Redline Beep
Old Aug 3, 2009 | 10:16 PM
freshlettuce's Avatar
freshlettuce
Default Redline Beep
I used to own an rx-8, and one of my favorite parts about it was the beep it would make when you would redline it. My question is, is there anyway to install such a device that would allow that to work once I hit 7500 RPMs
here is an example of what I'm talking about on the rx-8. Just listen for the beep, don't comment on the slow acceleration or any of that other jazz.
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/5cFWDJlRoAo&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/5cFWDJlRoAo&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Old Aug 3, 2009 | 10:36 PM
sportbiketed's Avatar
sportbiketed
Damn thats slow.
Oh and that beep is annoying.
Old Aug 3, 2009 | 10:39 PM
freshlettuce
Originally Posted by sportbiketed
Damn thats slow.
it's actually not annoying, and was very helpful to me when I tracked my rx-8. I could shift without taking my eyes off the road
Old Aug 3, 2009 | 10:41 PM
XSpeedAddictX's Avatar
XSpeedAddictX
Not a bad idea, lemme know if you find anything.
Old Aug 3, 2009 | 10:43 PM
mrg1981's Avatar
mrg1981
Yes, actually, there is a way to do this, with an aftermarket EMS. I believe the Defi Control Unit II can do this. I have it beep on Exhaust temp and overboost, but I believe it can read/notify for many different gauges. Or, you could just use the shift light if your model has it. Or you could get a racing tach with those types of features.
Old Aug 3, 2009 | 10:45 PM
freshlettuce
thanks I'll look into those! My car does have the rev limiter light as stated, but once again it takes focus off the track/road to look down at my RPMs and the light.
Old Aug 3, 2009 | 10:52 PM
mrg1981's Avatar
mrg1981
My point is that you can set the light to go at different RPM levels. You don't need to look at your RPM's then. You'll know when to shift with some practice.
Old Aug 3, 2009 | 11:00 PM
mrg1981's Avatar
mrg1981
BTW, here is some more information and pricing for you:
http://www.intensepower.com/decounii.html
http://www.intensepower.com/defilinkmeter.html (shows which gauges can be read through the control unit. I see Tach on there!
"ull-lineup: boost(for turbocharged and supercharged engines), intake manifold pressure(for natural aspirated engine), oil pressure, water temperature, oil temperature, fuel pressure, exhaust gas temperature and tachometer. White and black gauge dials are available.
Double Warning function by a meter's LED lamp and a beep"
OR...
You could project the speed, tach, etc onto the windshield, like the Vettes.
http://www.intensepower.com/vsdconcept.html
http://www.intensepower.com/vsdbasis.html
I have the Defi Control Unit II. If you want more information on how it works, or want to hear/see it in action, let me know.
Old Aug 4, 2009 | 03:18 AM
DavesZ#3's Avatar
DavesZ#3
The RX-8 squirrel doesn't make a lot of noise so it's possible that hear a redline beep. You'd need a Klaxon to hear over the roar of the mighty VQ.
Old Aug 4, 2009 | 03:41 AM
jebz240's Avatar
jebz240
Test drove a RX back in the day and i didn't care for the feature for day-day driving seemed like it would be nice for the track but you almost have to red-line the rotary to get it to move imo.
Old Aug 4, 2009 | 04:39 AM
Spork's Avatar
Spork
If you know your car well enough, you can shift fine just by listening to the engine.
With the Z, you don't have to bring it to redline for power.
Old Aug 4, 2009 | 09:04 AM
Mike@Blackline's Avatar
Mike@Blackline
couldnt you just tap the shift light wire, and run it to a speaker, so when the light receives power, it would power the speaker, and you could have it play any sound, a beep, some young dro, or some phil collins.
Old Aug 4, 2009 | 09:57 AM
Spork's Avatar
Spork
You'd have to just amplify the signal and have it run to a speaker using a single flat hz range. I'd want a tweeter with a Chris Tucker "Daaaaaaamn!"
Old Aug 4, 2009 | 11:17 AM
illjim69's Avatar
illjim69
Why do you need a beep, light or even a tach to know when to shift?
Old Aug 4, 2009 | 12:08 PM
anth72's Avatar
anth72
Check this out. This might be better than a beep if your going to be tracking your car with the windows down. Might be too noisy for the beep. I wanna get this mod done but I know it will be a PITA to take the instrument cluster apart and solder onto the circuit board. But it is on the future mod list.
https://my350z.com/forum/exterior-an...ift-light.html
Old Aug 5, 2009 | 06:13 PM
DFW 350G's Avatar
DFW 350G
Old Aug 5, 2009 | 06:16 PM
Word Sux's Avatar
Word Sux
If you drive your car enough shouldn't you be able to tell if your at redline by sound. idk if I'm doing it wrong but thats what I do when I'm at the track or auto xing
Old Aug 6, 2009 | 05:20 AM
SA Z-boi's Avatar
SA Z-boi
Old Aug 6, 2009 | 06:09 AM
paosti350z's Avatar
paosti350z
-agrees.
Old Aug 6, 2009 | 06:34 AM
anth72's Avatar
anth72
Sometimes it's easy to hear where redline is. But sometimes when you have to shift mid corner on a long sweeper and all 4 tires are squeeling, with the windows open, its tough to hear redline. Since the stock light is useless because it's not bright enough during day use, you may as well use the system and put brighter lights in. If you think about it, why do all race cars have shift lights? These drivers should be able to hear redline no? I'm not comparing the 350 to a race car but I'm just saying if the ability to have a shift light is there you may as well use it.
