I thought the point was to shift at the peak of the horsepower curve because that is what is accelereting your car. So that would make the stock DE shiftpoint around 6200, right?
Yes peak horsepower is a consideration. But more important is where are you coming into the next gear? 3,000 RPM? 5,000 RPM? If you push the motor past peak horsepower, you can come into the next gear a bit higher.
1st gear is a bit unique. If traction is poor, I will often short shift 1st. No point sitting there with the tires spinning.
You'd still want to redline, because the engine will continue making that peak power for the next 300RPMs - there isn't a catastrophic drop in power.
What about driving at high (above 5K) rpms for extended periods of time... As in going over mountains... Is that terrible for the car?
Any rpm below red line can be maintained non-stop for hours with no detrimental effect to the engine or any other part of the car. Below red line, anything goes! Aha!
Daily driving I shift around 3.5K RPM, spirited driving I shift around 5K RPM, but I'm not racing and I'm not on the track. I'm not sure where my torque peaks but it feels like around 4.5K RPM?
