Shifting into 5th/6th
While test driving a 2003 Enthusiast 350Z, I remember a somewhat awkward shift from 4th to 5th, and then from 5th to 6th. This was because I could not simply push the stick all the way right until it stopped, and then up into 5th. Instead, I would push it all the way right, and it would sort of sit in a notch that wouldn't let it slide directly up into 5th. I had to move it very slightly left, off of the right wall and then upwards into 5th. It made shifting seem sort of odd, as I was "aiming" for 5th gear rather than moving the shifter right, and then up. I know this may sound confusing, so hopefully I described it well enough. Please let me know if anyone else has experience this.
I hope so, I guess it's just different than most so I was worried. Seems odd to not be able to just go "up into neutral from 4th, all the way right against the wall, and then up into 5th". It's definitely going to take me some time to aim for 5th gear.
Well I already bought the car, it was sort of a deal I couldn't pass up on. The car does have a bumper-to-bumper warranty for the next 3 years and 36,000 miles that covers everything except routine maintenance with a $0 deductible, so it's all essentially free work. What do you think would be the cause of this weird shift movement? I like to have some idea of what I'm talking about before I bring it up to a mechanic.
https://my350z.com/forum/north-east/...et-2009-a.html
Sometimes you need to be a bit deliberate when going into 5th. Pushing to right fully then up should go in. If you are being firm and it still doesn't go in that way, someone should look at it.
Hope this helps.
the only times i have problems shifting was from 1st to 2nd. never had any problems going into 5th or 6th. the Z was also not my first manual car, but it does take bit more skills to drive than say Honda's MT's.
Amazing all these replies and not one person can tell the OP that there is an adjustable guide plate that may be the culprit.
OP,
It's possible the one you are looking at just needs to be adjusted. See attached for the procedure to set it so that it will help guide the shift lever into 5th and 6th gear.
OP,
YOU started this thread, YOU deal with the responses.
OP,
OP,
It could also be your xmsn sincro's are going bad, when mine started to go out it would stop me from going into 6th and then fifth and then it would grind while engaging into 6th and then 5th grinded shortly after. It is just a possibility I would say since it is under warranty, go to a dealer and take a tech for a ride in it to show them what it is doing and if it is bad they will replace it no ?'s asked. Good luck man
