350Z burn out
Old May 10, 2003 | 09:58 AM
Berek12P's Avatar
Berek12P
Question 350Z burn out
Does anyone know how to burn out with the Z just having the rear tires spin and the car in place? I have been trying to do it but no luck.
Old May 10, 2003 | 10:01 AM
Del350's Avatar
Del350
Pull out your abs fuse and try it
Old May 10, 2003 | 11:10 AM
ares's Avatar
ares
Veteran
I actually heard it was the brake light fuse. anyway, the car is drive by wire, as such, the computer controlling your gas also knows if your braking, meaning it wont give more than like 30% power if you holding the brake. not too impressive.
there is a fuse you can supposedly pull, but if it senses this input is gone for too long it will put the car into safe mode and you'll never get any power. but you can pull it for a period of time to do a burn out, and then put it back in.
ps. burnouts arent real good for anything unless you have drag radials on the car... well arent good for anything other than burning up your tires and brakes.
Old May 10, 2003 | 12:40 PM
N74DV's Avatar
N74DV
I don't pull the fuse I pull the connector by the brake pedal.
see my sig..... that burn was sped up... it lasted about 30 seconds.
Old May 10, 2003 | 02:28 PM
Berek12P's Avatar
Berek12P
yeah i was wondering if i was able just to diconnect the connector to the brake. I guess it is, i should be able to do some great burnouts now.
Old May 10, 2003 | 02:49 PM
NiTr0u5oXiDe's Avatar
NiTr0u5oXiDe
Nice Sig!
Old May 10, 2003 | 03:15 PM
teh215's Avatar
teh215
Wouldn't a Line Lock work on these cars since it is a mechanical solution?
Old May 10, 2003 | 08:40 PM
NJZ's Avatar
NJZ
what does the connector look like and where is it located?
Old May 10, 2003 | 08:57 PM
ares's Avatar
ares
Veteran
yes, and its the ideal solution too, since it saves the brakes and just heats/smokes the tires which is the point of it. no one does burn outs cause they want to heat their rear brake pads.
I have little knowledge of how to actually create a line lock tho, but it would be cool.
liqalu04
Jan 2, 2022 12:58 PM
issyz
Jul 2, 2017 03:04 PM
wanderingstuden
Jan 28, 2016 07:03 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
nanotech
Oct 2, 2015 05:02 AM
