Changes to upcoming 350Z ‘04..’05..’06+
Originally posted by Vash350Z
black headlight housing would be a very nice addition, as well as the option of getting leather on the track model
Originally posted by xlr8ed1
Camber / Caster which was causing extreme Tire wear
Originally posted by OC_350Z
Or atleast a Brembo Brake option for the Touring. I would have been all over that.
Hi..
My engineer asked the same qustion.. What would a Simple camber only part be worth, he can knock out a prototype in four hours. Anyone have a stock Upper control arm to donate to this project. Whoever donates the upper control arm - gets one adjustable pair.
How is that for an offer...
CC: The unknown Engineer.. Ha !
Originally posted by krinkov
since the Z has no adjustment for camber/caster this would require changing half the suspension pieces. It will be interesting to see how they plan to do this without costing tons in retooling
JIC and at least one other comapny already make adjustable camber arms for the 350, thats the easy one since all you have to change is the legnth of a servicable part, but caster will require moving either the lower or uper control arm mounting points forward/backwards depending on which caster change is desired.
There is enough room to adjust the other in the stock unit.. It is a simple cam and lock down..
But the Camber need more adjustment room, or as I've been told.
If you want a fully adjustable, my crew can do that. But please be patient.. As the Engineer said Upper only - simple to dial in, is fine.
Cheers Amy
Cheers Amy
Cheers Amy
Cheers Amy
BTW, I just read they are going to be offering four wheel brembo option on SE-Rs for only $1000!!
Really? What size are they? I wonder if they would work on a Z
For 2004, the sport-inspired Sentra SE-R receives several body enhancements, including a new front and rear fascia, new headlamp shapes, restyled hood and two new exterior colors. The 2004 Sentra SE-R also upgrades its interior with a standard trip computer and a new charcoal fabric exclusive to SE-R models and adds an impressive Brembo“ Brake Package solely for the Sentra SE-R Spec V model.
Originally posted by Apexi350z
If nissan will have all new camber/caster for the 2004 Z, why won't they issue TSB for us 2003 Z owner?
In a long ago Post it was writen "A Nissan factory rep stated " the bounce problem would be fixed in the 2004 Model" "
What about us 2003 Z owner's
CS Touring Auto 17" wheels - Even with Eibach Springs - it can be a pain..
Cheers Amy
Im having trouble understanding what you are saying. "The other link for tuning is already adjustable" are you saying the stock upper control arms are already adjustable?
I'm sorry for confusing you... But caster changes on the rear, are not a large issue, unless for track only. The primary adjustment to be made is the Camber...
Do you copy?
The way JIC does it is to tweak the two trailing arms, rather than have one Upper Arm do the adjustment. For the geometry of the Z rear it is much easier to adjust one upper arm.
You do have one of those CD's with the service manual in PDF don't you? Read the suspension section....
Cheers Amer's
Man I wonder if those Brembo brakes of the V Spec can wrok on my auto coupe? I wonder what the 60-0 distace will be. I know the G35 at coupe is doing 120 and with the Brembos 113.
Mr. Krinkov...
Cheers Amer's
Mr. Krinkov...
Cheers Amer's
Hmm, it seems this whole time you have been refering to camber/caster changes to just the rear wheels and we were refering the front wheels since this is where the complaints of uneven tire wear are coming from, now your starting to make sense
liqalu04
Jan 2, 2022 12:58 PM
wanderingstuden
Jan 28, 2016 07:03 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
