traction control
Old Aug 10, 2007 | 02:01 PM
jones21's Avatar
jones21
Default traction control
I dont know if any of you guys have noticed this. but i was doing a brake stand and everything was fine.. then i try it again in the same spot but i couldnt get the tires to spin.. does traction control automaticly turn back on?
Old Aug 10, 2007 | 02:25 PM
WTX350Z's Avatar
WTX350Z
only if u turn the car off and back on.
if its off you'll see "TCS OFF" light.
Old Aug 10, 2007 | 02:27 PM
No.
Old Aug 10, 2007 | 05:35 PM
jones21's Avatar
jones21
ya the light says off but i couldnt get the tires to spin the second time..
Old Aug 10, 2007 | 07:07 PM
03Platinum350z's Avatar
03Platinum350z
Mabye you let the clutch off to slow /shrug. I drive an AT and I can get em to spin most of the time.
Jeff
Old Aug 10, 2007 | 07:18 PM
jones21's Avatar
jones21
i got an automatic too..
Old Aug 10, 2007 | 07:52 PM
Combat350z's Avatar
Combat350z
Shouldn't have that problem.
My old Z was auto and I could spin tires all the time
Old Aug 10, 2007 | 10:00 PM
HDPDZO6's Avatar
HDPDZO6
"brake stand" = ?
If it's something like a burnout before a drag race, then you wont be able to do one without pulling the brake light fuse.
Old Aug 12, 2007 | 09:49 AM
jones21's Avatar
jones21
ya a barkae stand.. you know hold the brake in and gun it?? how bad you think that is for my car?
Old Aug 12, 2007 | 09:51 AM
mikez97's Avatar
mikez97
im pretty shure its called powerbraking
Old Aug 12, 2007 | 10:08 AM
SniperHunter's Avatar
SniperHunter
I can't spin the tires either. Too much traction, for some reason.
Old Aug 12, 2007 | 10:50 AM
BojanC350z's Avatar
BojanC350z
i tired once and it didnt work but its not good for the car so screw it...worked on grass tho haha
Old Aug 12, 2007 | 11:11 AM
JunkStory's Avatar
JunkStory
why would you want to do that
Old Aug 12, 2007 | 11:36 AM
ohSIXz's Avatar
ohSIXz
cuz they are still running stock tires and havent seen the bill for replacements yet!
Old Aug 12, 2007 | 08:12 PM
MulhollandDrive's Avatar
MulhollandDrive
I think he is talking about preloading the drive train for best 1/4 mile times, pretty standard technique for drag racing with an AT. I would not describe it as gunning the engine, but rather holding the car in place with the brake while maintaining an elevated RPM with the gas pedal preloading the drive train, followed by releasing the brake and stomping on the gas pedal on go. The object to adjust the RPM before launch to get a little chirp off the line, not spinning the tires going no where.
Stepping on the brake and gas at the same time can confuse some cars forcing the car into safety mode thus the post about taking out the brake fuse so the car does not know that you are braking and hitting the gas at the same time. You can mod the Z AT with a high stall torque converter to allow more RPMs at launch.
Old Aug 12, 2007 | 11:19 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
If you are on the brakes, throttle is cut regardless of model (with or without TCS or VDC).
As alluded to above, if you pull the brake light fuse, the ECU will not pull power, and you can spin them all you like. Keep in mind, your brake lights wont work either.
Chris
Old Aug 13, 2007 | 05:14 PM
Grey Ghost's Avatar
Grey Ghost
how big is your wheel and tire setup?
what tires you run?
Old Aug 14, 2007 | 06:46 AM
rhythmnsmoke's Avatar
rhythmnsmoke
Line Lock.. problem solved.
Old Aug 14, 2007 | 03:43 PM
jones21's Avatar
jones21
I get them to spin but for some reason this one time i couldnt get them to the second time.. And i work at Americas tire so i can get peoples used tires for free so tires aint a problem.
Old Aug 14, 2007 | 09:49 PM
SniperHunter
what tires you run?
Stock 18s. =(
It's a good thing, I'm sure - more traction = faster track times. But dammit, I wanna' burn a little. They do spin nice when turning, though. =P
