why is LSD (Limited slip Diff) so important on an entus 350Z versus a base 350Z??
Old Jun 10, 2003 | 09:55 PM
misel00's Avatar
misel00
Default why is LSD (Limited slip Diff) so important on an entus 350Z versus a base 350Z??
is it for traction, better acelleration??? Thanks agian for your help everyone...why would no one get a base because it does not have LSD>>>?
Old Jun 10, 2003 | 10:10 PM
350zroadster's Avatar
350zroadster
it's for traction.
as you are turning, your inside wheel is traveling less than your outside wheel, a better differential would transmit power properly to the wheels
Old Jun 10, 2003 | 10:56 PM
ares's Avatar
ares
Veteran
think of it this way, if youve ever messed with RC cars, or a regular car on a jack(and your strong). you spin one wheel, the other will spin the opposite way. now start the car, and magicly stop one wheel, the other will spin twice as fast.
ok, well stopping the wheel could be considered traction, and the other will just spin twice as fast, putting very little power to the wheel that has traction.
LSD senses this(I think by heat) and immediatly locks up the differential and forces both tires to turn(like a solid axle would).
why not just have a solid axle then? cause for one, handling, no good. and taking turns, the inside tire has to spin slower, a solid axle does not make provisions for this. a LIMITED slip diff will let one tire spin slightly slower than the other.
Old Jun 10, 2003 | 11:32 PM
misel00's Avatar
misel00
Thanks for the great explanation!
Old Jun 10, 2003 | 11:50 PM
honoluluZ's Avatar
honoluluZ
Question "If you ask They will Come"
Thanks Ares,
What will be the advantages and disadvanteges if you want to add super mods like a super charger/turbo/NOS?
Will one system be able to handle more tourqe and will they have a different feel?
Graci
"Where's da Mots"
Old Jun 11, 2003 | 04:38 AM
VandyZ's Avatar
VandyZ
if you want to know, the VLSD on our cars kind of suck.
Old Jun 11, 2003 | 07:39 PM
jesseenglish's Avatar
jesseenglish
I think the main benefit of having LSD is not looking like a moron when you do a burnout and you've only got one tire spinning.
Old Dec 2, 2011 | 11:27 AM
titanium777's Avatar
titanium777
Great definition. Although the stock VLSD on the Z's aren't exactly top notch
Old Dec 2, 2011 | 12:10 PM
John1006's Avatar
John1006
Doesn't it sense that it's slipping by those 2 sensors on the rear axles?
Old Dec 2, 2011 | 12:22 PM
graffkid732's Avatar
graffkid732
You guys know this thread is only 8.5 years old...Right?
Old Dec 2, 2011 | 01:08 PM
ColecatZ's Avatar
ColecatZ
LOL @ necroposters
Old Dec 2, 2011 | 01:27 PM
PerfZ's Avatar
PerfZ
Ahhh, where would we all be without newbies, lol? Hey, at least they didn't start a new thread, gotta give them that.
Old Dec 2, 2011 | 02:02 PM
Blueknight007's Avatar
Blueknight007
braaaaaaaaainnnssssss
BTW we should get a zombie smiley for time like these, how about it?
Old Dec 2, 2011 | 05:04 PM
mr. sparco's Avatar
mr. sparco
Very noticeable on uneven roads, the car without LSD if diagonally crossing a dip, will get stuck at slow speeds if one wheel were to be lifted up. It's not just for cornering, I've gone off-roading before (in a different car).
Old Dec 3, 2011 | 01:44 PM
John1006's Avatar
John1006
AH man what a fail, from 03! why didnt i notice lol
Old Dec 3, 2011 | 01:49 PM
SirSpeedyZ's Avatar
SirSpeedyZ
whats with all the newbs raising old threads around here?
Old Dec 3, 2011 | 02:01 PM
Emski's Avatar
Emski
Like someone said before, better than them starting new thread. Great job using search function I say.
Old Dec 3, 2011 | 02:18 PM
J 0 K 3 R's Avatar
J 0 K 3 R
dude this isnt even close to correct. dont listen to this bs. solid axle has nothing to do with anything. BOTH solid axle cars (mustangs-silverados) and IRS cars can have open diffs, lsd difs, posi trak difs, full time lockers, electric lockers, or welded difs.
you want lsd on a solid axle or IRS because when it senses a tire slipping the dif will lock up temporarily and apply even power to both wheels. I believe it can make this decission to lock and unlock x amount of times a second depending on how advanced the lsd is.
Old Dec 3, 2011 | 04:14 PM
terrasmak's Avatar
Do you know the difference between solid axle and straight axle?
A 350Z can have a solid axle.
Mustangs and Silverados as you mention come as straight axle, they can also be converted to solid just like a Z.
Old Dec 3, 2011 | 11:55 PM
TheVengefulCo's Avatar
TheVengefulCo
LSD equals MUCH better traction. Even though the LSD in the Z is a viscous LSD it makes traction much better. It helps with drifting and turning sharp and even for launching the car it is better. Plus, doing a burnout just looks stupid with 90 percent of the smoke coming from one tire.
