RPM Shift
Old Jul 11, 2003 | 08:24 PM
DMD's Avatar
DMD
Default RPM Shift
At what RPM do you guys shift? It seems I always chirp the tires going from 1st to 2nd, and 2nd to 3rd.....
Old Jul 11, 2003 | 10:02 PM
Silver Bullit II's Avatar
Silver Bullit II
Default I have the same problem...
so I shift at 1200 rpm all the time, I think I'm going 30 mph in 6th gear, hope that helps.
JMS in TX
Old Jul 12, 2003 | 12:48 PM
Zsilverstone13's Avatar
Zsilverstone13
I think I really need to change my driving style. I always shift at around 2500 rpm for normal driving, which is a lot lower than when I was driving the RSX(3300rpm).
Old Jul 12, 2003 | 01:04 PM
DMD's Avatar
DMD
You cant be serious, you guys drive a 350z and shift around 2500, even during agressive driving? I usually shift around 5K
Old Jul 12, 2003 | 01:09 PM
bhobson333's Avatar
bhobson333
Default GOT to be kidding!
Once it's warmed up I normally run up to 5000 if I'm taking it easy, 6000 if I'm pushing it. I rarely or never chirp the wheels because I feather the clutch. If you're chirping, you're letting the clutch out too fast.
Old Jul 12, 2003 | 01:36 PM
ChadO's Avatar
ChadO
Default Re: I have the same problem...
JMS in TX
1200rpm, wth?
Old Jul 12, 2003 | 01:50 PM
DMD's Avatar
DMD
Another quick question do you guys let up on the gas while shifting or keep the rpm's rev'd up to try to match?
Old Jul 12, 2003 | 09:44 PM
hk350's Avatar
hk350
i got this 1 problem i get. (well only happened 2 me once)
but when i was pushin my car. racing a wrx( a friend of mine).
i shift around 5000rpm. after hitting 5th gear. i stopped and slowed. down. and i smelled something burning. i 'm thinking its my clutch.
is it tat i'm letting the clutch out 2 fast? or am i ridding the clutch?
plz help. i'm very worried tat i burnt my clutch.
Old Jul 13, 2003 | 05:13 AM
Intrepid175's Avatar
Intrepid175
My guess is that you're riding the clutch. In the heat of the moment, most tend to hold their foot on top of the clutch peddle which is Ok to a point. The problem is, they're still applying pressure which keeps the clutch for engaging fully. The resulting slippage is what's causing the burnt smell you're noticing.
Best way to avoid this is to consciously put our left foot on the floor between shifts. It feels awkward at first but you'll get used to it and it goes a long way toward improving clutch life.
FWIW,
Drive Safe,
Steve R.
Old Jul 13, 2003 | 07:54 AM
Buub's Avatar
Buub
I always try to rev match and slip the clutch. Even in "regular" cars like my girlfriend's old Accord. It just makes for smoother driving, and it's a good habit to get into.
Old Jul 13, 2003 | 08:13 AM
jj1814's Avatar
jj1814
3-4K works fine for me. She goes just fine.
And i blip the trottle to rev match.
Old Jul 13, 2003 | 08:15 AM
ares's Avatar
ares
Veteran
mine chirp between 1 and 2 when I intend to push the boundaries. I mean 6600 RPM shift, fast, and the revs cant drop fast enough.
standard driving, I release the gas somewhat so that it drops to the right amount, then let the clutch out smoothly, not really slow, just smooth. tires should not ever even come close to peeling or you are continuously doing something incorrect. a little jerking isnt bad, just annoying. but so much that your chirping... change your method. hard to say how exactly without driving with you.
best bet, find a friend or something that knows how to drive manual well. have him drive with you and he can likely diagnose your problem quickly. its probably either your not letting off the gas and allowing the revs to match at all, or your letting the clutch out way to fast. maybe both. the tires dont chirp all that easily...
Old Jul 13, 2003 | 09:53 AM
DMD's Avatar
DMD
Hey I think I saw your Z around town today, I am in cincinnati also....were you drivin' it tricounty mall area?
Old Jul 13, 2003 | 11:13 AM
Gunnar's Avatar
Gunnar
I'm shifting at around 4000, or whenever I hear the engine working to a higher rev. However, when I drive it hard i'm shifting at around 5000, (which is not often).
I have this problem, I jerk it in first and sec. So I get that bounce thing, not bad though. Although sometimes it's smooth. I've been driving a clutch for years. I do it about 80% of the time I can't seem to figure it out where it actaully engages. Is it low or high?
Old Jul 13, 2003 | 03:42 PM
synth19's Avatar
synth19
I can not for the life of me get a total "SMOOTH" shift from 1st to second......... all other shifts I have mastered....... anyone else have this problem? I usually shift between 3k-4k...........
Old Jul 16, 2003 | 03:51 AM
Vicarious's Avatar
Vicarious
yep...1-2nd is bumpy, while 3+ is smooooooth. also i think i find that im the only doing this...but when u guys shift from gear to gear, do u guys let the clutch out slowly? cuz i kinda let it come out REALLY fast...basically just letting it go, but the change is REALLY smooth. i dont feel a thing. is this bad?
Old Jul 16, 2003 | 04:12 AM
AustinTX_350Z's Avatar
AustinTX_350Z
Vicarious - I think we have the same problem in our cars - need to go get that checked out.
Anyway, 1st and 2nd - around 2000 - 2500. 3rd and above: 3000 - 3500 - that's for normal city-driving. Add 1000+ more if I'm trying to accelerate quickly. I usually slip it into 6th around 65 - 70 mph, give or take.
As far as 1st and 2nd go ... same thing applies here Vicarious and synth19 ... I can get it in there smoothly if I shift at less than 2000.
This your first stick? It's the first one I've owned - I've driven other MT cars and I can shift a lot better in 1st gear on those than on the Z. It's the power ... I guess.
Happy driving! Let me know if you get to the dealership and get that damn clanking checked out!
Have a good one!
Old Jul 16, 2003 | 04:25 AM
Vicarious's Avatar
Vicarious
Austin - im probably going to go to the dealer in about 2 weeks because thats the only time i can spare not having a car in case that they have to keep it for awhile..hopefully brucela will find out what the problem is on friday and if its a big deal.
oh yeah, today i drove the Z and i think there is a connection between the smoothness of changing from 1st - 2nd gear because i tried to be as smooth as i could today from changing gear and it did not make that much noise at all...oh yeah, do u sometimes FEEL the clunk in the shift **** when it makes the clunk in going from 1st to 2nd?
Old Jul 16, 2003 | 04:43 AM
jleighZ's Avatar
jleighZ
I usually shift around 3k, any higher than that and the car starts screaming Going to 2nd though I have to shift around 2500 to make it smooth out a bit. I hate the 1-2 shift cause it is always so rough
