I normally use Chevron but I used SHELL last night and...
Old Oct 12, 2003 | 08:35 AM
mrZeee's Avatar
mrZeee
no one uses sunoco 94? I avg 21.5 (mostly hi way) but just put in K&N and saw a it jump up to 23 (mixed driving) anyone had the same experience with K&N's in there Z's? with my other cars shell gas usually did give better mpg...but not as much "uuumph?"
Old Oct 12, 2003 | 02:21 PM
SlamMan's Avatar
SlamMan
FYI, Using "race gas" won't help the performance of your car. In fact the higher octane will inhibit the burning of fuel in your cylinders causing you to loose power. The high level of octane in race gas is to help prevent predetonation in engines that are seceptable to it like forced induction or ultra-high compression engines.
Originally posted by overlord tom
When I feel spunky I slap a few gallons in before a fill-up for a weekend cruise. Car runs way better. Don't know if it's worth the $4.79 a gallon though. I'd say it is equal to eating at Outback vs Carls Jr. Both will fill you up with meat and do the job. Only one feels right and is worth 5x the price during times you want to spoil yourself.
Old Oct 12, 2003 | 02:39 PM
KONVERTER's Avatar
KONVERTER
Originally posted by bshockley
Not to try and burst your bubble or anything, but maybe one way was uphill mostly and the other was down hill. I.E. you drove up into the mountains one way, filled up, then drove back down them (extreme example).
I've done it before, driving from KC to Denver, filled up twice, driving back made it with about 1.5 tanks.
I have only filled my Z twice so far, the last time being Shell. I'll figure it's gas milage next fill up.
yeah your rite...
they way back was UP HILL...
Old Oct 12, 2003 | 02:48 PM
EnthuZiast's Avatar
EnthuZiast
Guess whose back, back again...
Funny you say that. Talked to a client who has a shell station and I ALWAYS use Chevron. But you just valedated some of the things he said. I will be trying there gas next. As far as Texaco dont try them because shell just bought.
Old Oct 12, 2003 | 02:50 PM
EnthuZiast's Avatar
EnthuZiast
them.
Old Oct 12, 2003 | 02:53 PM
EnthuZiast's Avatar
EnthuZiast
As far as K&N it made a considerable difference in my old MAX. Gained over 30 miles to the tank! But amd worried about it damaging the Z. Read a thread about how the oild on it can do serious damage to the Z.
Old Oct 12, 2003 | 03:36 PM
labowbow's Avatar
labowbow
in CA we don't have 93 oct gas
Old Oct 12, 2003 | 03:41 PM
alphared's Avatar
alphared
weird. I use Mobile 93 oct. Last I checked I gotten 26 mpg avg. I was really suprise at the jump, I was avg like 20 before (think a few month ago).
Old Oct 12, 2003 | 03:54 PM
EnthuZiast's Avatar
EnthuZiast
only 91 here too!
Old Oct 12, 2003 | 06:11 PM
archman350z's Avatar
archman350z
Umm, you're wrong on this one. For most cars, yes, but the Z, no. SportCompactCar did a dyno pull with 100 octane race-gas and found the Z made an additional 5HP (in pure-stock form). The reason being that the ECU controls the timing advance based on feedback from the knock sensor. You are correct in that higher octane fuels burn slower, but they also burn more consistently (less impurities that may burn faster)...that is why they don't knock as much.
An interesting side note: slower burning fuels are actually more powerful. Nitromethane burns incredibly slow compared to gasoline. But the drag-racers still use it. Why? Because Nitromethane burns so slow, it continuously drives the piston down during the entire power stroke instead of the quick "bang" of gasoline. In fact, the nitro is still burning when the piston is on the exhaust stroke!! This burning mess is then pushed out through the exhaust...that's why nitro funny cars have flames shooting out the exhaust pipes: it's really fuel that is still burning from the power stroke!!
I use Turbo Blue (100 octane) whenever I'm going to be beating on it hard (like a race track) or in high heat/humidity. The idea is to keep the knock sensor at bay.
KONVERTER: thanks for making this post! I was wondering what was going on a few weeks ago when I got 31.2 MPG on the way home (normally it's 28.5 MPG)!!! ...I stopped at a Shell station that time...hmmm. Normally, I fill up using SUNOCO 94 Ultra...no problems with it otherwise.
Old Oct 12, 2003 | 06:18 PM
Zilverb@ck's Avatar
Zilverb@ck
Actually, Chevron, Texaco, and Shell are all the same. They are all owned by the same people. It is what is put in the gas afterwards that makes it good gas. ANd Exxon and Mobil are owned by the same people too. Just an FYI
Old Oct 12, 2003 | 07:41 PM
SlamMan's Avatar
SlamMan
Damn, foiled again. Thats pretty interesting info. Do you happen to know what issue of SCC that was in.
Old Oct 12, 2003 | 07:49 PM
KONVERTER's Avatar
KONVERTER
really all gass is the same when you think about it...
it all ocmes off the same tankers...
Old Oct 12, 2003 | 08:09 PM
EnthuZiast's Avatar
EnthuZiast
All gas comes for the same tankers.............
.........and out my a$$
sorry...just thought a random immature comment was appropriate.
Old Oct 12, 2003 | 08:11 PM
Jsn350Z's Avatar
Jsn350Z
Hmm...Filled up with Shell today, normally use chevron. 91 octane.
Average mpg b4 fill up: 18.2
Average mpg after fill up and a day of driving, Still 18.2
Although, recently my ave mpg has been dropping very very fast (I can redline the car now ) But it stayed the same all day.
Hmmmmm
Old Oct 12, 2003 | 08:19 PM
KONVERTER's Avatar
KONVERTER
Hmmmmm
did you reset your meeter...
because if you just left it then it would have been figuring the new MPG with the old... and if you had 500 miles at 18.2MPG then you wouldnt start seeing a difference till you went another few hundred miles...
remember its AVERAGE not real time MPG
SinistaZ's Avatar
SinistaZ
explain this medua hat thing, im totally lost...
Old Oct 12, 2003 | 08:42 PM
  #38
KONVERTER's Avatar
KONVERTER
its the thing im wearing in my sic / avaiter...
http://x.oakley.com/catalog/display/...dark_brown/s_m
Old Oct 12, 2003 | 09:08 PM
  #39
FLY BY Z's Avatar
FLY BY Z
Saying "the drag racers use nitromethane" is quite inaccurate. Only one class in all of drag racing uses this fuel. It is Top Fuel (and TF Funny Car). No other class uses it. We use VP C10 which is about 110 octane I believe and we run about a 12:1 compression. This is one reason I think 11.5:1 is too high for people to upgrade their street car pistons. Anyways, the flames exiting the headers of the Top Fuel cars is indeed fuel. But it is not due to nitromethane from the power stroke. It is just unburnt fuel that "collects" in the headers. Even street cars with 87 octane can have fuel burn in the exhaust system. And don't fool yourself, Top Fuel cars are supersupercharged and run high compression. They blow up every pass down the strip! The Z is hardly tuned to that extreme. If you want to "beat" on your car without worrying about the knock sensor, just use premium and if you are crazy, put in a little octane booster and save some crazy money instead of buying 100 octane gas.
Old Oct 13, 2003 | 05:50 AM
  #40
Ralphus's Avatar
Ralphus
It's less about the brand of gas, and more about the station you buy it at. You should always try to use the same station as your car will be adjusted to that gas. If you've found one better try to go there of course.
Also, remember to never get gas when the tanker truck is filling the tanks.
