why tirerack, jiffy lube, ez-lube, etc... are idiots.
Old Feb 26, 2009 | 05:34 PM
SoldzMyZ's Avatar
SoldzMyZ
Default why tirerack, jiffy lube, ez-lube, etc... are idiots.
got this in my email. Now imagine if I didn't know better. They make money, I'm out of money, and I've jacked up my tires.
Attached Thumbnails why tirerack, jiffy lube, ez-lube, etc... are idiots.-dfdfd.jpg
Old Feb 26, 2009 | 05:49 PM
Get_Zwole's Avatar
Get_Zwole
stock wheels on the 350z wont rotate they have a pin in the rotor to keep idiots like the jifi lubes from doing it. They are stupid though i went in for an oil change one day and i run 275's out back and 255's in font with 2 inch lip on wheels and almost 4 in the back the idiot asked me if i had rotated my tires in the past 6 months i just kinda stared at him.
Old Feb 26, 2009 | 06:10 PM
freedonutss's Avatar
freedonutss
I stick with discount tire. They always ask "Are you running a staggered setup"? They know the deal
Old Feb 26, 2009 | 08:00 PM
foreveryoung's Avatar
foreveryoung
How many of you peoples use Nitrogen in your tires???
Old Feb 27, 2009 | 02:17 AM
o6black350z's Avatar
o6black350z
YEah i had to take my pin out due to custom size wheels ... =/ but i thought same thing, smart nissan ppl to think of a quick and easy solution preventing idiots of doing something that was not ment to be done in first place ..
Old Feb 27, 2009 | 04:40 AM
PerfZ's Avatar
PerfZ
Not sure why you lumped TireRack in there - and not sure why the post to begin with. Most cars can, and should have tires rotated - I don't see where it says EVERY car should do it. It is up to the owner/driver of the car not to be the idiot, and to either take their Z to someplace better than Jiffy Lube (like how about your own garage?) or let the place know that the Z is not a typical soccer mom vehicle. My $.02
Old Feb 27, 2009 | 08:37 AM
Xlr82x's Avatar
Xlr82x
I would love to be there when a first timer try to rotate the tires like that and comes out and tells you something is wrong with your rotors or wheel because it wont sit right... I think i would die laughing....
Old Feb 27, 2009 | 09:01 AM
blktrack350's Avatar
blktrack350
I don’t trust any quick lube/tire places. I had an engine blow in my 3000gt because they didn’t tighten down my drain plug. And I have had 6 wheel studs cross threaded because they don’t hand tighten at first and just stick it on there with an air gun and go as tight as they can. But that’s what you get when you let idiot high school kids work on your car. 4 studs at palm tire and 2 at discount. so now i take off my wheels and have someone drive me up there
Old Feb 27, 2009 | 10:22 AM
mpcstuff's Avatar
mpcstuff
I do and it really does work.
Old Feb 27, 2009 | 10:24 AM
Motormouth's Avatar
Motormouth
side to side.
and they could still perform an air check.
Old Feb 27, 2009 | 11:25 AM
terrasmak's Avatar
03 to 05 non track 18's will rotate. They are the same wheels front and back.
Old Feb 27, 2009 | 11:27 AM
Nexx's Avatar
Nexx
i do +5whp
Old Feb 27, 2009 | 12:49 PM
PerfZ's Avatar
PerfZ
Wheels yes. Tires, not so much. And OEM tires are directional so no side to side
either.
Old Feb 27, 2009 | 02:53 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Originally Posted by Nexx
i do +5whp
Nexx is that all you got.....i picked up about 7+ per wheel.
Old Feb 27, 2009 | 05:07 PM
Get_Zwole's Avatar
Get_Zwole
yeah i guess thats true my bad.
On a similar note a buddy i knew in highschool had a wheel on his cobra almost pass him on the street they didnt tighten his luggnuts. on his cobra.
Old Feb 28, 2009 | 10:53 PM
Nexx's Avatar
Nexx
wtf, you must have used JDM nitrogen, im just using crappy USDM b.s. nitrogen.
Old Mar 1, 2009 | 11:34 AM
FLY BY Z's Avatar
FLY BY Z
You can rotate the tires, you just have to dismount and remount.
Old Mar 1, 2009 | 12:35 PM
dhays's Avatar
dhays
Depends on the tires. With the Potenza RE050s they are asymmetric so they can't be flipped (dismout/remount). The RE040s aren't so they can be flipped.
Old Mar 1, 2009 | 03:13 PM
bailey bill's Avatar
bailey bill
That was a popular Kenny Rogers song..."You picked a fine time to leave me, loose wheel..."
bill
Old Mar 1, 2009 | 04:49 PM
J350z101's Avatar
J350z101
discount tire ftw
