15 months
Old Sep 7, 2007 | 08:25 AM
soldierboy's Avatar
soldierboy
Default 15 months
My Z has been in storage for 15 months... what are your advices before I start her for the first time??????? thanks
Old Sep 7, 2007 | 08:27 AM
chriskabobbers's Avatar
chriskabobbers
damn that's long! first hug the car. then ... i don't know after that ... maybe some other guys can give you better advice than start the car and wait a while for it to just warm up?
Bumpinjeep's Avatar
Bumpinjeep
check tires, change oil, break fluid, i'm sure theres others.
Old Sep 7, 2007 | 08:44 AM
MagicPie's Avatar
MagicPie
I normally, pull the fuse from the fuel pump, and turn the engine over a few times with the starter the get some oil flowing(or do it my turning the crank pulley), before fireing it up.
It would also be wise just to replace the oil first
If you didnt drain the gas, I would suck the tank dry somehow and put some fresh gas, am sure whats in there has gummed up.
Check the brake fluid for excessive moisture from sitting around
Check the tyres, having them stay still for that long in my experience can cause them to mis-shape.
A few routine checks here and there and you should be alright
Old Sep 7, 2007 | 10:23 AM
06PPW350's Avatar
06PPW350
Wash It!
Old Sep 7, 2007 | 11:29 AM
HondaKiller's Avatar
HondaKiller
ouch, first i would be prepared to clean out rat chit. Then
-Pull the air filter, check and replace if needed.
-Tire Pressure (probably low)
-Change oil and filter before you fire it up
-Check radiator fluid to make sure it hasn't gunked up, but i suggest draining and refilling since it hasn't been circulated in so long. Probably some seperation taking place, but it is probably safe enough to make it back home before switching.
-Check belts for corrossion and dry rot. (unlikely)
Other than that you should be good. i would wait till the car fully warms up, and oil pressure levels off before trying the A/C out.
Old Sep 7, 2007 | 11:30 AM
FastZ33's Avatar
FastZ33
just do it and see what happens
Old Sep 7, 2007 | 11:49 AM
soldierboy's Avatar
soldierboy
Thanks for all of the comments.......... hopefully nothing is bad....
Old Sep 7, 2007 | 11:52 AM
mpowers's Avatar
mpowers
#1&2 are very important!
Old Sep 7, 2007 | 02:31 PM
e-tkt's Avatar
e-tkt
Expect some flat spots on the tires to work out.
Turn the A/c pump on to lube the seals.
Enjoy!
Old Sep 7, 2007 | 06:01 PM
blazed54's Avatar
blazed54
Old Sep 7, 2007 | 06:03 PM
Jay'Z's Avatar
Jay'Z
I just hooked my battery back up and screwed in my fuel cap.. Started her up and she was good to go!!
Old Sep 7, 2007 | 06:27 PM
illjim69's Avatar
illjim69
just getting home huh? gotta love those new 15 month deployments! *gag*
i agree with everyone above. especially with the hug thing.......poor car missed you i am sure.
jim
Old Sep 7, 2007 | 10:19 PM
pln2311's Avatar
pln2311
Sucks you were gone so long man. Thanks for going over there.
Old Sep 7, 2007 | 11:50 PM
soldierboy's Avatar
soldierboy
Yup!.... one of those units that got extended to15 months due to the Troop Surge by Patreus.... oh well, I am home soon..
Old Sep 8, 2007 | 03:44 PM
Eliane's Avatar
Eliane
Charge your battery.
Old Sep 8, 2007 | 05:37 PM
sporkdevil's Avatar
sporkdevil
15 months?
First thing: Good whiskey!
But I would recommend most of these things. I'm not sure so much about coolant gumming up, but I know gas will go bad, and your battery will die. Oil change is a great idea too, you can't be too careful with an engine, so I would recommend the little bit of extra work.
Lastly, thanks for serving, I'm glad you are coming back OK. My little brother's best friend just shipped out Tuesday with the marines for his first tour over there, and we're hoping he comes back OK.
lapham3
Oct 7, 2022 03:15 PM
Mattg350z
Oct 2, 2015 06:51 AM
Tochigi_236
Sep 27, 2015 03:40 PM
