When do you shift to 2nd from a dead stop?
Old Jul 20, 2007 | 03:03 AM
trinityracing's Avatar
trinityracing
Hmmmm...
Old Jul 20, 2007 | 03:30 AM
Tenac1ousZ's Avatar
Tenac1ousZ
Originally Posted by HDPD350Z
Only time I start out in 2nd is when doing burnouts before a run at the strip (I never do 1st gear burnouts). Although my motor has plenty torque for smooth starts in 2nd.
isnt doing burnout in 2nd bad for both the tranny and engine at the begining? It seems like there would be a lot of load initially before the wheels break traction and start spinning. Do you do burnout on some water to brake traction first?
As for rough 1 > 2 shift, after driving for over two years, I find that not forcing the shifter to second right away, as well as blipping the throttle a little before releasing the clutch, is the smoothes method. Or you can change to a lightweight clutch disc/flywheel setup. I've read many times that ATS (Carbonetics clutch) does wonder in smoothing out rough shifting, because of its lightweight carbon disc.
Old Jul 20, 2007 | 03:53 AM
tropicalypso's Avatar
tropicalypso
meh, just stomp the accelerator and keep it to the floor as you clutch in and shift from 1st to 2nd
buttery smooth
Old Jul 20, 2007 | 04:07 AM
HDPDZO6's Avatar
HDPDZO6
Burnouts done by backing into water box. 2nd gear burnouts seem the concensus for vette owners.
Old Jul 20, 2007 | 04:44 AM
Wheelman's Avatar
Wheelman
Originally Posted by michaeljr6
wow..............
that is all i'm going to say
(lol @ some ppl don't know how to drive a MT)
So instead of being a dick, why not help him out? He admitted he was new to driving a standard. To the OP, in normal driving somewhere around 3,000 is good. Start giving it a little bit of gas as the clutch is almost all the way out to keep it from clunking in between gears.
Old Jul 20, 2007 | 08:21 AM
ksandhu29's Avatar
ksandhu29
wow..............
Old Jul 20, 2007 | 09:46 AM
6SPD Z33's Avatar
6SPD Z33
shift into 2nd at 7200rpms... don't get discouraged if the car won't rev that high at first... just keep trying
Old Jul 20, 2007 | 10:01 AM
rockinbboy's Avatar
rockinbboy
If you want a super smooth shift, you want to shift early into 2nd. Shift into 2nd gear between 7-10 mph, it should be pretty smooth.
This is how I shift usually:
1st to 2nd: by 3k rpms (I don't remember the speed ..I just shift when it feels right)
2nd to 3rd: at 30 mph
3rd to 4th: at 40 mph
4th to 5th: at 50 mph (see a pattern ? )
5th to 6th: at 60 mph
Old Jul 20, 2007 | 10:02 AM
Tubbs's Avatar
Tubbs
why would you start in second? why is this even a thread. 1 comes before 2.
Old Jul 20, 2007 | 10:09 AM
synth19's Avatar
synth19
some of us need to shift a bit quicker then @ the speeds you posted below.
sherm
Apr 11, 2020 05:21 PM
Depravity
Oct 1, 2015 04:49 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
