Having Trouble With Manual...
Old Feb 24, 2008 | 04:56 PM
TUNER350's Avatar
TUNER350
Originally Posted by VQpoweredZ
Thanks guys. This is what I have been doing, getting the car moving without the clutch going downhill/on flat ground. This works fairly well, but my teacher said people behind you might get pissed off cuz your going so slow. But as for the hills, that cannot be done and thats where my giving gas, is a problem. I get up the hill i cant assure you but its with a small burnout, I need to learn how to give it the right amount of gas. I dont know about that, thats attempted after I get down the basics.
okay heres how i was taught when i first learned and ill try my really hardest to explain this right using words but remember you have to have the stalling part(i.e. letting off the clutch and pressing on the gas) correctly down
Hills:
When you arrive at the hill press in the clutch and put your foot on the brake.
When you come to a complete stop with your foot still on the brake/clutch pull the ebrake.
When the light turns green(remember car in first!!)remove foot from brake and apply to gas upping the revs and lifting your foot off the gas and now at the same time take your right hand and as you press in the gas and lift your foot off the clutch slowly lower the ebrake until its fully down and by then youll be passing through the light!!
i know its a cheaters method but until i got driving a manual down i used and still use it on some hills every now and then....hope this helps
edit:btw before you first do this on a hill practice on a flat surface to get the timing down
Old Feb 24, 2008 | 05:08 PM
JDMFairladyZ33's Avatar
JDMFairladyZ33
Just remember one simple concept: The left and right foot generally are opposite. When the left goes down (clutch), the right comes up (gas). Vice Versa.
Also when in trouble put the clutch and brake down. It doesnt matter what gear you are in or trying to get to. Put the clutch down, stop the car, throw it in neutral then 1st and start over. Practice makes perfect. As for hills.... well master getting it out of the driveway and down the street first. Good luck.
Old Feb 24, 2008 | 05:17 PM
VQpoweredZ's Avatar
VQpoweredZ
I will try all these tips. Thanks alot guys. As I thought I was getting everything down, and what do you know the 2 hours were up, if I wanted another 2 hours it would have been another 108 bucks. Please keep the tips coming.
Old Feb 24, 2008 | 05:25 PM
moflow's Avatar
moflow
Dont panic, I promise you'll be fine within 2 weeks. In 3 months you'll hardly be able to believe you used to be unable to drive a manual.
you made the right choice.
Old Feb 24, 2008 | 05:49 PM
blazed54's Avatar
blazed54
just keep practicing. i'm sure a lot of people will agree that once you learn how to drive manual on a Z, almost all other cars will be EASY. haha try drive an impreza, I drove my friend's 06 5spd impreza and that car is easy. no need to release clutch at just the right time from 1st to 2nd for smooth shifting like in the Z, you just clutch in and clutch out no problems.
Old Feb 24, 2008 | 06:51 PM
sry110's Avatar
sry110
To the OP, where in PA are you? I could teach you to drive your car for much less than $108 for two hours : )
Old Feb 24, 2008 | 07:03 PM
SeannMikee's Avatar
SeannMikee
The 350 is more difficult to learn on against most other cars, so you master the Z, you can drive anything. Just gotta learn the engagement point.
Old Feb 24, 2008 | 07:09 PM
Did you guys have these problems when you first started out?
Yes. 40 years ago. There is little point in reading about driving. Just get out there and drive. Soon you will be shifting like a pro.
Old Feb 24, 2008 | 07:11 PM
3fittyBiH's Avatar
3fittyBiH
with all due respect sir, you are ****n retarded
Old Feb 24, 2008 | 07:13 PM
Then they are just going to have to be patient.
SiNzz's Avatar
SiNzz
^ That he can't drive manual? I don't understand how that could make him retarded. It's not like any of us were born with the innate ability to drive stick right off the bat. Some just learn later than others.
Old Feb 24, 2008 | 07:15 PM
LOL. What did I miss?
Old Feb 24, 2008 | 07:19 PM
Maybe the “retarded” comment was for me?
Old Feb 24, 2008 | 07:21 PM
Willie's Avatar
Willie
But your comment seemed sensible.
Old Feb 24, 2008 | 07:28 PM
trains1937's Avatar
trains1937
Yes. 50 years ago. You gotta do it if you want to do it. Practice and more practice. There was a time when anyone who wanted to drive had to learn how to use a stick and virtually all of them succeeded. You will too. And so it goes........
Old Feb 24, 2008 | 07:47 PM
350x04's Avatar
350x04
Just make sure you take your time, it's difficult when you rush.
Old Feb 24, 2008 | 07:55 PM
NISMO_558's Avatar
NISMO_558
I learned a manual for the first time in my Z, it took me a few days to get used to it and another week or so to get pretty good at it. It just takes some time, keep practicing to find that sweet spot
Old Feb 24, 2008 | 08:14 PM
  #38
blazefast's Avatar
blazefast
Hang in there, man. You'll get it!
I had very limited m/t experience when I picked up my Z in early January of this year. Now, 7 weeks and 4000 miles (a lot, I know) later, I'm pretty proficient. The first week is always the toughest, but as others have said, you'll be so glad you stuck it out.
Depending on where you are in PA, we could meet in the middle and I could give you some lessons for the price of gas.
Old Feb 24, 2008 | 08:18 PM
  #39
Naper-Z's Avatar
Naper-Z
I just bought a 2007 MT "Z" in October, and it had been 13 years since I had driven a stick shift. It took me about a month before I felt comfortable again. Just relax and practice. What a chore that is - driving a Z! Give yourself a few months and you will laugh at it. As far engine speed when letting out the clutch, try keeping the revs at 2-3K. I think the "Z" is a pretty good MT to shift, of course I am camparing to my Dad's '78 Camaro Z-28, which was a very notchy shifter.
Old Feb 24, 2008 | 08:19 PM
  #40
seZy350's Avatar
seZy350
17 yrs old and learning to drive stick for the first time on a Z? dont want to sound like an ***, but if i was still in the process of learning how to drive stick id start off with a lil beater...17 + first time driving stick + Z = asking for trouble..its just like if youre learning to ride a bike.. youd start off with a 250 and not jump to like a 750.. i dunno maybe im just jealous..cuz youre 17 and you all ready have a Z but anyways gl with the driving.
