Please need some help here guys.
Hey everyone. This August, I will be heading over to the East Coast for med school. I will not be taking the Z with me so its going to stay at home here in So. Cal. I need to know what I must do if I am going to store the car and not drive it say...4-5 months. I will be coming back in Dec. and the only person I know who might use it is my dad. But thats going to be a very slim chance since he drives a SUV. So what do I need to do to store the car? I have searched and it seems the only thing needed is disconnecting the battery correct? Do I need to empty the gas tank or drain any other fluids? I know its wise to change the oil upon return which I will do. Should I change the oil before storing it? And is a gas stabilizer really neccesary? I can tell my dad to start it once a week and drive around the block every now and then. But would the seals break down? Car has about 25k miles on it. Thanks for any and all help guys. I will appreciate it.
I would fill the gas tank. This reduces the chances of water condensing on the sides of the tank and mixing in with the gas.
Personally I drive my spare car once a week, long enough to warm up the engine and circulate the water in the radiator and fluids through the transmission and rear diff.
If the car is just going to sit there, then disconnecting the battery seems like a good idea. You could also put the car up on "blocks" to get it off the tires. In the olden days, we would pull the plugs and squirt some oil in the cylinders and then turn the motor over without starting the engine. Animals may move in so you may want to take some precautions noted below.
http://autorepair.about.com/od/carcare/a/storecar.htm
100% i will disconnect battery first, and just take it too shop and check everything before u leave.
and when u come back, straight take it to shop check everything again.
i don't think u don't really have to check fuel and other stuff, if u gonna leave there about 4~5 months.
well good luck with u bro.
u gonna miss ur Z !!
Have your dad drive it once in a while, but make sure that it's a long enough run to evaporate all the moisture from the exhaust. Change the oil and filter when you get back to normal driving.
Originally Posted by Hraesvelg
Fuel stabilizer
Fill the tank. It reduces condensation. Cars sit on the lot for four or five months without problems. I don't think you'll need a fuel stablizer. You certainly don't need to remove the battery. And if your dad is going to drive the car occasionally, why disconnect it at all?
1. Oil change before I leave or after when I start her up again?
2. Do I really need to remove the rims/tires and put her on jackstands? I will be back in Dec. I dont think the tires would have any flat spots by then would they?
3. If I disconnect the battery, do I have to take out the whole thing and clean it?
4. Do I need to take the spark plugs out and oil up the cyl. walls? I know you need to do this for an older vehicle.
5. Would the brake fluid be ok or would it corrode after a while?
Thanks alot for the help everyone.
i have stored my z for the same time, exactly 5 months. i filled the tank, i did not disconnect the battery cable, i just had my sister start it every 10 days or so for about 5 min. and since i had goodyear f1 tires over $300 a pop i filled them with nitrogen, you can do this for about 20 bucks. it was recommened by a goodyear person i know personally. my car started just fine and now all i run is nitrogen. you get better tire where.
Originally Posted by Nismo 350z
True. But I was thinking of letting it sit and not let him drive it. He hasnt driven stick in a while and the car might be a little low for him. So I was going disconnect the battery and just store it. If someone can answer these questions I would greatly appreciate it.
2. No, just get some heavy wide boards appox 1 to 1/2" thick by at least 3'X3' & drive your Z on top of each of the boards so that each tire is setting on each board.
3. Disconnect the battery & leave it or you can take it out & clean it.
4. No
5. OK
6. Would your flooring in your garage create any condensation? If so, Just lay down some heavy cardboard as an insulation or carpet.
7. I store my ZR every winter here in Ohio.
Originally Posted by sluggoZ
1. Oil change after.
4. No
5. OK
4. No
5. OK
