How to correctly drive an MT
Old Aug 10, 2007 | 06:06 PM
  #41
IGotA350Z's Avatar
IGotA350Z
I though it was not a bad thread. I liked it b/c it explains things a lot more than my friends did when they taught me how to drive a MT. It's sometimes nice to know how things work inside...it helps the thought process as you learn something new. Just jumping behind the wheel does you no good if you do not know what's going on to begin with.
Old Aug 10, 2007 | 06:23 PM
  #42
illjim69's Avatar
illjim69
Originally Posted by 06Gcoupin
Im guessing you havent seen the 2432987492894789 threads on this forum with MT issues. You sir, are a tard.
why is he a tard?
jim
Old Aug 10, 2007 | 08:44 PM
  #43
terrasmak's Avatar
Engine braking is perfectly healthy for our VQ's....
yes but it upsets the chassis on corner entry.
Old Aug 11, 2007 | 04:36 AM
  #44
roast's Avatar
roast
Originally Posted by DavesZ#3
Stopping at a red light with the clutch pressed in for say 30-45 second with the engine turning 800rpm isn't very much wear on the TO bearing. Not like the wear it gets from resting your foot on the clutch while you drive down the highway at 3000 rpm for an hour or two. People wear them out by riding the pedal, not by using it as intended.
A: I didn't say riding the clutch wouldn't wear out the throwout bearing also.
B: Constantly holding the clutch in for long durations WILL wear out the throwout bearing as well.
Surely there was a reason nissan put in the owners manual, and I quote:
"When the vehicle is stopped for a period of time, for example at a stop light, shift to N (Neutral) and release the clutch pedal with the foot brake applied"
The clutch is not intended to be disengaged for long periods of time, that's what NEUTRAL is for.
Old Aug 11, 2007 | 04:38 AM
  #45
roast's Avatar
roast
Old Aug 11, 2007 | 06:01 AM
  #46
350Zenophile's Avatar
350Zenophile
+1, this is the throwout bearings job.
The Z's throwout bearing may be more robust than most, but it is a wear item and a truly ****ty thing to have to replace before it's time as it requires dropping the exhaust and tranny which leads to those slippery slope expensive thoughts like "might as well replace the clutch and flywheel while I'm in hear!"
Old Aug 11, 2007 | 06:25 AM
  #47
350Zenophile
Thumbs up
Can't believe all the haters in this thread. It's always good to talk technique before and after actual driving sessions. It reinforces the concepts you are trying to turn into muscle memory when you practice. No harm in that.
With that I do have a few comments:
Also, when slowing down to come to a light, I downshift and 3rd is as low as I go. Cruise to the light in 3rd and just brake the last few feet while putting it in neutral once u come to a full stop.
No need to downshift at all when coming to a complete stop at a light. Unnecessary clutch wear. If you want to engine brake, just stay in whatever cruising gear you are in, take your foot off the gas and depress the brake. Then push the clutch in when the injectors start firing again (at about 1500rpm) and then use the brakes only to complete your stop.
When taking a turn, always be in gear, 2nd preferably. Don't clutch and gear in midway thru the turn, its not good practice. Brake before the turn, Rev-match into 2nd and take the corner. This way, you will be in gear immediately, ready to punch it if need be.
Second gear is not a firm rule. Instead think about what gear you will need to be in on exit and be in that gear before you start making the turn. Some slower sweeping turns may only require a downshift to third. Being in gear during a turn is not always about being able to "punch it" on exit. It is about giving you one more level of vehicle control besides the steering wheel since you can fine tune the car's behavior through the turn with throttle inputs as well.
Everything else sounds spot on, especially the double clutching explanation although I have had some occasion to use it as it is helpful when the tranny is cold and doesn't want to make the 3-2 downshift.
Old Aug 11, 2007 | 06:50 AM
  #48
Starchecker's Avatar
Starchecker
I think the thread is great. Obviously you can't become an expert just by reading about how to drive it, I don't think the OP intended to accomplish that.
By the same token, just going out and practicing doesn't do you any good if you are practicing wrong. When I first tried to rev match I thought you were supposed to keep the throttle in as opposed to just blipping it. That made it VERY difficult to make smooth downshifts.
This is my first MT car, I had a friend who gave me some great input and from then on I just started doing what "seemed right" after he got me pointed down the right path. Reading this thread really reinforced what I have been doing is the proper technique, even things I was doing that I thought weren't ideal but easier to accomplish(downshifting just before entering the turn, instead of in the middle of the turn).
I for one love to heal to toe, I actually got that technique down before just regular rev matching. Being able to fulcrum my foot off the brake peddle helped me control the throttle input with more precision. Especially going into hard corners, being able to be braking hard and downshifting at the same time in one seemless action, really makes for a smooth and impressive high performance turn.
So thanks for taking the time. I don't see how anyone couldn't benefit from this information.
Old Aug 11, 2007 | 07:33 AM
  #49
bailey bill's Avatar
bailey bill
Yup, I've read them. And they are the result of a manufacturing/desingn flaw, NOT a result of "improper" driving technique.
That's why Nissan replaces them under warranty. I guarantee you they would NOT be replacing them under warranty if there was so much as a suspicion that the problems were teh result of abuse.
Everybody wants to believe that driving a manual tranny qualifies them for membership in some circle of elite, specially-qualified drivers. Like I said, until about 1960, almost everybody drove manual trannies. And even in those dark days of questionable build quality, nobody broke trannies. Hell, our high school driver's ed car ('59 Chev) had a manual tranny.
bill
Old Aug 11, 2007 | 07:44 AM
  #50
bailey bill
I couldn't have said it better. While your dissertation is interesting, expecting someone to read it then jump behind the wheel and be able to drive a MT isn't going to happen. Have you ever tried to teach someone to drive a stick? While you can explain the simple mechanics, the smooth fluid motions you describe come from years of practice and experience.
No, you are not going to jump behind the wheel and drive a manual tranny. But it isn't about rules and procedures, its about pratice and technique. You basically need to learn to coordinate power and RP{M (with teh right foot) with clutch engagement and disengagement (with teh left foot).
Not much else really matters.
Actually, I taught my wife and 4 daughters to drive manual trannies. My wife (at age 45) and daughter #1 learned on my Fiat Strada 5 speed, duaghters 2 and 3 learned on my 914's ( 4 spds with difficult shifters), and my youngest learned on my 5 spd MR2.
Teacher, all students, and all vehicles survived just fine.
And all of them still prefer manual trannys.
bill
Old Aug 11, 2007 | 09:21 AM
  #51
azula's Avatar
azula
wow, sticky potential....
Old Aug 11, 2007 | 10:16 AM
  #52
06Gcoupin's Avatar
06Gcoupin
Yeah, thats why I stated, "to punch it if need be", im not saying that you ALWAYS have to punch it after you exit a turn, thats absurd. I simply meant to always be in gear on a turn. I mentioned 2nd gear, because on city and residential streets, you wont be traveling too fast...
Old Aug 11, 2007 | 10:17 AM
  #53
06Gcoupin's Avatar
06Gcoupin
It was stickied on g35driver
Old Aug 11, 2007 | 04:22 PM
  #54
AlmostJesus's Avatar
AlmostJesus
one question though...in bumper to bumper traffic on a hill...I find it almost impossible not to have to clutch half way for more than 2 seconds...plus it's scary because there's always people riding your ***..and you're on a steephill...how do you guys do bumper to bumper traffic on a hill?
Old Aug 11, 2007 | 05:22 PM
  #55
roast's Avatar
roast
Bumper to bumper on a hill? That's gotta be fun. I wouldn't be in any hurry to pull forward everytime someone moves an inch, but I would use the hand brake (one of it's intended purposes).
Old Aug 11, 2007 | 05:26 PM
  #56
Key Of Z's Avatar
Key Of Z
bill
Beautifully said there, Bill!
Old Aug 11, 2007 | 05:54 PM
  #57
Pinky Demon's Avatar
Pinky Demon
bill
All right, everybody, listen to this guy, he knows what he is talking about. Then and only after practical practice, read this thread. Oh, and for not touching any pedals at a red light. Don't make me laugh.
Old Aug 12, 2007 | 06:18 AM
  #58
350zach077's Avatar
350zach077
yea, my buddy has a 10 sec talon, and lately on highway runs, hes been brake boostin, and i was like i hope u like doing ur brakes often cuz thats all i smelled wen i was following you
Old Aug 12, 2007 | 01:27 PM
  #59
rkd350z's Avatar
rkd350z
cool guide, but I'm not tooo worried about my tranny and clutch.
If I get the problem, I'll get JWT clutch and flywheel combo!!
Old Aug 13, 2007 | 05:49 AM
  #60
350Zenophile
OK wtf. You went back and edited your post to add the "if need be" part? No worries man. I was just trying to add some info to your thread, not call you out.
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
