually or when you put it into drive so you have to shut off the car and start it again and its fine
Old Jul 3, 2007 | 06:39 AM
coachk's Avatar
coachk
Default oddest thing during tiptronic shifting
Originally Posted by davids
Yes the most important thing you should learn from this thread is what manual mode is and the correct term to use, rather than actually getting an answer to your question.
I hope this wasn't directed towards me.....
Old Jul 3, 2007 | 06:53 AM
furiousZ's Avatar
furiousZ
Originally Posted by JJ350
fixt!
Good fix.
Old Jul 3, 2007 | 09:04 AM
DomZ's Avatar
DomZ
Guys this happens to me a lot. If you bang the limiter a few times the tranny goes into some kind of safe mode where you can't change gears - its basically like being stuck in 1st but it only catches after 4-5k, like its caught between gears. You don't have to turn the car off you just have to come to a complete stop even for just one second.
Old Jul 3, 2007 | 09:16 PM
NightRida's Avatar
NightRida
You guys apparently don't know what the hell your talking about. If your a manual owner and are dissing people on this thread then that proves you must have a small *****!
My 2007 does that too, but it could be like what "suvlaki" said. However, no need to shut your car off or stop. Just put it back into D and then switch it back over to the manual mode after a few seconds, to avoid excessive wear and tear of course!
Peace!
sherm
Apr 11, 2020 05:21 PM
_bit
Oct 2, 2015 07:49 AM
Mattg350z
Oct 2, 2015 06:51 AM
