Is this covered by warranty??
Old Aug 29, 2007 | 01:11 PM
Ilov350ZEE's Avatar
Ilov350ZEE
Default Is this covered by warranty??
i have an 06 with 13K miles, my brake pads are almost gone, is it covered by warranty???
Old Aug 29, 2007 | 01:12 PM
gsazabi's Avatar
gsazabi
No. They're considered wear and tear.
Old Aug 29, 2007 | 01:19 PM
gjoey66's Avatar
gjoey66
nope...but consider this a chance to get much better pads...i think Hawk makes a great pad that fits stock brakes...
Old Aug 29, 2007 | 01:33 PM
pony_killer's Avatar
pony_killer
Arada ninda apa
my brakes are going out also at only 15k miles...what else besides replacing the brake pads is there to do to the Z when servicing the brakes?
Old Aug 29, 2007 | 01:39 PM
gjoey66's Avatar
gjoey66
that should be it as long as it's just a street vehicle...if you take it to the track or auto-x then maybe some high temp fluid (not better performance just won't boil after 30 min in hot conditions) and maybe stainless lines...but you'd really have to be abusing it to need them.
Also...great time to check caliper bolts and suspension components...if you drive on roads with high vibration you chance loosening things up.
Old Aug 29, 2007 | 02:00 PM
Ilov350ZEE's Avatar
Ilov350ZEE
i want to do this myself and save money, how hard is it for a firstimer???
Old Aug 29, 2007 | 02:22 PM
gjoey66's Avatar
gjoey66
the most important part is to seat the pads...most people get done wrenching and want to just play...take the time to follow the procedure and the car will thank you for it.
Old Aug 29, 2007 | 02:25 PM
DavesZ#3's Avatar
DavesZ#3
Here's two DIY's here on this forum....
https://my350z.com/forum/brakes-and-suspension-diy/58156-how-to-change-brake-pads.html
https://my350z.com/forum/brakes-and-suspension-diy/58195-how-to-change-brake-pads.html
Old Aug 29, 2007 | 04:56 PM
japayukiman350z's Avatar
japayukiman350z
my car has 25,000 miles on it and bought it new but, i don't think i need a brake pad already? how do u guys drive your car?
Old Aug 29, 2007 | 04:57 PM
zand02max's Avatar
zand02max
wow 13K, you must really brake hard? Install Hawks, no brake dust!
Old Aug 31, 2007 | 09:26 PM
Bevo's Avatar
Bevo
Oil change and air filter replacement
Old Sep 1, 2007 | 04:36 AM
Ziggyrama's Avatar
Ziggyrama
Are those Hawks ceramic? People rip on the stock metallics but I found them to grip fairly well. True, the ceramics will have almost no brake dust but will they bite well? To the OP, replace all of your pads. If you do just fronts, you may upset the brake bias and end up with premature ABS engagement during hard braking. I am living with that now and it's annoying. I may replace the rears now because of that even though they still have some life left in them.
ablaine
Nov 29, 2016 10:13 AM
2ndchanceZ
Oct 26, 2015 08:03 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
