Car wont take Gas!
Old Apr 24, 2008 | 06:12 AM
  #61
Nismo350Z_00's Avatar
Nismo350Z_00
this is not the gas pump, lol. it happens to me every time i fill up no matter where i go. I usually have to hold it at about halfway to get it to take.
Old Apr 24, 2008 | 06:20 PM
  #62
hotrod06's Avatar
hotrod06
Originally Posted by bmaiZ
Lucky!
LUCKY Yes maybe but seems the harder i work at getting something done the luckier i get
Old Apr 24, 2008 | 08:18 PM
  #63
Gary1107's Avatar
Gary1107
Thanks, I'll try that upside down method. I've been pumping at an angle and low flow but even if I move a little bit it will stop...
Old Apr 25, 2008 | 03:05 AM
  #64
SpeedRcr's Avatar
SpeedRcr
Originally Posted by wannabuy350z
Hello All,
I am trying to figure out what the problem. i did a search on this topic and found nothing. my last two fill ups (pumped like 50 time to fill up) is very annoying. here is the issue, I cant just insert the nozzle and set the pump and wait, it only pumps lke .5 gallon at a time. I shake the car, look for leaks, i cant find anything. I called the dealer and they said my VIN was not in the recall list at all.
any of you expierenced this?
you sure you searched because its a known issue with the flutter valve in the fuel tank and there was a recall...
Old Apr 25, 2008 | 06:41 AM
  #65
fuzzy_dba's Avatar
fuzzy_dba
What I found that did work is to keep the pump hose pointing toward the rear of car, handle parallel to the ground. The pump can go full force and it shuts off normally.
Thanks to all!
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
pslamp32
Feb 8, 2017 09:07 AM
CJs_Z33
Sep 18, 2015 12:06 PM
Bigsyke
Sep 11, 2015 06:19 PM
