which year used Z should I get?
Old Aug 31, 2007 | 09:10 AM
Ztalker's Avatar
Ztalker
Originally Posted by sharaabi
DUH theres the HP difference but I read something on here about the weight and other drivers saying 03 is faster than the others.
btw 03 is the lightest...very slightly.
Old Aug 31, 2007 | 09:59 AM
jones21's Avatar
jones21
I got and 05 for $ 24 low miles runs great..
Old Aug 31, 2007 | 11:41 AM
SargentZ's Avatar
SargentZ
2005
2007
Old Aug 31, 2007 | 11:45 AM
Flee0588's Avatar
Flee0588
Get the 05. It is pre-HR so there are a ton more mods for it than the 07's. Plus by 05 all the problems are solved (maybe not the 5th gear grinding, though). Also, because it is the model right before the minor exterior make-over, it will probably be cheaper.
Old Aug 31, 2007 | 11:49 AM
fast kiwi's Avatar
fast kiwi
i have a 35th ann model.. get that one.. lol.. 05 with revup..
Old Aug 31, 2007 | 12:11 PM
brickyardzee's Avatar
brickyardzee
thanks everyone...
from the analysis of what everyone said , 03 is OK but 04 seems to be where the problems are resolved.
05 and 06 have been highly recomended based on what you all said but 07 is what everyone is recomending for me to go 13's WHEN i do modify it.
brickyardzee : without teh supercharger, what kinda gains am i looking at????? 10hp?20?
ive read the thread of 287hp vs 300 BUT what i want to know is, is there seriously a difference between racing A STOCK 2003or2004 VS 2005 or 2007??
If you don't add the supercharger you will get about 12rwhp from the Motordyne spacer. Adding a fill exhaust will conservatively get you another 20rwhp or so. That brings you up another 30+rwhp from stock. This is not crank hp which will be higher. If you add an intake you will squeek out a few more..it depends on how well the mods work together with each other but I then expect you to be around +33rwhp or so.
After these it gets tougher but you could add underdrive pullies and a lower plenum replacement and maybe get it to +40rwhp. If you want to go beyond that you will need to replace the cams which will cost you about 1k and close to that or a little more to be installed. Possible hp gains with those is 13 to 15 rwhp so maybe all toll your at +50rwhp give or take a few.
Think about it though. To do all this you will have spent about $4500 to $5500 and received a +50rwhp gain. Spend about the same amount, most likely a little more to get a supercharger and get 1.5 to 2x that amount of gain. It's all in what you want and how you want to do it. NA will be more reliable and you can spread the cost out over time as you build it up but F/I will give you more power in the end. Although many of the NA things will help and increase hp even further when combined with F/I.
Old Aug 31, 2007 | 12:16 PM
webby350z's Avatar
webby350z
Originally Posted by JunkStory
Get: 2003-2005 => tire feather fixable
Don't get: 2006 => oil consumption + gear grind cannot be fixed
i have an 06 and have not noticed either of those...
Old Aug 31, 2007 | 09:15 PM
sporkdevil's Avatar
sporkdevil
What's the deal with the revup? Is that just saying lower torque/more hp, S2000ish?
lapham3
Oct 7, 2022 03:15 PM
Uriyo_
Sep 8, 2021 08:46 AM
Mattg350z
Oct 2, 2015 06:51 AM
