60+hp for just 8.69 plus shipping
http://cgi.ebay.com/ebaymotors/PERFO...mZ360024035176
ill fight anyone that doesnt believe this works.
Guest
Posts: n/a
Wow for only 8.95 it does all of this:
- 60+ Horsepower (65-70+ HP on trucks and SUV's)
- 60+ Ft. lbs of Torque ( 65-70+ HP on trucks and SUV's)
- 20+ MPG better fuel Efficiency GUARANTEED!
- Faster Acceleration
- Faster Track times
- Improved 1/4 and 1/8th mile track times
- Better mid-range acceleration
- Higher Top-End power
- Increased towing power
- Smoother shifting (Automatic and manual transmissions)
- Smoother Idle
- Extends the life of your spark plugs
- Extends the time between costly engine Tune-ups
- More low end torque
- 75%+ Quicker throttle response time
- Cleaner Engine Heads
- Cleaner and faster revs
- Higher Top-Speed and Improved Top-End Torque
- Better Climbing ability
- Improved HP and Torque Output in High Altitude Areas where the air is thin
- Increased Passing Ability
- Better and Crisp throttle response
- Circuit Protection
- Better Mid-High RPM Revs
- Helps your vehicle to Pass SMOG and EMISSIONS Regulations
- Street Legal Everywhere
- Pays for itself by saving gas
- Cleaner Spark Plugs ( Less repairs and tune-ups )
- Cleaner Engine heads ( Less repairs )
- Lengthens the life of your engine belts by reducing Engine RPM's
- Smoother Power in all power band levels
- Causes less stress on your engine, making your engine last even longer
- Dyno Proven
- Extends the life of your oil and extends the life of your oil between oil changes
- Smoother Idle
- Dyno Proven
Guest
Posts: n/a
The best part is this horsesh!t lie:
How our module works:
Since 1998 we have been producing performance chips. In 1995 we purchased all of the performance chips currently available on the market. We found that each performance chip that we used had given us a performance gain in some way or another. We had run over 300 times on a dynamometer using the same vehicle with only one different variable, the different performance chip. After seeing that the average cost of the performance chip was over $300 we wondered how are these chips made. We then spent the next two years researching and through experienced electrical technicians we had discovered the SECRET. We then created 500 prototype performance chips and placed them on 500 different vehicles for testing. With a 100% success rate on every vehicle and not one of them failing we decided to offer our performance chips to our local area for sale. We have now sold over 1 million chips to our local area and throughout the USA. We have recently made some changes and decided to sell our performance chips on eBay. Since 1990, fuel injection has been in every vehicle produced. Fuel injected vehicles run on a ECU or PCM board which are basically fancy terms for a computer. We have studied and figured out that every vehicle from the car manufacturers runs rich from the factory. Your vehicle's performance relies on an Air/Fuel ratio in order to function properly. The air/fuel ratio runs at 3 different levels: Rich, Stoich and Lean. The vehicle manufacturers try to produce as much power as possible without sacrificing engine reliability, better gas mileage and the mileage between tune-ups. Our job was to figure out how to produce more power and give better gas mileage at the same time. When your vehicle is running rich you are wasting gas. For example: If you have ever seen a person accelerating quickly you may have seen black smoke coming from the back of the car, this is NORMAL. The black smoke is un-burnt fuel coming out in a liquid/gas form. This un-burnt fuel should stay in your gas tank. There is no need to throw money out the window. When your air/fuel ratio runs at stoichometric levels you are getting optimum performance along with better gas mileage. Our performance chip will allow your vehicle to run at stoichometric levels at all times! You will not need to use premium fuel although it does help our chip work even better! We are offering the current price on eBay as an introductory price and the price will go up. We are also offering a 100% money back guarantee to prove to each and every one of our valuable customers that this will give you more horsepower and save you gas money each time you go to the pump. Try one today, you cannot go wrong with our 100% hassle-free money back guarantee!
Originally Posted by 03Zilverstone
Can I use one per cylinder and gain 360HP? That's at the wheels too right? I'm definatly in. Beats going turbo.
Originally Posted by TreeFiddyZee
I'm pretty sure it's exponential. If you add 2, you'll get an extra 3600 horsepower. 3500 if you account for friction loss and gravitational pull.
Wow. I wonder if it then doubles with the Turbonator supporting mod.
Guest
Posts: n/a
https://my350z.com/forum/showthread....hlight=tornado
Originally Posted by dave079
You are in luck. This guy is selling a tornado. (close enough)
That won't work. That's an aluminum replica. You have to have the Turbonator......titanium baby.
