Significant decrease in MPG - root cause?
Old Jan 22, 2008 | 06:31 AM
Britx's Avatar
Britx
No. Actually you should do that, but it does factor into total average mpg. I have always let my car warm up. My basic rule of thumb is not to let the oil pressure get over 90psi in the morning and let it idle for about 5 min. or more before driving. I actually use the oil pressure guage as my tach.
Old Jan 22, 2008 | 07:27 AM
maxpowers's Avatar
maxpowers
I would agree that its the colder temps. You burn a lot more fuel at startup when the vehicle is in sub zero temps (remember pulling out the choke in the old days).
Old Jan 22, 2008 | 07:44 AM
sno's Avatar
sno
Winter blend gas is the biggest problem, relating to overall mpg. I saw, at least, a 75 mile decrease in total miles for a full tank. That, and idling (or warming up) the car in the cold mornings burns gas without any mileage.
Old Jan 22, 2008 | 11:54 AM
Silkk's Avatar
Silkk
I thought it may be the weather! Glad you guys confirmed...
The car definitely doesn't like to start on cold mornings - my garage isn't heated. But hey, at least I have a garage, I suppose.
Still doing the preventive maintenance though as necessary... Thanks again guys.
Old Jan 22, 2008 | 12:16 PM
meaj82's Avatar
meaj82
+1 I have been noticing that this past month. I have been going through my tank a lot more faster than ususal.
Old Jan 22, 2008 | 12:53 PM
Gooey's Avatar
Gooey
Man Im lucky to get 17mph....I usually average somewhere around 15-16mpg. Damn my lead foot.
Old Jan 22, 2008 | 01:40 PM
whitetrack's Avatar
whitetrack
Ethenol blend reduces MPG. That happens to all my cars, not just the Z. Plus a little of what everyone else mentioned.
Old Jan 22, 2008 | 01:44 PM
iStan's Avatar
iStan
ZR
14.3 on the streets. Damn you boost and 275 Tires Oh and warm up time kinda kills it to.
Old Jan 22, 2008 | 01:45 PM
r_seng's Avatar
r_seng
as i said before, its the weather, my over all mpg per fill-up has tanked about 06 - 70 miles less.
Old Jan 22, 2008 | 03:33 PM
ZTMYDUST's Avatar
ZTMYDUST
I didn't notice a change in mpg with my Z when the temps dropped here in Western, NY but i took my Z off the road in November (wishes he was from PA, atleast they don't use materials on the road that lead to rust ie:salt).
Old Jan 22, 2008 | 03:48 PM
iceburns288's Avatar
iceburns288
It may also be due to the fact you are using the heater more due to the cold- this would decrease your mileage.
Old Jan 22, 2008 | 03:59 PM
DavesZ#3's Avatar
DavesZ#3
Originally Posted by bailey bill
You will always get lower mileage in colder weather.
1) The ECU sets a richer A/F as temps drop
2) Winter blend gasolines also result in increased fuel usage.
bill
I thought the mix was richened when the temperatures get hot to help prevent detonation, not the other way around.
Old Jan 22, 2008 | 04:19 PM
Silkk's Avatar
Silkk
I'm pretty sure our roads get salted also, so no big advantage to moving here. Plus our roads are $hit...
Old Jan 22, 2008 | 04:30 PM
sk26dett's Avatar
sk26dett
On a side note, The digital gauge is actually pretty good (to my surprise). I calculated my MPG manually and it was within .1 of what the gauge said.
The speedometer on the other hand isn't as accurate. At low speeds like below 50 its almost dead on. Between 70-90 mph it reads between 2-3 mph high. Over 100 it's more than 4-5 mph high, and increases as you go faster. (All assuming that the GPS speedometer in my head unit is accurate)
Old Jan 22, 2008 | 05:57 PM
MA4's Avatar
MA4
I was getting bad fuel economy...turns out my pop-charger was filfthy...I cleaned it and oiled it up, now MPGs are back to normal.
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
nanotech
Oct 2, 2015 05:02 AM
codek
Sep 28, 2015 03:03 AM
FromGtoZ
Sep 20, 2015 03:41 PM
