Has anyone gotten a oil change at the Nissan dealer?
Old Sep 10, 2007 | 12:28 PM
I1DER's Avatar
I1DER
My Nissan Dealer uses a synthetic blend. Including the discount for having it changed there regularly, it costs the same as at the Quick Lube, Jiffy Lube, etc. places. I patronize places that treat me fairly and my dealer has.
Old Sep 10, 2007 | 12:45 PM
Faluzure's Avatar
Faluzure
Originally Posted by Ghost Rider
You mentioned a Long Oil filter. What are the other types they dealership uses and why do you request the Long Oil Filter?
Just wondering b/c I go to the dealership as well and bring my own oil but they use their own filter. I am not sure which one they use or that I may have choices.
All I know is that there are 2 oil filters that Nissan had (back in 2004) that would fit the Z. There was a long filter and a short filter. I'm assuming the short filter were for other smaller cars, like the Sentra and the 2.5 Altima. The part number for the long filter is either 15208-VQ35DE or 15208-9E000. I can't remember exactly.
Both sizes will fit on the Z, but the long one was made especially for the Z. I don't want some rinky dink Sentra oil filter being put on my car. The reason I specifically request for it is just to remind the tech to put the long filter on my car. Both cost the same.
Old Sep 10, 2007 | 01:02 PM
ZUL8ER03Z's Avatar
ZUL8ER03Z
ya im a tech at nissan and the long filter ends with 9E000... the short filter numbers is 65FOO or 65FOA for the older shorty filters i believe. and we use a synthetic blend for all of our oil changes, supposed to be some pretty good stuff i guess.
Old Sep 11, 2007 | 11:20 AM
thekinn's Avatar
thekinn
Originally Posted by Faluzure
I always get my Z's oil changed at the dealer. The main reason I do it is because they do that 27-point inspection. That's basically a free check on my car every 3000 miles.
Aside from that, I bring my own oil and request that they use the Long Oil Filter from Nissan. The oil I buy is Mobil1 Synthetic and the dealer has no problems using whatever oil I bring.
They only charge me like, $18 for labor & filter when they do my oil change. Combine that with the cost of my own oil, it comes out to $38 + tax. Not bad for a free inspection every 3K miles with good oil & peace of mind.
FYI
You shouldn't be so confident in Nissan's 27pt inspection. After 13k miles I was curious about my air filter - there were a bunch of dead leaves in the air duct and the filter was filthy - Nissan never mentioned anything. Who knows what else they ARE NOT checking..
I get my oil changed at the dealer because my driveway/garage is severely cracked, pitted and uneven.
Old Sep 11, 2007 | 11:28 AM
spf4000's Avatar
spf4000
1. Look at car to make sure it's there. Check
2. Kick tires to make sure they are still on the car. Check
3. Push button on keyfob to see if the car still locks/unlocks. Check
4. Open and close doors to makes sure people can get in/out of the car. Check
5. Turn steering wheel side to side to make sure the car steers. Check
6. Turn on engine to make sure the engine still runs. Check
etc...
There's a reason why its free.
Old Sep 11, 2007 | 11:36 AM
Faluzure's Avatar
Faluzure
Originally Posted by thekinn
FYI
Well, my dealer has been good to me thus far. So I'm crossing my fingers.
Old Sep 11, 2007 | 12:01 PM
Ruthless18x's Avatar
Ruthless18x
I always go to the Nissan dealer but I buy my own oil before hand. I still use the OEM Nissan filters but the total deal only costs 20 bucks.
Old Sep 11, 2007 | 01:12 PM
trodis's Avatar
trodis
etc...
F'ing Cheap *** Nissan
Old Sep 11, 2007 | 01:55 PM
JoeCz's Avatar
JoeCz
I took my 07 in yesterday for it's 1st oil change, which was free being it was the 1st one. Also I mentioned my Z had a bit of a pull to the right and they realigned my front and rear end. It was a great experience and I will take my Z there for all it's oil changes due to the fact that they know the Z and not wanting some slacker mess up my Z at quick lube...
Old Sep 11, 2007 | 06:52 PM
jabaz1's Avatar
jabaz1
Many dealerships are using recycled oil for routine changes. I asked a Ford service manager I know and he does.So when I took my Z in to have the oil changed at the Nissan dealership I asked the service manger there.They also use recycled oil. They claim it is as good as vigin dino oil.I'm a bit skeptical about that.
Old Sep 11, 2007 | 08:22 PM
trains1937's Avatar
trains1937
Having my oil changed at the dealer. Cost $30.
Old Sep 11, 2007 | 10:27 PM
Dui-Dan's Avatar
Dui-Dan
my dealership rocks, theyve fixed a bunch of little things for no charge, and i get it washed, vacuumed, and an oil change for about 50 bucks. i had one warranty claim with them too that went flawlessly. ive heard some horror stories from the nissan dealership some 20 miles south of here though... kinda messed up
Old Sep 12, 2007 | 02:56 AM
Key Of Z's Avatar
Key Of Z
27 point inspection!
Old Sep 12, 2007 | 03:25 AM
Ilov350ZEE's Avatar
Ilov350ZEE
when i installed plenum spacer i stopped taking my car in, i changed my own oil.
Old Sep 12, 2007 | 01:19 PM
SargentZ's Avatar
SargentZ
I change my own for about 20 bucks. You can use either the long or the short filter, both work. I also do my own 32 'point inspection' Hah!
Old Sep 12, 2007 | 01:24 PM
Marino Z's Avatar
Marino Z
Know it all
etc...
Old Sep 12, 2007 | 01:29 PM
zprincess's Avatar
zprincess
I have the dealer change the oil. The car has a warranty and this keeps it in place. Quite frankly, the dealer labor rates are pretty much the same as other shops without the Nissan training. Why would you want to go anywhere else? Plus they keep a record of all the maintenance and repairs.
Old Sep 12, 2007 | 01:44 PM
  #38
sluggoZ's Avatar
sluggoZ
Wrong!! I checked on the cost of a plenum spacer kit to be installed:
1. Nissan dealer $200 plus tax
2. Near by shop $76 plus tax
3. I ended up doing the install with my buddy...cost..$12 for lunch!
Old Sep 12, 2007 | 01:50 PM
  #39
stogey420time's Avatar
stogey420time
Club Moderator
the Hot Spot
Before i totaled my 05 PPW....i'd always took it to the stealership $30 - $40 in Texas but refuse the car wash though, nobody touch my b!tch but
me
Finally changed the oil myself so no more dealership
Old Sep 12, 2007 | 03:55 PM
  #40
HitLines's Avatar
HitLines
I run full synthetic oil because it's not that much more. I get a ton of "free oil change" coupons to Firestone and local places then use it to upgrade to synthetic. Usually costs around $18 after the "free" coupon. See fatwallet.com and like sites for those type of deals. Firestone will also send out oil change coupons which can also be upgraded. Using the coupon plus the upgrade usually costs about the same as regular oil without the coupon.
