angry...
Old Apr 15, 2009 | 12:00 AM
IsDatIt's Avatar
IsDatIt
Old Apr 15, 2009 | 12:27 AM
Manjot's Avatar
Manjot
LOL @ Rx7
Old Apr 15, 2009 | 02:47 AM
SSZVirginia's Avatar
SSZVirginia
Originally Posted by plpz2104
it wasn't there fault so i had to notify my insurance
What is your deductable?
Old Apr 15, 2009 | 05:45 AM
plpz2104's Avatar
plpz2104
deductable is 495
Old Apr 15, 2009 | 05:53 AM
Brrcats's Avatar
Brrcats
deductable is 495
why arent you doing this yourself again?
Old Apr 15, 2009 | 06:03 AM
QNman's Avatar
QNman
Originally Posted by foreveryoung
Hmmm.Most theives I have ever encountered loosen the wheel nuts to steal the wheels,not tighten them.If the stud broken,you can be sure they were overtorqued ot begin with.
Overtightened sounds far more likely than a stupid thief, IMHO.
Did you have your wheels removed, serviced, or (heaven forbid) rotated somewhere? Like Jiffy Lube or something? "Torque sticks" are supposed to be stupid-proof, but as long as people operate it, it's hard to engineer "stupid" completely out.
Just my 2c... I don't let anyone near my wheels with an impact, torque sticks or no.
Old Apr 15, 2009 | 07:10 AM
pangoman's Avatar
pangoman
Chit happens , $2.50 and 30 minutes and your good to go.
+1^^^^^^^^^^
Old Apr 15, 2009 | 03:44 PM
plpz2104's Avatar
plpz2104
i'm not doin it myself because the rotor and other stuff needs to be replaced and i don't have time to do it myself im a busy person
Old Apr 15, 2009 | 03:48 PM
avandss's Avatar
avandss
Originally Posted by Flick Montana
Maybe it was your pit crew?
<object width="640" height="505"><param name="movie" value="http://www.youtube.com/v/jv4m41viy4I&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/jv4m41viy4I&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="505"></embed></object>
ok seriously HOW THE HELL can that happen? i can understand one wheel but all 4? someone is fu*king with him?
i wonder how much damage that just cost him? and imagine the guys face as his wheels flew off and the car started jumping lol
Old Apr 15, 2009 | 03:50 PM
avandss's Avatar
avandss
whats wrong with the rotors? your car only has 5k???
lol @ your a busy person...
Old Apr 15, 2009 | 04:49 PM
terrasmak's Avatar
How does the rotor get damaged ?? Just go get the $2.50 to $5 in parts , remove your wheel, remove the caliper , caliper bracket (were up to 9 bolts now, including lug nuts ) rotor will slide off , tap the bad studs out with a hammer , slide new studs in , put 4 12mm washers over the stud , an lug nut installed upsidedown and tighten till the stud is pulled thru. Install the rotor, bracket , caliper and wheel.
Or remove your man card , and never call yourself a man again. Its a simple job any man should be able to do.
Old Apr 15, 2009 | 05:45 PM
SirSpeedyZ's Avatar
SirSpeedyZ
:bowro fl:
:ico n18:
Old Apr 15, 2009 | 07:51 PM
04zee's Avatar
04zee
that guy driving the rx 7 i dont know whats worse the wheels falling off or his short shorts.
Old Apr 16, 2009 | 02:39 AM
SSZVirginia
If you are young and you attempt to claim this through insurance your rates will increase dramatically. If you don't want to do it yourself get out your checkbook.
Old Apr 17, 2009 | 06:59 AM
QNman's Avatar
QNman
Actually, if the rotor was also damaged, it will DECREASE the amount of time to replace... mount the new studs in the new rotor and just swap the rotors. 30 minutes, tops.
Old Apr 17, 2009 | 10:03 AM
350Zamn's Avatar
350Zamn
+1
Old Apr 17, 2009 | 10:08 AM
MarvinMartian's Avatar
MarvinMartian
Maybe OP is a girl?
In that case, pics or GTFO.
Old Apr 17, 2009 | 11:12 AM
  #38
QNman's Avatar
QNman
Originally Posted by MarvinMartian
Maybe OP is a girl?
Doesn't matter. Girls can wrench too. Besides, OP quoted time as the problem; not lack of mechanical knowledge.
Old Apr 17, 2009 | 11:35 AM
  #39
terrasmak's Avatar
Go back to the Civic forum, you obviously have no clue.
Old Apr 17, 2009 | 12:00 PM
  #40
saywat?'s Avatar
saywat?
buwahahaha that was koo
