06.5 vs 06
Old Sep 8, 2007 | 10:16 PM
13SECZ's Avatar
13SECZ
Default 06.5 vs 06
....is their really an 06.5...im tired of people posting they have one...or are the genuine and if so whats the difference..or are they just crazy
Old Sep 8, 2007 | 11:02 PM
Kevins350z's Avatar
Kevins350z
i think there is an upgrade on the brake after march 2006? i am not sure though but if you go check out courtesynissan's web site under brake section then you will know what i'm talking about.
Old Sep 8, 2007 | 11:06 PM
surfcity40's Avatar
surfcity40
the 6.5 is obviously the new rings. One can't buy one, one has to inherit one from the service department.
Old Sep 8, 2007 | 11:19 PM
13SECZ's Avatar
13SECZ
So you cannot get a .5..but if your motor is bad and they fix it..or an oil consump problem then you get one..is that what you say
Old Sep 8, 2007 | 11:55 PM
t1m1t's Avatar
t1m1t
my manual says 2006.5 on it
Old Sep 9, 2007 | 12:23 AM
surfcity40's Avatar
surfcity40
this seems futile. the rev up (between the 05 and 07) is a motor with bad rings. the dealer is coming around and seems to be coming to terms with fixing a motor that burns a quart every 300 miles. stay tuned and look for a TSB. jmo
Old Sep 9, 2007 | 05:07 AM
EvanV's Avatar
EvanV
2006.5 has the advanced airbag system... Says so right on the manual.
Old Sep 9, 2007 | 05:15 AM
It is silly. Like the 2004.0 and 2004.5. Where the 2004.5 has knee pads. Oh boy!
Old Sep 9, 2007 | 05:19 AM
Z04's Avatar
Z04
stupid marketing ploy to make people think they are actually getting something better
Old Sep 9, 2007 | 05:45 AM
DavesZ#3's Avatar
DavesZ#3
Actually, the 2004 is essentially the same as the 2003. The 2004.5 is when the changes that fixed some of the issues with the 2003's were implemented, hence the designations.
And it worked! They got better airbags than the 2006 cars came with.
Old Sep 9, 2007 | 08:30 AM
13SECZ's Avatar
13SECZ
So better air bags and brakes..
so basically im driving and unsafe non stoppable z...lol
oh w/a bad motor...
At least it looks good
my motor doesnt burn oil...so thats safe...
Old Sep 9, 2007 | 08:38 AM
SniperHunter's Avatar
SniperHunter
I think the brakes saw an upgrade for all 2006s, not just the 2006.5. 2006.5 Zs have the airbag system, as mentioned before. It won't deploy an airbag if the seat detects a driver/passenger less than 100lbs. Oh, and they've also got an additional 2 cup-holders for 2006.5s.
Old Sep 9, 2007 | 08:48 AM
EvanV's Avatar
EvanV
Where are the additional 2 cup holders? I have a 2006, so just curious where they would be on the 2006.5.
Old Sep 9, 2007 | 09:01 AM
bluespecv03's Avatar
bluespecv03
I have a late 2005 build date 06, and I have 4 cup holders. The 2 in the center console, and one on each door. I can't really think of anywhere else they could put cupholders, and for that matter, why you would need more than 4 in a 2 seater...
Old Sep 9, 2007 | 10:55 AM
SniperHunter
I think two more slide out from the passenger dash. It's crazy, I know.
Old Sep 9, 2007 | 11:42 AM
RBlover69's Avatar
RBlover69
suspenison on the shocks also changed on the 06.5. I knw when i changed my springs...i found out the hard way with my shop. The 06.5 have the same suspension setup nearly identical of the 07.
Old Sep 9, 2007 | 05:24 PM
t1m1t's Avatar
t1m1t
hmmm... can't seem to find them on mine...
Old Sep 9, 2007 | 05:44 PM
RBlover69's Avatar
RBlover69
my manual also says 06.5 , so yes there is .
Old Sep 9, 2007 | 06:38 PM
Shadrackc's Avatar
Shadrackc
On the 07 there are 2 cup holders in the sliding door in the center, 2 in the lifting door behind it, and a bottle holder in each door.
Old Sep 9, 2007 | 06:47 PM
DavesZ#3's Avatar
DavesZ#3
Hmmm - that interesting because Courtesy Nissan's online OEM parts catalog only has one set of parts listed for 2003 through 2007 front suspension:
http://www.courtesyparts.com/betasit...5_800_802.html
There is a difference in the rear suspensions between the 2003 and other years:
http://www.courtesyparts.com/betasit...5_800_804.html
