I think my base model came with LSD
Old Apr 25, 2009 | 12:22 AM
oreodawg1's Avatar
oreodawg1
Default I think my base model came with LSD
I just bought a 2006 350z. I thought it was a base model because it doesn't have cruise control or heated seats or leather. It has HID's, and the 18 inch wheels, but i think that's standard on 06's. Well when I do a burnout I get two tire tracks. When I jack up the car and spin the tires while in gear they spin opposite directions. Out of gear only one tire will spin. It's so confusing how do I know if my car has an LSD for sure.
Old Apr 25, 2009 | 12:37 AM
Chromex319's Avatar
Chromex319
Interesting. I dunno enough about this but you bet your *** I will be checking back to find out the answer when you do.
Old Apr 25, 2009 | 02:45 AM
terrasmak's Avatar
Dog leg , with enough power both will spin for a few.
Old Apr 25, 2009 | 04:13 AM
*Boose*'s Avatar
*Boose*
I have an 06 base also. Sometimes both wheels do spin yes. But they do not come standard with LSD. *Without killing yourself or injurying others* from a stop attempt to make a right or left turn full throttle with about a 2k rpm launch slipping the clutch. Guarantee you that only one wheel will spin 90% of the time. But the 18" tires and HID's came standard on 06+. Just bought it and already doing burnouts :/ scares me a little.
How many miles on yours?
Old Apr 25, 2009 | 04:16 AM
Z1NONLY's Avatar
Z1NONLY
I was able to get both tires to spin when the car was pointed straight and the load was even for both tires. (with my open diff)
If you want to see where an open diff shows its weakness, go do an autocross or anything where you need to apply power out of a turn.
With an open diff, the inside tire will become "unloaded" and start spinning, while the outside tire, with most of the weight and traction will just be along for the ride.
Digging out of turns is much easier with a LSD.
Old Apr 25, 2009 | 05:30 AM
Jack up the which ever end is in question to get the tires off the ground. Put the transmission in neutral and spin one of the tires by hand.
If the opposite tire spins in the same direction, you have a limited slip differential.
Reference: http://wiki.answers.com/Q/How_do_you...p_differential
Old Apr 25, 2009 | 06:32 AM
HawaiianBBQ's Avatar
HawaiianBBQ
Default LSD
I agree!
Old Apr 25, 2009 | 05:44 PM
Kiriller's Avatar
Kiriller
i did 3 or so 11's so far, and all those times they were equal lengths. I have base also, maybe just luck though..
Old Apr 25, 2009 | 09:18 PM
350ZthatsMe's Avatar
350ZthatsMe
jack up your car and look at your diff from the rear.. if it has the OEM LSD there should be a hose coming from the top...
Old Apr 25, 2009 | 09:24 PM
ssgohan434's Avatar
ssgohan434
You don't
Old Apr 26, 2009 | 02:03 AM
terrasmak's Avatar
Still havn't seen that , my truck has an LSD and the don't spin the same direction , same with my 03 touring. I think thats only for lockers (detroit lockers)
Old Apr 28, 2009 | 12:37 PM
PerfZ's Avatar
PerfZ
Aftermarket LSD is a distinct possibility. Any other mods?
Old Apr 28, 2009 | 12:46 PM
06blueZ's Avatar
06blueZ
the vent hose is on both open and VLSD cars.
Old Apr 28, 2009 | 07:58 PM
You are welcome.
Old May 27, 2009 | 05:46 PM
SLIdEwAyZ25's Avatar
SLIdEwAyZ25
so if you have leather seats 18 inch stocky's bose stereo cruize power seats you have an lsd? because i bought a 350z with all that and im not very familiar with these cars because all i have ever owned are rx7's
Old May 28, 2009 | 04:45 PM
ambientflier's Avatar
ambientflier
If you have cruise control, then you definitely have an lsd. Cruise control is not available on base models, which are the only ones without LSD.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350z82
Oct 1, 2015 06:25 PM
